I’d like to make GPIO02 an output and change the value. How do I do this with JetPack 6.0?
Hi @bike_works
Here is information about how to control GPIOs on JP6:
Regards,
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
@enrique.ramirez when I do gpioset -c 1 12=1
it works but just hangs. I don’t see the mode-wait option.
maybe I should be using a python library?
Did you install the right package?
sudo apt install gpiod
Also, make sure you use double dashes --
instead of -
I’m using scarthgap in yocto land. Wonder if I just have a different version of gpioset. I see v2.1.2
