Hello, experts
The dev board and our custom board‘s USB port will not lose power when the system reboot. This caused the system to reboot, but the peripherals were not reset.
Is there any reference scheme that can reset the power on the USB port at the same time when the system reboot through hardware signal control?
You should tell us how you designed your usb port on your custom board.
We don’t know you or your board. Why do you expect we can answer your question with 0 info provided?
