I am trying to use jetson Xavier NX
I need to setup /dev/ttyTHS0 100000 bit/s baudrate and 8E2 mode to make sure sbus receiver could work, but i dont know how to do that.
hello victorj171 ,
may I know what’s your hardware pin connections,
Xavier series by default used combined-uart, and its baudrate settings is configured as 115200/8n1.
please also share kernel logs with… $ dmesg | grep THS to check which serial port you’re using,
thanks
hi JerryChang,
my hardware pin is J12 Expansion Header Pin #10 UART1_RXD
$dmesg | grep THS
[1.486030] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq =47,base_baud =0) is a TEGRA_UART
hello victorj171,
there’s hardware to convert the signal from UART to SBUS.
please see-also https://www.aliexpress.com/item/1005001903787023.html, and https://www.aliexpress.com/item/1005003157011491.html
on Xavier NX side, you may see-also [Jetson Xavier NX] UART Tune - #15 by JerryChang to disable combined uart.
