i´ve a Server HP DL380p Gen8 with a NVidia Grid K2 Card. I´ve installed XenServer 6.2 with all patches an the latest BIOS.
I´ve assigned to a VM a vGPU trough the XenCenter GUI. When i try to start the VM i get following error:
Starting VM ‘VMNAME’ - Internal error: xenopsd internal error: Unix.Unix_error(20, "open", "/sys/bus/pci/drivers/nvidia/bind")
I´ve launched following commands on the XenServer Console:
lsmod | grep nvidia -> no output
I have exactly the same server and the same problem with the NVIDIA GRID K1.
Problem is I can not find the MMIO above 4G option in the BIOS, there is not such option in there.
I’d suggest checking with HP to see if there’s an earlier (or later) BIOS that returns this setting.
Also, be aware that the next release of XenServer, currently in tech preview codename Creedence, eliminates the need for this setting as it moves to a 64 Bit DOM 0 session.
Did you find a solutions to fix the Bios setting on the HP DL380p Gen8 Server.
I want to disabled the MMIO above 4G option in the BIOS. Is it possible on this machine?
