How to install NFSv4
We used ‘nfs-kernel-server’ to install nfs server on our Orin. The linux version is 20.04. The nfs version should be nfsv3 and nfsv4, but we only got -2 and +3. Is there any way to install nfsv4? Thanks.
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
[✔] other
Target Operating System
[✔] Linux
QNX
other
Hardware Platform
[✔] other
SDK Manager Version
1.9.3.10904
[✔] other
Host Machine Version
[✔] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Your issue was posted t worong forum, I’m moving it into Jetson AGX Orin forum to get the support.
https://cateee.net/lkddb/web-lkddb/NFSD_V4.html
Enable this kernel config and build the kernel again.
It is not by default enabled.
Thank you for responding!
We tried and could not find the KConfig file.
According to the link you mentioned, we checked file path: ‘fs/nfsd/Kconfig’. But there is no Kconfig file in this file path.
Hi dude,
I mean you have to download the kernel source manually.
Kernel source will not be present on your device unless manually downloaded.
fs/nfsd/Kconfig means the file in the kernel source directory, not the rootfs.
