Hi, I am following this tutorial https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_required_hello_world.html#converting-it-to-a-standalone-application and wondering if there are any ways to hide every properties panels when I run the application? I only want to see the viewport.
Here is my expectation:
I found a solution, however it is hard-coded. If there are another way to do it I am gladly to know.
from omni.ui import Workspace
Workspace.show_window("Stage", False)
Workspace.show_window("Layer", False)
Workspace.show_window("Property", False)
Workspace.show_window("Render Settings", False)
Workspace.show_window("Console", False)
Workspace.show_window("Content", False)
Hi @hoanggiang
You can also use the following keyboard shortcuts:
| F7 | Enables and disables the visibility of the UI | |
| F11 | Toggles full screen mode |
Check the viewport control docs for more details
F7 works well with a normal stage, but not with a standalone version.
But thanks to your answer, I found a better way to do it
import carb.settings
settings = carb.settings.get_settings()
settings.set("/app/window/hideUi", True)
But then I couldn’t press F7 to enable the visibility of the UI again :)
Nice…
Now, if you want to toggle the UI visibility you can try:
import omni
def keyboard_event(event, *args, **kwargs):
if event.type == carb.input.KeyboardEventType.KEY_PRESS:
if event.input == carb.input.KeyboardInput.F7:
settings.set("/app/window/hideUi", not settings.get("/app/window/hideUi"))
appwindow = omni.appwindow.get_default_app_window()
input = carb.input.acquire_input_interface()
input.subscribe_to_keyboard_events(appwindow.get_keyboard(), keyboard_event)
I’ve filed a bug for F7 not working in standalone mode, that should work in theory. The extension that handles that might not be enabled with standalone python.kit by default.
