How to make an extension appear under the Window menu?
@v.b.naik i am just another user, but did you already enabled the extension in the extension manager? and also, which extension is it that you are looking for, is it 3rd party or one that ships with Composer?
To enable the extension manager, you must run the template in the developer mode. To do this you add the “-d” flag to the launch code. This will start the program, but now with the extension manager visible under the developer menu.
