I designed a customer tk1 board.
On the board I use ADV7281M to covert pal vedio source to mipi csi ,and
the output connect to the mipi csi(csi_e x1 width).
After reading V4L2 User Guide for Jetson TK1,I still don’t understand how to get accesse to the mipi csi of TK1. I recompiled the kernel but I can’t find /dev/video to user space.
The output format is YCrCb(prabably also called YUV) 4:2:2 ,and the resolution is 720*576. 25 frames/s
I don’t know how to enable the soc camera,but I test the 1.2V power supply of CSI&DSI,the voltage is correct.
The configuration of the board is the same as the jetson-tk1 board.I designed to use the 1x lane CSI E,Which is connected to camera 2# in the design guide.
I tried to added driver for my device but it seemed that I had failed.
Now I configged the Chip ADV7281M via i2c1 to generate a fixxed frame , and I want to make the frame shown on TK1
From your description, what I know is that you have a csi port connecting to TK1.
No other additional information is available. I don’t know what work you have done.
Such as,
What is the output format/resolution? Have you added sensor driver for your device? Have you enable the soc camera?
Have you configured the csi lane/port from board config?
Thanks for your help.
The output format is YCrCb(prabably also called YUV) 4:2:2 ,and the resolution is 720*576, 25 frames/s.
Now I configged the Chip ADV7281M via i2c1 to generate a fixxed frame , and I want to make the frame shown on TK1.
