How to get opencv images from argus/syncsensor sample?
Hi folks,
I use Jetpack 4.2.1 on jetson nano b01 board.
I have OpenCV 4.2.0 cuda supported.
I want to modify syncsensor sample to get mat object.
cuGraphicsResourceGetMappedEglFrame(&m_frame, m_resource, 0, 0);
Under above code, I added ;
cv::cuda::GpuMat gpu_rgba(m_frame.height, m_frame.width, CV_8UC4, m_frame.frame.pPitch[0]);
cv::cuda::GpuMat gpu_rgb (m_frame.height, m_frame.width, CV_8UC3);
cv::cuda::cvtColor(gpu_rgba, gpu_rgb, cv::COLOR_RGBA2RGB);
cv::Mat cpu_mat(m_frame.height, m_frame.width, CV_8UC3);
gpu_rgb.download(cpu_mat);
But it does not work.
I have an error.
error: (-217:Gpu API call) unspecified launch failure in function ‘call’.
What do I have to do to get cv::mat object from syncsensor sample, could you help me, please?
Thanks for support.
You may refer to this patch:
