Software Version
DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
I have multiple cameras of different models, and when I call INvSIPLQuery:: GetPlatformCfg for different cameras, there will be different arguments’ name '. Then when I call INvSIPLCamera:: SetPlatformCfg for each camera, it will report an error. Can’t INvSIPLCamera:: SetPlatformCfg be called for different cameras in the same program? How to call INvSIPLCamera:: SetPlatformCfg for configuration of different camera models?
I found that in the same program, INvSIPLCamera:: SetPlatformCfg can only be called once, which prevents me from configuring different models of cameras through this interface
Dear @TomFord ,
Is it like you want to run single instance of nvsipl_camera process to with multiple cameras of different type?
May I know the camera modules and connections port details.
Dear @SivaRamaKrishnaNV
Yes, I want to run single instance of nvsipl_camera process to with multiple cameras of different type.
the camera modules is V1SIM728S2RU2030NB20_CPHY_x4 and F008A120RM0A_CPHY_x2. The connections port is C, pin-2 and pin-3 .
Dear @TomFord ,
Could you try below steps.
Create mixed JSON file with two cameras.
Run ./nvsipl_camera -t ./mixed_camera.json -c MIXED_CAMERA_CPHY_x4 -m “0x0110” –showfps to create new mixed platform config in database (or just -t -c are enough?)
Run ./nvsipl_camera -c MIXED_CAMERA_CPHY_x4 -m “0x110” –showfps to test the mixed config
Mixed_camera.json is below
“platformConfigs”: [
"name": "MIXED_CAMERA_CPHY_x4",
"description": "MIXED CAMERA_4 lane CPHY mode",
"enableMasks" : ["0x0110"],
"deviceBlocks": [
"homogenousModules": false,
"csiPort": "csi-ef",
"passiveMode": false,
"phyMode": "cphy",
"simulatorMode": false,
"deserializer": "MAX96712_Fusa_nv",
"groupInitProg": false,
"cameraModules": [
{"name": " V1SIM728S2RU2030NB20", "linkIndex": 1, "sensors": [{"name": "IMX728", "id": 0}]},
{"name": " F008A120RM0A ", "linkIndex": 2, "sensors": [{"name": " AR0820 ", "id": 1}]}
My JSON file is below:
"platformConfigs": [
"enableMasks": ["0x0000 0x0000 0x1001 0x0000"],
"deviceBlocks": [
"csiPort": "csi-c",
"phyMode": "cphy",
"cameraModules": [
"name": "SG0233C5200M",
"linkIndex": 0,
"sensors": [{
"name": "GW5200",
"id": 8
"name": "V1SIM623S4RU5195NB3",
"linkIndex": 3,
"sensors": [{
"name": "IMX623",
"id": 11
But when I run the command ./nvsipl_camera -t ./mixed_camera.json -c “MIXED_CAMERA_CPHY_x4” --showfps -v 3, an error is reported as follows:
Platform configuration name: MIXED_CAMERA_CPHY_x4
Platform configuration file: ./mixed_camera.json
Verbosity level: 3
Raw output: disabled
ISP0 output: enabled
ISP1 output: enabled
ISP2 output: enabled
Enabled FPS logging
Disabled Metadata logging
Disabled automatic recovery
Disabled NvSci
Disabled profiling
Disabled initialization profiling
Disabled ISP Statistics settings override
Subframe : disabled
Disabled Passive mode
Disabled retrieving/displaying NITO Metadata
nvsipl_camera: Setting up signal handler
libnvsipl_query.so: CNvMQuery.cpp : 238: ParseJsonFile: CNvMQuery::ParseJsonFile reading file ./mixed_camera.json
libnvsipl_query.so: CNvMDeviceBlockInfo.cpp : 134: ParseJson: deserializer on this platform MAX96712_Fusa_nv
libnvsipl_query.so: CNvMSensorInfo.cpp : 209: ParseJson: Updated GW5200
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 226: ParseJson: Parsed SG0233C5200M
libnvsipl_query.so: CNvMSensorInfo.cpp : 209: ParseJson: Updated IMX623
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 226: ParseJson: Parsed V1SIM623S4RU5195NB3
nvsipl_camera: Getting platform configuration for MIXED_CAMERA_CPHY_x4
nvsipl_camera: Creating camera master
nvsipl_camera: Setting up master
nvsipl_camera: Creating consumers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 394: LogPlatformCfg: ---------- START PLATFORM CONFIGURATION ----------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 395: LogPlatformCfg: platform:
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 396: LogPlatformCfg: platformConfig: MIXED_CAMERA_CPHY_x4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 397: LogPlatformCfg: description: MIXED CAMERA_4 lane CPHY mode
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 398: LogPlatformCfg: numDeviceBlocks: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 500: LogPlatformCfg: ----------- END PLATFORM CONFIGURATION -----------
nvsipl_camera: ERROR: Master SetPlatformConfig failed. status: 1
Dear @TomFord ,
Could you please confirm if the used camera modules are listed in DRIVE AGX Orin Sensors & Accessories | NVIDIA Developer .
Is nvsipl_camera is working with both camera modules independently?
Yes, nvsipl_camera is working with both camera modules independently. And I have already used V1SIM728S2RU2030NB20_ CPHY_ x4 and F008A120RM0A_ CPHY_ X2, similar errors will also occur:
Verbosity level: 3
Enabled FPS logging
Disabled NvSci
Disabled profiling
Subframe : disabled
libnvsipl_query.so: CNvMSensorInfo.cpp : 209: ParseJson: Updated IMX728
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 226: ParseJson: Parsed V1SIM728S2RU2030NB20
libnvsipl_query.so: CNvMSensorInfo.cpp : 209: ParseJson: Updated AR0820
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 226: ParseJson: Parsed F008A120RM0A
system
Closed
May 18, 2023, 7:27am
10
Dear @TomFord ,
I see above post is marked as solution. Could you confirm the status?
Dear @TomFord ,
May I know if you are able to run the multiple camera configuration?
