Hi.
I am trying to profile my python code on CLI, but I can’t find the command “nsys”.
Documentation says that Nsight Systems can run on Intel© Core series x86_64, so it seems to be unable to run Nsight Systems on Jetson Nano.
https://docs.nvidia.com/nsight-systems/index.html#nsight_systems/2019.6.1-x86/03-system-requirements.htm%3FTocPath%3D_____3
Is it possible to run Nsight Systems on Jetson Nano? If possible, how to run the command “nsys” on Jetson Nano?
Hi ksk256, Nsight Systems runs from an Ubuntu-based x86_64 host PC and collects profiling information from the Jetson remotely over a network connection. You can install Nsight Systems to your host PC using the NVIDIA SDK Manager tool.
You can profile CUDA applications from the Nano itself using the nvprof command line tool:
https://docs.nvidia.com/cuda/profiler-users-guide/index.html#nvprof-overview
