I’m trying to run a Moveit2 Python Example from command line.
I could run it from simulation UI, but having hard time to execute from command line.
Following command is what I tried with Conda, and no-Conda environments.
(isaac) ~/isaac-sim$ python3 /home/jay/isaac-sim/exts/isaacsim.ros2.bridge/isaacsim/ros2/bridge/impl/samples/ros_moveit_sample.py
File "/home/jay/isaac-sim/exts/isaacsim.ros2.bridge/isaacsim/ros2/bridge/impl/samples/ros_moveit_sample.py", line 22, in <module>
import omni.appwindow
ModuleNotFoundError: No module named 'omni.appwindow'
~/isaac-sim$ ./python.sh /home/jay/isaac-sim/exts/isaacsim.ros2.bridge/isaacsim/ros2/bridge/impl/samples/ros_moveit_sample.py
There was an error running python
Is there a way to execute python example solely from command line?
Basically, what I want to achieve is running this from command line (from Hello World Example):
Thank you in advance.
