I cannot Run FrankaDeformable in livestream
I trained the FrankaDeformable task. And I got pth file, but when I tried to run, It causes error.
this is the code that I entered.
PYTHON_PATH scripts/rlgames_train.py task=FrankaDeformable test=True checkpoint=runs/FrankaDeformable/nn/last_FrankaDeformable_ep_6000_rew__176.834_.pth headless=True enable_livestream=True
And this is the error I received.
2024-06-02 13:16:02 [18,869ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/cudamanager/src/CudaContextManager.cpp, LINE 349
2024-06-02 13:16:02 [18,872ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,873ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,875ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,877ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,878ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,880ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,881ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,883ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,885ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,886ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,888ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,889ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,891ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,893ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,894ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,896ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,899ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,901ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,902ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,904ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,905ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,907ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,908ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,910ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,912ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,913ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,915ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,916ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,918ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,920ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,921ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,923ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,925ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,926ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,928ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,929ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,931ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,934ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,935ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,936ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,937ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,939ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,940ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,942ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,943ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,945ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,947ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,948ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,951ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,953ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,954ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,955ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,956ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,958ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,959ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,961ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,963ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,964ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,966ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,969ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,970ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,972ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,974ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,975ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,977ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,978ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,980ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,982ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,983ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,985ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,986ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,987ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,988ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,990ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,991ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,993ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,995ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,996ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,998ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [18,999ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,001ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,004ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,006ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,007ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,009ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,011ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,012ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,014ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,015ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,017ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,020ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,022ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,023ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,025ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:02 [19,026ms] [Error] [omni.physx.plugin] PhysX error: Mem allocation failed with error code 2!
2024-06-02 13:16:03 [19,697ms] [Warning] [omni.physx.plugin] PhysX warning: /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, LINE 109
2024-06-02 13:16:03 [19,705ms] [Warning] [omni.physx.plugin] PhysX warning: /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, LINE 109
2024-06-02 13:16:03 [19,716ms] [Warning] [omni.physx.plugin] PhysX warning: /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, LINE 109
2024-06-02 13:16:03 [19,731ms] [Warning] [omni.physx.plugin] PhysX warning: /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, LINE 109
2024-06-02 13:16:03 [19,800ms] [Warning] [omni.physx.plugin] PhysX warning: /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, FILE /buildAgent/work/eb2f45c4acc808a0/physx/source/gpucommon/src/PxgCudaMemoryAllocator.cpp, LINE 61
Fatal Python error: Segmentation fault
Are you using Isaac Lab?
Hi there, please try to run with a smaller number of environments as the deformable simulation requires more memory. This can be done in command line by adding num_envs=128 to the command. You may also need to lower the minibatch_size parameter for the training config with train.params.config.minibatch_size=2048.
