NVSIPL Camera with Custom JSON config input
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi, I am testing with nvsipl_camera and would like to test with multiple different vendor cameras. I saw from these two links: How to set up multiple cameras of different models - #2 by TomFord and Unable to get multiple cameras working on AGX ORIN - #11 by SivaRamaKrishnaNV that I need to have a custom JSON file to set up the configuration.
First, I want to get the JSON file working with one camera before I test multiple. I did not get any final resolution from these threads that worked for me, this is what I am seeing currently:
Note: I am using the camera config F008A120RM0AV2_CPHY_x4
  1. nvsipl camera is working correctly without the JSON file:
sudo ./nvsipl_camera -c F008A120RM0AV2_CPHY_x4 -m 0x0100 0x0000 0x0000 0x0000
  1. I created the JSON file (named rig_test.json) based on the two links above:
	"platformConfigs": [
			"name": "MIXED_CAMERA_CPHY_x4",
			"description": "MIXED CAMERA_4 lane CPHY mode",
			"enableMasks": ["0x0100 0x0000 0x0000 0x0000"],
			"deviceBlocks": [
					"passiveMode": false,
					"csiPort" : "csi-ab",
					"phyMode": "cphy",
					"simulatorMode": false,
					"groupInitProg": true,
					"homogenousModules": false,
					"deserializer": "MAX96712",
					"cameraModules": [
							"linkIndex": 0,
							"name": "F008A120RM0AV2",
							"sensors": [
								"name": "AR0820",
								"id": 0
  1. I run nvsipl_camera with this JSON:
sudo ./nvsipl_camera -t rig_test.json -c MIXED_CAMERA_CPHY_x4 -m 0x0100 0x0000 0x0000 0x0000 -v 4
  1. I get nvsipl_camera: ERROR: Master SetPlatformConfig failed. status: 1 - It seems like the numCameraModules = 0 for some reason, I cannot find out how to get it to parse the cameraModules correctly. This is the log output below:
Platform configuration name: MIXED_CAMERA_CPHY_x4
Platform configuration file: ./rig_test.json
Verbosity level: 4
Raw output: disabled
ISP0 output: enabled
ISP1 output: enabled
ISP2 output: enabled
Disabled FPS logging
Disabled Metadata logging
Disabled automatic recovery
Disabled NvSci
Disabled profiling
Disabled ISP Statistics settings override
Subframe : disabled
Disabled Passive mode
Authentication: controlled by Platform Config
Disabled retrieving/displaying NITO Metadata
nvsipl_camera: Setting up signal handler
libnvsipl_query.so: CNvMQuery.cpp : 272: ParseJsonFile: CNvMQuery::ParseJsonFile reading file ./rig_test.json
libnvsipl_query.so: CNvMDeviceBlockInfo.cpp : 131: ParseJson: deserializer on this platform MAX96712
libnvsipl_query.so: CNvMSensorInfo.cpp : 218: ParseJson: Updated AR0820
libnvsipl_query.so: CNvMCameraModuleInfo.cpp : 247: ParseJson: Parsed F008A120RM0AV2
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 129: ApplyMask: block:0 enabled
nvsipl_camera: Getting platform configuration for MIXED_CAMERA_CPHY_x4
nvsipl_camera: Setting link masks
nvsipl_camera: Creating camera master
nvsipl_camera: Setting up master
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 328: GetInstance: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 331: GetInstance: Exiting
nvsipl_camera: Creating consumers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 580: SetPlatformCfg: Entering DevBlkQueues variant
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 529: SetPlatformCfg: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 359: LogPlatformCfg: ---------- START PLATFORM CONFIGURATION ----------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 360: LogPlatformCfg: platform:
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 361: LogPlatformCfg: platformConfig: MIXED_CAMERA_CPHY_x4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 362: LogPlatformCfg: description: MIXED CAMERA_4 lane CPHY mode
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 363: LogPlatformCfg: numDeviceBlocks: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 366: LogPlatformCfg: DeviceBlockInfo deviceBlockList[0]
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 367: LogPlatformCfg:  csiPort: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 368: LogPlatformCfg:  phyMode: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 369: LogPlatformCfg:  i2cDevice: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 371: LogPlatformCfg:  DeserInfo deserInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 372: LogPlatformCfg:          name: MAX96712
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 373: LogPlatformCfg:          description: Maxim 96712 Aggregator
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 374: LogPlatformCfg:          i2cAddress: 0x29
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 376: LogPlatformCfg:          errGpios.size(): 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 378: LogPlatformCfg:          errGpios[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 378: LogPlatformCfg:          errGpios[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 380: LogPlatformCfg:          useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 381: LogPlatformCfg:          resetAll: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 382: LogPlatformCfg:  numCameraModules: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 455: LogPlatformCfg:  desI2CPort: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 456: LogPlatformCfg:  desTxPort: 4294967295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 457: LogPlatformCfg:  pwrPort: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 459: LogPlatformCfg:  dphyRate[0]: 2500000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 460: LogPlatformCfg:  cphyRate[0]: 2000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 459: LogPlatformCfg:  dphyRate[1]: 2500000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 460: LogPlatformCfg:  cphyRate[1]: 2000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 462: LogPlatformCfg:  isPassiveModeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 463: LogPlatformCfg:  isGroupInitProg: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 465: LogPlatformCfg:  gpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 469: LogPlatformCfg:  isPwrCtrlDisabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 471: LogPlatformCfg:  longCables[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 471: LogPlatformCfg:  longCables[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 471: LogPlatformCfg:  longCables[2]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 471: LogPlatformCfg:  longCables[3]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 473: LogPlatformCfg:  resetAll: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 475: LogPlatformCfg: ----------- END PLATFORM CONFIGURATION -----------
Do you have any info that could help? Am I writing the JSON file incorrectly? Thank you.
To further investigate the problem, could you please run the working command at the same verbosity level and compare the outputs? This might provide additional insights into the root cause.
Here’s the command for reference:
sudo ./nvsipl_camera -c F008A120RM0AV2_CPHY_x4 -m 0x0100 0x0000 0x0000 0x0000 -v 4
Sure, here’s the output:
Platform configuration name: F008A120RM0AV2_CPHY_x4
Verbosity level: 4
Disabled NvSci
Disabled profiling
Subframe : disabled
nvsipl_camera: Getting platform configuration for F008A120RM0AV2_CPHY_x4
libnvsipl_query.so: CNvMPlatformCfgInfo.cpp : 138: ApplyMask: module:2 enabled
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 361: LogPlatformCfg: platformConfig: F008A120RM0AV2_CPHY_x4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 362: LogPlatformCfg: description: F008A120RM0A 24BIT RGGB module in 4 lane CPHY mode
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 382: LogPlatformCfg:  numCameraModules: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 385: LogPlatformCfg:  CameraModuleInfo cameraModuleInfoList[0]
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 386: LogPlatformCfg:          name: F008A120RM0AV2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 387: LogPlatformCfg:          description: Entron F008A120RM0A module - 120-deg FOV, 24-bit capture, MIPI-AR0820, MAX9295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 388: LogPlatformCfg:          linkIndex: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 389: LogPlatformCfg:  isSimulatorModeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 391: LogPlatformCfg:          SerInfo serInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 392: LogPlatformCfg:                  name: MAX9295
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 393: LogPlatformCfg:                  description: Maxim 9295 Serializer
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 394: LogPlatformCfg:                  i2cAddress: 0x62
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 395: LogPlatformCfg:                  longCable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 397: LogPlatformCfg:                  errGpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 401: LogPlatformCfg:                  useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 403: LogPlatformCfg:                  serdesGPIOPinMappings.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 410: LogPlatformCfg:          isEEPROMSupported: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 413: LogPlatformCfg:          EEPROMInfo eepromInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 414: LogPlatformCfg:                  name: N24C64
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 415: LogPlatformCfg:                  description: N24C64 EEPROM
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 416: LogPlatformCfg:                  i2cAddress: 0x54
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 417: LogPlatformCfg:                  useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 420: LogPlatformCfg:          SensorInfo sensorInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 421: LogPlatformCfg:                  id: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 422: LogPlatformCfg:                  name: AR0820
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 423: LogPlatformCfg:                  description: OnSemi AR0820 Sensor
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 424: LogPlatformCfg:                  i2cAddress: 0x10
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 426: LogPlatformCfg:          SensorInfo::VirtualChannelInfo vcInfo
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 427: LogPlatformCfg:                  cfa: 35
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 428: LogPlatformCfg:                  embeddedTopLines: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 429: LogPlatformCfg:                  embeddedBottomLines: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 430: LogPlatformCfg:                  inputFormat: 8
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 431: LogPlatformCfg:                  resolution.width: 3848
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 432: LogPlatformCfg:                  resolution.height: 2168
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 433: LogPlatformCfg:                  fps: 30.000000
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 434: LogPlatformCfg:                  isEmbeddedDataTypeEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 435: LogPlatformCfg:                  isTriggerModeEnabled: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 437: LogPlatformCfg:          errGpios.size(): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 441: LogPlatformCfg:          useCDIv2API: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 442: LogPlatformCfg:          isTPGEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 443: LogPlatformCfg:          patternMode: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 444: LogPlatformCfg:          isAuthEnabled: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 180: SetConfig: Create device block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 188: SetConfig: Set device block config
Main: CDevBlkDriverLibs.cpp: 118: FindFirstLibPath: Checking "/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 118: FindFirstLibPath: Checking "/lib/nvsipl_drv" for drivers
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CDevBlkDriverLibs.cpp: 130: FindFirstLibPath: Loading library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623c.so"
Main: CDevBlkDriverLibs.cpp: 118: FindFirstLibPath: Checking "/usr/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 118: FindFirstLibPath: Checking "/usr/lib/nvsipl_drv" for drivers
Main: CDevBlkDriverLibs.cpp: 118: FindFirstLibPath: Checking "/usr/local/driveworks/lib" for drivers
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CDevBlkDriverLibs.cpp: 211: LoadDriversLibraries: Opening driver library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623c.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMDeserializerFactory.cpp: 60: LoadDeserializerDriver: Loading Deserializer driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623c.so"
Main: CDevBlkDriverLibs.cpp: 34: CDevBlkDriverLibs: Driver libraries are already loaded
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S1RU3120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S1RU3070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S1RU3070HB20_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S1RU3030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU1030NB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU3070HB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU3070HB30_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU3120NB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU3120HB30" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU2030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU4070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU4070HB20_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU4120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S2RU4120HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4120NC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4120HC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4070HC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4070HC00_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU2030NC00" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4120NC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4120HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4070HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU4070HC10_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU3030NC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728S3RU3030HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU4120NC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU4120HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU4070HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU4070HC10_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU3030NC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM728SARU3030HC10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "MAX96712TPG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "MAX96712TPG_YUV_8" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_max96712tpg.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "IMX728_FPDLINK_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728_fpdlink.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S2RU2120NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S2RU1070NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S2RU2030NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S3RU2120NB2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S3RU1070NB2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM728S3RU2030NB2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728s.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM623S3RU1197NB1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0SIM623S4RU1197NB2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623s.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "SIM_V1SIM728S1RU3030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "DS90UB971TPG" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ds90ub9724_971tpg.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S3RU3200NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S3RU3200NB20_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S4RU5195NB3" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S4RU5195NB3_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V0SIM623S4RU5195NB3" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S5RU5195NC0" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S5RU5195NC0_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S5RU6195NC1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623S5RU6195NC1_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623SARU6195NC1" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V1SIM623SARU6195NC1_R" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "SIM_V1SIM623S3RU3200NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623vb2_sim.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0OOX05B1CHU1170NA10_LL" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0OOX05B1CHU1170NB10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "R0OOX05B1CHU1170NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ox05b1s.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "AR0820C120FOV_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "AR0820C70FOV_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "VC0820C120R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "VC0820C070R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "VC0820C030R24" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820_cust1.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "I0OO23111CML1050NB10" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "I0OO23111CML1050NB10_30FPS" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "I0OO23111CML1050NB10_E" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-55H_E" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311_c.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V623S2-195V1-SVS" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-60H" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "LI-OV2311-VCSEL-GMSL2-60H_L" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ov2311.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_RCCB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RCCB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_RCCB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030BM0A_RGGB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120BM0A_RGGB_BINNING" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A070BM0A_24BIT_RGGB" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A030RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A070RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120RM0A" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120RM0A_SIDE" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "F008A120RM0AV2" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_ar0820.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "C2SIM728S2RU1120NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "C2SIM728S2RU1070HB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "C2SIM728S2RU1070NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "C2SIM728S2RU1030NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728c.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-120V0" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-120V1-FWC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-120V1-SCF" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-070V1-SCR" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-030V1-FTC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "V728S1-030V1-RC" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx728.so"
Main: CNvMCameraModuleFactory.cpp: 129: LoadDriver: Loading CameraModule driver from library "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623c.so"
Main: CNvMCameraModuleFactory.cpp: 175: LoadDriver: Mapping module name "C2SIM623S2RU1195NB20" to module driver "/lib/nvsipl_drv/libnvsipl_devblk_drv_imx623c.so"
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 569: SetPlatformCfg: Exiting
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 608: SetPlatformCfg: Exiting DevBlkQueues variant
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 678: SetPipelineCfg: Entering for pipeline: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 624: LogPipelineCfg: -------- START PIPELINE   2 CONFIGURATION --------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 625: LogPipelineCfg: captureOutputRequested: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 626: LogPipelineCfg: isp0OutputRequested: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 627: LogPipelineCfg: isp1OutputRequested: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 628: LogPipelineCfg: isp2OutputRequested: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 630: LogPipelineCfg: NvSIPLDownscaleCropCfg downscaleCropCfg
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 631: LogPipelineCfg:  ispInputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 635: LogPipelineCfg:  isp0OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 639: LogPipelineCfg:  isp1OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 643: LogPipelineCfg:  isp2OutputCropEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 647: LogPipelineCfg:  isp0DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 652: LogPipelineCfg:  isp1DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 657: LogPipelineCfg:  isp2DownscaleEnable: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 663: LogPipelineCfg: NvSIPLIspStatsOverrideSetting statsOverrideSettings
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 664: LogPipelineCfg:  enableHistStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 665: LogPipelineCfg:  enableHistStatsOverride[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 666: LogPipelineCfg:  enableLacStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 667: LogPipelineCfg:  enableLacStatsOverride[1]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 668: LogPipelineCfg:  enableBpStatsOverride[0]: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 669: LogPipelineCfg: (imageGroupWriter != nullptr): 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 670: LogPipelineCfg: --------- END PIPELINE   2 CONFIGURATION ---------
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 59: CapturePreInit: Creating FuSa Capture block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 38: ThreadCreate: Creating thread:SIPL_CDI_2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMBufferPool.hpp: 112: Init: Creating buffer pool with 2 buffers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 137: m_FuncStatic: Thread created
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 92: ISPPreInit: Creating FuSa ISP block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 122: ThreadSetName: Setting thread name:SIPL_CDI_2
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 158: m_Func: Running thread:SIPL_CDI_2
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 161: m_Func: Calling ThreadFunc for thread:SIPL_CDI_2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 840: SetPipelineCfg: Exiting for pipeline: 2
nvsipl_camera: Creating consumer for output:1 of sensor:2
nvsipl_camera: Consumer initialization for output:1 of sensor:2
nvsipl_camera: Creating consumer for output:2 of sensor:2
nvsipl_camera: Consumer initialization for output:2 of sensor:2
nvsipl_camera: Creating consumer for output:3 of sensor:2
nvsipl_camera: Consumer initialization for output:3 of sensor:2
nvsipl_camera: GetPtpDeviceNode() selected /dev/ptp2
nvsipl_camera: Using PTP clock
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2465: GetImageAttributes: Entering for pipeline: 2 and output type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2549: GetImageAttributes: Exiting for pipeline: 2 and output type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2465: GetImageAttributes: Entering for pipeline: 2 and output type: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1294: ContainsLowLevelAttributes: NvSciBuf attributes not set.
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1347: ContainsHighLevelAttributes: NvSciBuf attributes not set.
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2549: GetImageAttributes: Exiting for pipeline: 2 and output type: 1
Pipeline: 2 ISP Output: 0 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2465: GetImageAttributes: Entering for pipeline: 2 and output type: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2549: GetImageAttributes: Exiting for pipeline: 2 and output type: 2
Pipeline: 2 ISP Output: 1 is using YUV 420 SEMI-PLANAR UINT8 BL REC_709ER
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2465: GetImageAttributes: Entering for pipeline: 2 and output type: 3
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 2549: GetImageAttributes: Exiting for pipeline: 2 and output type: 3
Pipeline: 2 ISP Output: 2 is using RGBA PACKED FLOAT16 PL SENSOR_RGBA
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3770: FillNvSciSyncAttrList: Entering for pipeline: 2, output type: 1, and client type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3836: FillNvSciSyncAttrList: Exiting for pipeline: 2, output type: 1, and client type: 0
nvsipl_camera: Initializing master interface
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1117: Init: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 264: Init: Initializing worker thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 38: ThreadCreate: Creating thread:DEVBLK_WORKER_0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 270: Init: Initialized worker thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 227: WorkersDoAction: All worker threads starting action:1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 122: ThreadSetName: Setting thread name:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 158: m_Func: Running thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 161: m_Func: Calling ThreadFunc for thread:DEVBLK_WORKER_0
DEVBLK_WORKER_0: CNvMMax20087Factory.cpp: 41: operator(): CNvMMax20087 Driver Factory creating new adapter for CDI root dev 0xffff9c000b60
DEVBLK_WORKER_0: CNvMMax20087SyncAdapter.cpp: 27: SetConfig: Configure Sync Adapter
DEVBLK_WORKER_0: CNvMMax20087SyncAdapter.cpp: 67: CreatePowerDevice: Create Sync Adapter Driver
DEVBLK_WORKER_0: CNvMMax96712.cpp: 244: DoInit: Check deserializer is present
MAX96712: Revision 5 detected
DEVBLK_WORKER_0: CNvMMax96712.cpp: 251: DoInit: Set deserializer defaults
MAX96712 Link 2: PHY optimization was enabled
DEVBLK_WORKER_0: CNvMMax96712.cpp: 259: DoInit: Get deserializer revision
DEVBLK_WORKER_0: CNvMMax96712.cpp: 271: DoInit: Set MIPI output mode
DEVBLK_WORKER_0: CNvMMax96712.cpp: 318: EnableLinks: Enabling links
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 174: Init: Initializing link 2
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 67: DumpLinkParams: Link parameters
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 68: DumpLinkParams: Link Index: 2
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 69: DumpLinkParams: Broadcast serializer addr: 0x62
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 70: DumpLinkParams: Serializer addr: 0x63
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 73: DumpLinkParams:
Broadcast sensor addr: 0x10
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 74: DumpLinkParams: Sensor addr: 0x11
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 75: DumpLinkParams: VCID: 2
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 76: DumpLinkParams: Embedded data type: false
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 77: DumpLinkParams: Trigger mode sync: true
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 78: DumpLinkParams: Frame rate: 30.00 fps
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 81: DumpLinkParams:
Broadcast EEPROM addr: 0x54
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 84: DumpLinkParams: EEPROM addr: 0x55
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 86: DumpLinkParams: Simulator mode: 0
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 87: DumpLinkParams: Passive mode: 0
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 210: Init: Check config link lock
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 221: Init: Setup address translations
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 97: SetupAddressTranslations: Check broadcast serializer is present
MAX9295: Revision 8 detected!
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 105: SetupAddressTranslations: Set the default setting in the serializer
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 117: SetupAddressTranslations: Translate image sensor device addr 11 to 10
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 132: SetupAddressTranslations: Translate eeprom device addr 55 to 54
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 145: SetupAddressTranslations: Set unique address
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 279: Init: CDI_WRITE_PARAM_CMD_MAX9295_SET_FSYNC_GPIO
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 343: Init: CDI_WRITE_PARAM_CMD_MAX9295_CONFIG_PHY
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 365: Init: CDI_WRITE_PARAM_CMD_MAX9295_CONFIG_VIDEO_PIPELINES
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 394: Init: Initializing link 2
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 399: Init: Set Fsync
DEVBLK_WORKER_0: CNvMTransportLink_Max96712_9295.cpp: 404: Init: Set FSYNC mode
DEVBLK_WORKER_0: CNvMMAX96712_9295_AR0820.cpp: 66: DetectModule: Check SENSOR is present
Sensor AR0820 GRBG Rev 2.1 detected!
DEVBLK_WORKER_0: CNvMMAX96712_9295_AR0820.cpp: 150: InitModule: Set defaults in CNvMSensor::Init
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 253: WorkersDoAction: All worker threads finished action:1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 287: Init: Initializing interrupt handler thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 294: Init: Initialized interrupt handler thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 297: Init: Initializing error monitor thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 38: ThreadCreate: Creating thread:DB0_INTRMON
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 304: Init: Initialized error monitor thread for block:0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 317: Init: Pulse error monitoring is not supported, skipping
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 235: CaptureInit: Initializing FuSa Capture block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 122: ThreadSetName: Setting thread name:DB0_INTRMON
DB0_INTRMON: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 158: m_Func: Running thread:DB0_INTRMON
DB0_INTRMON: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 161: m_Func: Calling ThreadFunc for thread:DB0_INTRMON
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 259: ISPCDIInit: Creating CDI block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 265: ISPCDIInit: Creating ISP block
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 38: ThreadCreate: Creating thread:SIPL_VI_ISP_2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 1180: Init: Exiting
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 122: ThreadSetName: Setting thread name:SIPL_VI_ISP_2
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 158: m_Func: Running thread:SIPL_VI_ISP_2
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 161: m_Func: Calling ThreadFunc for thread:SIPL_VI_ISP_2
nvsipl_camera: Custom interface found
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3674: RegisterImages: Entering for pipeline: 2 and output type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 350: RegisterImageGroupBuffers: Creating capture buffer pool of size: 6
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMBufferPool.hpp: 112: Init: Creating buffer pool with 6 buffers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 44: OnBufferRelease: Wake up thread
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThrRegisterImages: Exiting for pipeline: nc for thread:SIPL_VI_ISP_2
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThrRegisterImages: Exiting for pipeline: 2 and output type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3674: RegisterImages: Entering for pipeline: 2 and output type: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 459: RegisterImageBuffer: Creating ISP[0] buffer pool of size: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMBufferPool.hpp: 112: Init: Creating buffer pool with 4 buffers
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3756: RegisterImages: Exiting for pipeline: 2 and output type: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3674: RegisterImages: Entering for pipeline: 2 and output type: 2
SP_2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 459: RegisterImageBuffer: Creating ISP[1] buffer pool of size: 4
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3756: RegisterImages: Exiting for pipeline: 2 and output type: 2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3674: RegisterImages: Entering for pipeline: 2 and output type: 3
SP_2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 459: RegisterImageBuffer: Creating ISP[2] buffer pool of size: 4
ain: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3756: RegisterImages: Exiting for pipeline: 2 and output type: 3
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3847: RegisterNvSciSyncObj: Entering for pipeline: 2, output type: 1, and sync object type: 1
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3847: RegisterNvSciSyncObj: Entering for pipeline: 2, output type: 1, anMain: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3913: RegisterNvSciSyncObj: Exiting for pipeline: 2, output type: 1, and sync object type: 1
nvsipl_camera: Opened NITO file for module "F008A120RM0AV2", file name: "/usr/share/camera/F008A120RM0AV2.nito"
nvsipl_camera: data from NITO file loaded for module "F008A120RM0AV2"
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 851: RegisterAutoControlPlugin: Entering for pipeline: 2 and type: 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFusaISPBlock.cpp: 1046: Reset: Calling FusISP reset
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFusaISPBlock.cpp: 964: ProcessALG: Calling FusISP Process ALG
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 112: SetSensorControl: Wake up threadSIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/utils/CNvMThread.cpp: 161: m_Func: Calling ThreadFunc for thread:SIPL_CDI_2
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 198: PrintSensorControl: i: 0 exposureTime: 0.029961 sensorGain: 5.800000
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 198: PrintSensorControl: i: 1 exposureTime: 0.001507 sensorGain: 5.800000
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 198: PrintSensorControl: i: 2 exposureTime: 0.000125 sensorGain: 5.800000
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 198: PrintSensorControl: i: 3 exposureTime: 0.000009 sensorGain: 5.800000
SIPL_CDI_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 203: PrintSensorControl: illuminationControl: valid = 0, enable = 0
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 923: RegisterAutoControlPlugin: Exiting for pipeline: 2 and type: 0
nvsipl_camera: Starting master
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3922: Start: Entering
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvMCDIBlock.cpp: 134: Start: Start the thread
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 796: StartProcessing: Start the thread
nvsipl_camera: Pipeline: 2, NOTIF_INFO_CDI_PROCESSING_DONE
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 227: WorkersDoAction: All worker threads starting action:2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMDeviceBlockMgr.cpp: 253: WorkersDoAction: All worker threads finished action:2
Main: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/CNvMCamera.cpp: 3960: Start: Exiting
Enter 'les' followed by sensor ID to enable LED
Enter 'lds' followed by sensor ID to disable LED
Enter 'dl' followed by sensor ID to disable the link
Enter 'el' followed by sensor ID to enable the link without module reset
Enter 'elr' followed by sensor ID to enable the link with module reset
Enter 'cm' to check the module availability
Enter 'q' to quit the application
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 185: sParseTopEmbData: Parsed Exposure time[0]:0.029961
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 188: sParseTopEmbData: Parsed Sensor Gain[0]: 5.800000
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 185: sParseTopEmbData: Parsed Exposure time[1]:0.001507
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 188: sParseTopEmbData: Parsed Sensor Gain[1]: 5.800000
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 185: sParseTopEmbData: Parsed Exposure time[2]:0.000125
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 188: sParseTopEmbData: Parsed Sensor Gain[2]: 5.800000
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 185: sParseTopEmbData: Parsed Exposure time[3]:0.000009
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFEmbeddedDataParser.cpp: 188: sParseTopEmbData: Parsed Sensor Gain[3]: 5.800000
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFusaISPBlock.cpp: 850: ProcessISP: Calling FusISP process ISP
nvsipl_camera: Pipeline: 2, NOTIF_INFO_ICP_PROCESSING_DONE
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/blocks/CNvFusaISPBlock.cpp: 964: ProcessALG: Calling FusISP Process ALG
nvsipl_camera: EmdData.embeddedBufTopSize: 0 EmdData.embeddedBufBottomSize: 0
FrameQueue: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 44: OnBufferRelease: Wake up thread
SIPL_VI_ISP_2: /dvs/git/dirty/git-master_modular/camera/fusa/sipl/src/core/pipelineMgr/spmgr/pipeline/CNvFSensorPipeline.cpp: 44: OnBufferRelease: Wake up thread
P Process ALG
It also keeps sending sensor gain and exposure until I press CTL+C too. Note that this output shows the full config and sensor + pipeline setup whereas the JSON command doesnt make it past the config reading. Thanks!
I’m considering whether the absence of the following output might be the cause. Can you please verify the mask used in the executed command?
I got it working - I needed to change linkIndex to match the link the camera was connected to.
In the mask: 0x0100 0x0000 0x0000 0x0000 I had to change linkIndex to 2 (from 0) and then it worked correctly.
Thanks for the help!
Great to hear that you got it working!
