Hi NV,
I have tried to use ./sample_camera_multiple_gmsl to capture multiple cameras’ data. However, can I record multiple cameras’ data with the sdk?
Hi NV,
Dear songwen.huand,
Could you check our recording tool(/usr/local/driveworks/tools/capture/) for your topic.
Hi SivaRamaKrishna,
I don’t think ./recorder can record h264 or raw data. Can you specify which tool to use?
Dear songwen.huang,
Could you please refer to “Recorder-Specific Parameters” in /usr/local/driveworks-2.0/doc/nvsdk_html/dwx_config_ref.html and usr/local/driveworks-2.0/doc/nvsdk_html/rigconfiguration_usecase0.html on your host PC?
DW recording tool support h264 and raw data format like below.
Encoding Format format output-format
RAW raw raw
LRAW lraw raw+yuv
H264 h264 yuv
H265 h265 yuv
MP4 mp4 yuv
Dear songwen.huand,
You can use any recording tool. You need to select right values for format and output format parameters in the input .json file to the recorder.
Please check Tools-> Recording tools → Configuration Reference section in DW documentation
External Media
Let us know if you have any issues.
Hi SivaRamaKrishna,
Thanks your help. The issue was solved.
