USB ports fail after reboot - Jetson AGX Xavier
System characteristics:
Jetson AXG Xavier 16GB
Jetpack 4.5.1
L4T 32.5.1
Hi. I’m recently flash an AGX Xavier with the above characteristics. After installation, I reboot the device and, after it, any USB port could detect physical connected devices.
I connected a mouse to see if the USB port supply voltage, but not. The led mouse was off all the time.
I had to restart the device manually (with the reset button) and, after it, the USB ports work correctly.
The problem is that it is not the first time it happens. Previously, I had the same AGX Xavier with Jetpack 4.4.1 and the same problem happened.
This is an unusual behaviour and I want to understand what is happening.
Thank you for your help.
This looks like a Jetson issue. We recommend you to raise it to the respective platform from the below link
Latest Jetson & Embedded Systems/Jetson AGX Xavier topics - NVIDIA Developer Forums
