I have a developer kit, and I weld an emmc on it recently.But it can’t find emmc.
When use ‘fdisk -l’ command, it shows that there only :
ram0 - ram 15, oop0 mtdblock0, mmcblk0(SD Card), zram0 - zram3
Hi 1058089431,
There is no eMMC on current devkit, and you could use a large size SD card.
Please refer to Getting Started With Jetson Nano Developer Kit
I know, so I weld one.
Hi 1058089431,
Which document you refer to to weld the eMMC on devkit?
https://developer.nvidia.com/embedded/learn/get-started-jetson-nano-devkit#setup
In this picture. There is obviously an EMMC near microSD。
And Jetson_Nano_Product_Design_Guide page36 says that
Jetson Nano uses one SDMMC interface for on-module eMMC (SDMMC4 on Tegra) and brings one to the connector pins for SD Card or SDIO use.
Did I get it wrong? I think it means emmc interface is not the same path with microSD.
In device tree(tegra210-3448-000x-3449-0000-xx.dtb), sdhci@700b0600 is for mmc. sdhci@700b0000 is for microSD.
您好,您知道如何把nano套件系统转移到定制板上吗
Hi junxing.liang,
Please write your question in English. I think I already told this to you before.
