I need to use 4 different cameras as well as the I/O pins for a robotics project, and I was planning to use the Jetson Xavier NX, but the dev kit only has 2 CSI slots despite the module itself having 6 connections. Is there a solution that anyone else has found for this issue.
You may need design customize carrier board or get customize carrier board to support 2 above cameras support for NX. Please check camera modules from our partners:
How do I go about designing a custom carrier board?
There are related docs in DLC for your custom design, or you can check with vendors in ecosystem for that. https://developer.nvidia.com/embedded/community/ecosystem
