I’d like to have my PC’s GTX 1050 drop to the lowest clocks speed, when there is no need for high performance.
It worked before.
However, after a driver update (I don’t know which one), clocks are stuck on the highest values.
In nvidia-settings I have:
- Adaptive Clocking - Enabled
- Preferred Mode - Auto
- Current Mode - Adaptive
I’m stuck on the highest performance level (which is 2).
Every 30 seconds performance level drops to 1 for 1 second and rises again.
It happens when there are applications running or in a complete idle state.
I’m on kernel 4.15.18 and here are nvidia-smi results:
| NVIDIA-SMI 396.18 Driver Version: 396.18 |
| 0 GeForce GTX 1050 Off | 00000000:01:00.0 On | N/A |
| 0% 54C P0 N/A / 90W | 885MiB / 1984MiB | 7% Default |
If someone could point me in the right direction that would be much appreciated.
