How to transfer bbox3d to ros2 topic with id?
Isaac Sim Version
[Y ] 4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
[Y] 1.2
1.1
1.0
Operating System
[Y] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
QUESTION********
① question1: I really dont knwo how to apply id to bbox3d defined in issac by replicator
header:
stamp:
sec: 0
nanosec: 0
frame_id: ‘’
results:
  • hypothesis:
    class_id: ‘0’
    score: 1.0
    pose:
    pose:
    position:
    x: 0.0
    y: 0.0
    z: 0.0
    orientation:
    x: 0.0
    y: 0.0
    z: 0.0
    w: 1.0
    covariance:
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
    • 0.0
      bbox:
      center:
      position:
      x: 5.599999904632568
      y: -0.5
      z: 0.0
      orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
      size:
      x: 1.019092082977295
      y: 1.019092082977295
      z: 1.019092082977295
header:
stamp:
sec: 370
nanosec: 16685964
frame_id: sim_camera
detections:
  • header:
    stamp:
    sec: 0
    nanosec: 0
    frame_id: ‘’
    results:
    • hypothesis:
      class_id: ‘0’
      score: 1.0
      pose:
      pose:
      position:
      x: 0.0
      y: 0.0
      z: 0.0
      orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
      covariance:
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
        bbox:
        center:
        position:
        y: 3.5
        z: 0.0
        orientation:
        x: 0.0
        y: 0.0
        z: 0.0
        w: 1.0
        size:
  • header:
    stamp:
    sec: 0
    nanosec: 0
    frame_id: ‘’
    results:
    • hypothesis:
      class_id: ‘0’
      score: 1.0
      pose:
      pose:
      position:
      x: 0.0
      y: 0.0
      z: 0.0
      orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
      covariance:
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
      • 0.0
        bbox:
        center:
        position:
        y: -0.5
        z: 0.0
        orientation:
        x: 0.0
        y: 0.0
        z: 0.0
        w: 1.0
        size:
② question2: when i am using the office scene, I use semantics schema editor to apply semantic data to prims, their prefix include SM and BP,but SM(almost floor) will be taged, BP(almost objects) wont be taged,
and it showed that the BP(or some SM) mesh seems be locked, it is grey colour
is there any body can help me, please!!!
hello!!!
Hey @3478428491 Sorry for my late reply.
For the first question, you can refer to the doc ROS2 Camera Helper — Isaac Sim. If you enable “Enable Semantic Labels” or set “Semantic Labels Topic Name”, it should automatically apply id.
For the second question, could you please provide the prim path that you want to apply semantic data? We can try to replicate it on our end. Thanks
Hello, Thanks for your rely.
For the second question, Wewant to set semantic data on the prim which have real size on various objects, we only can set it on the floor now, as the image shows.
Hey @3478428491 are you following this tutorial: Adding Semantics to a Scene — Omniverse Extensions
Thank you for your reply
I attempted to annotate them again, but it still didn’t work. Then I tried annotating it individually, and a message indicated that the object is locked.
2025-03-21 09:12:00 [Error] [omni.ui.python] Error in ‘pxrInternal_v0_22__pxrReserved__::UsdStage::_ValidateEditPrim’ at line 1330 in file /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp : ‘Cannot create prim spec at path </Environment/office/SM_ColumnA28/SM_ColumnA>; authoring to an instance proxy is not allowed.’
@3478428491 , try collecting the stage and then setting the mesh. The env has been loaded as a reference and it seems that it cannot change the parent mesh properties.
Thank you! This has been incredibly helpful.
