krakc
August 13, 2009, 9:38pm
1
hi
this is my pc
board asrock p4i45GV
pentium IV 2.4GHZ
RAM 1.3GB
nVidia GeForce FX5200
i will be to explain my problem
i use ubuntu ultimate edition 2.3 based in ubuntu 9.04, kernel 2.6.28-14-generic
i start my pc → F2 → enter to Bios → Primary Graphics Adapter = Internal VGA
enter to ubuntu very good → i use this guide by install the drivers [url=“http://forums.nvidia.com/index.php?showtopic=99513 ”]http://forums.nvidia.com/index.php?showtopic=99513[/url]
reboot my pc → enter again to ubuntu → in terminal writte → sudo nvidia-xconfig → restart again my pc
enter to Bios → primary Graphics Adapter = AGI
this is my problem:
When the screen with the loading bar, it is not loaded and then appear a series of diagonal lines and the system dont load.
If when appear the screen loading Ubuntu, press Alt + F1, I can last several errors and last says:
tty1 respawning too fast, stopped
then i try enter in recovery mode, but the system dont load, and i can see this error:
/bin/sh: 6: /sbin/sulogin: invalid argument
init: rcS-sulogin main process (xxxx) terminated with status 2
then i enter to bios and change again my PGA to Internal VGA and the system load normal.
please help me, i need use my card GeForce FX5200
thanks
hi
this is my pc
pentium IV 2.4GHZ
RAM 1.3GB
enter to ubuntu very good → i use this guide by install the drivers http://forums.nvidia.com/index.php?showtopic=99513
this is my problem:
thanks
Do you want to use you card with CUDA? Your card isn’t a CUDA enabled device.
hi
this is my pc
pentium IV 2.4GHZ
RAM 1.3GB
this is my problem:
thanks
I found the answer in the Ubuntu Foruns
Ubuntu Forums
posted by mojo6911
I figured it out. Since you can’t disable the onboard video, it conflicts with any PCI video card with linux. This is what I did:
Remove PCI card and install Ubuntu using on board video.
After it is installed,
sudo nano /etc/modprobe.d/blacklist
add:
blacklist intel_agp
blacklist agpgart
Shutdown and reinstall the PCI card and boot up and it should work.
It basicly disables your onboard vidio (in this case intel) by blacklisting it (make linux ignore it). I did the same on my windows xp side by disabling the onboard video card using the the device manager.
I hope this helps
I follow the steps and it works.
