How to set stiffness and damping for a drive with ROS2 and python
Setting joint drive stiffness and damping
Isaac Sim Version
5.0.0
Operating System
Ubuntu 22.04
Detailed Description
Hi, I have loaded my robot in a USD file and added ROS2 OmniGraphs for controlling it, which works perfectly — I can send position, velocity, and effort commands to my joints. I would like to be able to change the stiffness and damping of each joint during the simulation. If it’s possible to set them via a ROS2 OmniGraph, that would be ideal. Otherwise, I would greatly appreciate any guidance on how to do this. I’m new to Isaac Sim, so any help is very welcome.
@mehdi1379_2000 i am just another user, but feel free to take a look at the API doc mentioned by the mod in another thread that would allow you to control the DOF properties including stiffness and damping:
You can go to the Isaac Sim examples and check the code
[Isaac Sim]–>[Window]–>[Examples]–>[Physics Examples],
[Joints]–>[Rigid-Body Ropes]
then, it use DriveAPI to set the damping & stiffness
hi, thanks a lot for your suggestion but it doesn’t work for me. i have installed Isaac by downloading it not via pip and i am running pyhton codes using python.sh but it can not import some libraries like pxr
am i doing it in wrong way?!
If you want to change the drive stiffness and damping directly on the joints, the UsdPhysics.DriveAPI is the low‑level USD/PhysX API that exposes those attributes on the prims.
