How to grip chair part using gripper
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 4090 D
  • Driver Version: 570.133.07
Topic Description
How to use friction to grip chair part using gripper
Screenshots or Videos
Hi @zhiguo.tang1, thanks for posting your question. You should be able to pick up objects with gripper friction. Two things I suggest doing:
  1. Update your Isaac Sim to 4.5.0. Many things in 4.0.0 are not supported anymore.
  2. You can look at the example here for using gripper to pick up a cube: Adding a Manipulator Robot — Isaac Sim Documentation
  3. You can also add a particular material to the gripper fingerpad links: Here are some readily available materials: Material Browser — Omniverse Extensions Maybe something like rubber will provide good amount of friction.
Hope that helps.
Hello!
Best regards,
