I can't open my terminal through the menu bar
I can’t open my terminal through the menu bar. It will flash a few times after being clicked, but if I right-click and select terminal in the folder, it can still open normally. What should I do
Have this happened before? What’s your JetPack version?
Can you try to reflash your Jetson device with the newer JetPack version?
My version number is l4t 32.5.2. As for the problem of brushing the system, you can take a look at another question I raised about sdkmanger if it is convenient for you
I seem to have successfully installed the DEB package, but which package is this version number? The version number is 0.11.0a0 + fa347eb
Don’t know what deb you are talking about. Maybe share more detail.
