I want to set up multiple cameras and save incoming data from each of them in separate files (.h264 or raw) simultaneously. In other words I want to do what ./sample_gmsl_camera --write-file=… does but for multiple cameras. As far as I know ./sample_camera_multiple_gmsl doesn’t have that parameter.
Furthermore I also tried nvmipp_capture_encode like:
./nvmipp_capture_encode -cf e2379a_c01.conf -c dvp-ar0231-raw12-1920x1208-ab -e 0 -t 0 -o output_AB.h264 -d 0 --aggregate 4 --vc_enable --nvplugin but display throws an error.
Afterwards I also add -w 1 as suggested in this issue https://devtalk.nvidia.com/default/topic/1010018/failed-to-run-nvmimg_cap-sample/ but an image is shown in the whole screen and the drive freezes. I can’t playback the data as well.
Is there a better solution?
