Hi Guys,
I wish to play audio wav file on TX2. What is the best way to achieve the same ?
Hi Guys,
Hello!
The Jetson TX2 does not have an on-board codec and so if you want to playback a WAV file, you can connect the TX2 HDMI to a TV or monitors with speakers can use the following command …
aplay <wav-file>
It is possible to connect an external audio codec to the board and probably the most simplest would be …
https://devtalk.nvidia.com/default/topic/1032785/no-sound-using-i2s-to-cs4344-codec/#5279504
Regards,
Jon
Depending on your app requirements, even simpler may be to use a USB audio to analog adapter.
I have have been using a CM108 based one (just a few $), it works fine out of the box (you may just have to adjust sound mixer in Ubuntu).
I am using USB headsets (USB headsets have an integrated sound card, by default), or hdmi tv monitor that has speakers.
mplayer *.wav
mplayer *.mp3
works for me
