I encountered an error when running the example program of IsaacGymEnvs
I encountered an error when running the humanoid_amp.py example using the following command.
python train.py task=HumanoidAMP
(isaacgym) jiao@jiao-Predator-PHN16-71:~/isaacgym/IsaacGymEnvs/isaacgymenvs$ python train.py task=HumanoidAMP num_envs=1024
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/hydra.py:119: UserWarning: Future Hydra versions will no longer change working directory at job runtime by default.
See https://hydra.cc/docs/1.2/upgrades/1.1_to_1.2/changes_to_job_working_dir/ for more information.
  ret = run_job(
Importing module 'gym_38' (/home/jiao/isaacgym/python/isaacgym/_bindings/linux-x86_64/gym_38.so)
Setting GYM_USD_PLUG_INFO_PATH to /home/jiao/isaacgym/python/isaacgym/_bindings/linux-x86_64/usd/plugInfo.json
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/torch/utils/cpp_extension.py:25: DeprecationWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html
  from pkg_resources import packaging  # type: ignore[attr-defined]
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/pkg_resources/__init__.py:2871: DeprecationWarning: Deprecated call to `pkg_resources.declare_namespace('mpl_toolkits')`.
Implementing implicit namespace packages (as specified in PEP 420) is preferred to `pkg_resources.declare_namespace`. See https://setuptools.pypa.io/en/latest/references/keywords.html#keyword-namespace-packages
  declare_namespace(pkg)
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/pkg_resources/__init__.py:2871: DeprecationWarning: Deprecated call to `pkg_resources.declare_namespace('google')`.
PyTorch version 1.13.1+cu117
Device count 1
/home/jiao/isaacgym/python/isaacgym/_bindings/src/gymtorch
Using /home/jiao/.cache/torch_extensions/py38_cu117 as PyTorch extensions root...
Emitting ninja build file /home/jiao/.cache/torch_extensions/py38_cu117/gymtorch/build.ninja...
Building extension module gymtorch...
Allowing ninja to set a default number of workers... (overridable by setting the environment variable MAX_JOBS=N)
ninja: no work to do.
Loading extension module gymtorch...
2024-03-28 20:46:46,636 - INFO - logger - logger initialized
<unknown>:3: DeprecationWarning: invalid escape sequence \*
Error: FBX library failed to load - importing FBX data will not succeed. Message: No module named 'fbx'
FBX tools must be installed from https://help.autodesk.com/view/FBX/2020/ENU/?guid=FBX_Developer_Help_scripting_with_python_fbx_installing_python_fbx_html
/home/jiao/isaacgym/python/isaacgym/torch_utils.py:135: DeprecationWarning: `np.float` is a deprecated alias for the builtin `float`. To silence this warning, use `float` by itself. Doing this will not modify any behavior and is safe. If you specifically wanted the numpy scalar type, use `np.float64` here.
Deprecated in NumPy 1.20; for more details and guidance: https://numpy.org/devdocs/release/1.20.0-notes.html#deprecations
  def get_axis_params(value, axis_idx, x_value=0., dtype=np.float, n_dims=3):
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/networkx/classes/graph.py:23: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working
  from collections import Mapping
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/networkx/classes/reportviews.py:95: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.10 it will stop working
  from collections import Mapping, Set, Iterable
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/networkx/readwrite/graphml.py:346: DeprecationWarning: `np.int` is a deprecated alias for the builtin `int`. To silence this warning, use `int` by itself. Doing this will not modify any behavior and is safe. When replacing `np.int`, you may wish to use e.g. `np.int64` or `np.int32` to specify the precision. If you wish to review your current use, check the release note link for additional information.
  (np.int, "int"), (np.int8, "int"),
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/torch/utils/tensorboard/__init__.py:4: DeprecationWarning: distutils Version classes are deprecated. Use packaging.version instead.
  if not hasattr(tensorboard, "__version__") or LooseVersion(
task:
    physics_engine: physx
    env:
        numEnvs: 1024
        envSpacing: 5
        episodeLength: 300
        cameraFollow: True
        enableDebugVis: False
        pdControl: True
        powerScale: 1.0
        controlFrequencyInv: 2
        stateInit: Random
        hybridInitProb: 0.5
        numAMPObsSteps: 2
        localRootObs: False
        contactBodies: ['right_foot', 'left_foot']
        terminationHeight: 0.5
        enableEarlyTermination: True
        motion_file: amp_humanoid_run.npy
        asset:
            assetFileName: mjcf/amp_humanoid.xml
        plane:
            staticFriction: 1.0
            dynamicFriction: 1.0
            restitution: 0.0
    sim:
        dt: 0.0166
        substeps: 2
        up_axis: z
        use_gpu_pipeline: True
        gravity: [0.0, 0.0, -9.81]
        physx:
            num_threads: 4
            solver_type: 1
            use_gpu: True
            num_position_iterations: 4
            num_velocity_iterations: 0
            contact_offset: 0.02
            rest_offset: 0.0
            bounce_threshold_velocity: 0.2
            max_depenetration_velocity: 10.0
            default_buffer_size_multiplier: 5.0
            max_gpu_contact_pairs: 8388608
            num_subscenes: 4
            contact_collection: 2
    task:
        randomize: False
        randomization_params:
            frequency: 600
            observations:
                range: [0, 0.002]
                operation: additive
                distribution: gaussian
            actions:
                range: [0.0, 0.02]
                operation: additive
            sim_params:
                gravity:
                    range: [0, 0.4]
                    operation: additive
                    schedule: linear
                    schedule_steps: 3000
            actor_params:
                humanoid:
                    color: True
                    rigid_body_properties:
                        mass:
                            range: [0.5, 1.5]
                            operation: scaling
                            distribution: uniform
                            setup_only: True
                            schedule: linear
                    rigid_shape_properties:
                        friction:
                            num_buckets: 500
                            range: [0.7, 1.3]
                            operation: scaling
                            schedule: linear
                        restitution:
                            range: [0.0, 0.7]
                            operation: scaling
                            schedule: linear
                    dof_properties:
                        damping:
                            range: [0.5, 1.5]
                            operation: scaling
                            schedule: linear
                        stiffness:
                            range: [0.5, 1.5]
                            operation: scaling
                            schedule: linear
                        lower:
                            range: [0, 0.01]
                            operation: additive
                            schedule: linear
                        upper:
                            range: [0, 0.01]
                            operation: additive
                            schedule: linear
train:
    params:
        seed: 42
        algo:
        model:
        network:
            separate: True
            space:
                continuous:
                    mu_activation: None
                    sigma_activation: None
                    mu_init:
                    sigma_init:
                        val: -2.9
                    fixed_sigma: True
                    learn_sigma: False
            mlp:
                units: [1024, 512]
                activation: relu
                d2rl: False
                initializer:
                regularizer:
            disc:
                units: [1024, 512]
                activation: relu
                initializer:
        load_checkpoint: False
        load_path:
        config:
            full_experiment_name: HumanoidAMP
            env_name: rlgpu
            ppo: True
            multi_gpu: False
            mixed_precision: False
            normalize_input: True
            normalize_value: True
            value_bootstrap: True
            num_actors: 1024
            reward_shaper:
                scale_value: 1
            normalize_advantage: True
            gamma: 0.99
            tau: 0.95
            learning_rate: 5e-05
            lr_schedule: constant
            kl_threshold: 0.008
            score_to_win: 20000
            max_epochs: 5000
            save_best_after: 100
            save_frequency: 50
            print_stats: True
            grad_norm: 1.0
            entropy_coef: 0.0
            truncate_grads: False
            e_clip: 0.2
            horizon_length: 16
            minibatch_size: 32768
            mini_epochs: 6
            critic_coef: 5
            clip_value: False
            seq_len: 4
            bounds_loss_coef: 10
            amp_obs_demo_buffer_size: 200000
            amp_replay_buffer_size: 1000000
            amp_replay_keep_prob: 0.01
            amp_batch_size: 512
            amp_minibatch_size: 4096
            disc_coef: 5
            disc_logit_reg: 0.05
            disc_grad_penalty: 5
            disc_reward_scale: 2
            disc_weight_decay: 0.0001
            normalize_amp_input: True
            task_reward_w: 0.0
            disc_reward_w: 1.0
pbt:
    enabled: False
task_name: HumanoidAMP
experiment:
num_envs: 1024
seed: 42
torch_deterministic: False
max_iterations:
pipeline: gpu
sim_device: cuda:0
rl_device: cuda:0
graphics_device_id: 0
num_threads: 4
solver_type: 1
num_subscenes: 4
test: False
checkpoint:
sigma:
multi_gpu: False
wandb_activate: False
wandb_group:
wandb_name: HumanoidAMP
wandb_entity:
wandb_project: isaacgymenvs
wandb_tags: []
wandb_logcode_dir:
capture_video: False
capture_video_freq: 1464
capture_video_len: 100
force_render: True
headless: False
Setting seed: 42
Using rl_device: cuda:0
Using sim_device: cuda:0
{'name': 'HumanoidAMP', 'full_experiment_name': None, 'env_name': 'rlgpu', 'ppo': True, 'multi_gpu': False, 'mixed_precision': False, 'normalize_input': True, 'normalize_value': True, 'value_bootstrap': True, 'num_actors': 1024, 'reward_shaper': {'scale_value': 1}, 'normalize_advantage': True, 'gamma': 0.99, 'tau': 0.95, 'learning_rate': 5e-05, 'lr_schedule': 'constant', 'kl_threshold': 0.008, 'score_to_win': 20000, 'max_epochs': 5000, 'save_best_after': 100, 'save_frequency': 50, 'print_stats': True, 'grad_norm': 1.0, 'entropy_coef': 0.0, 'truncate_grads': False, 'e_clip': 0.2, 'horizon_length': 16, 'minibatch_size': 32768, 'mini_epochs': 6, 'critic_coef': 5, 'clip_value': False, 'seq_len': 4, 'bounds_loss_coef': 10, 'amp_obs_demo_buffer_size': 200000, 'amp_replay_buffer_size': 1000000, 'amp_replay_keep_prob': 0.01, 'amp_batch_size': 512, 'amp_minibatch_size': 4096, 'disc_coef': 5, 'disc_logit_reg': 0.05, 'disc_grad_penalty': 5, 'disc_reward_scale': 2, 'disc_weight_decay': 0.0001, 'normalize_amp_input': True, 'task_reward_w': 0.0, 'disc_reward_w': 1.0, 'device': 'cuda:0', 'population_based_training': False, 'pbt_idx': None}
self.seed = 42
Started to train
/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/gym/spaces/box.py:84: UserWarning: WARN: Box bound precision lowered by casting to float32
  logger.warn(f"Box bound precision lowered by casting to {self.dtype}")
[Warning] [carb.gym.plugin] useGpu is set, forcing single scene (0 subscenes)
Not connected to PVD
+++ Using GPU PhysX
Physics Engine: PhysX
Physics Device: cuda:0
GPU Pipeline: enabled
/home/jiao/isaacgym/IsaacGymEnvs/isaacgymenvs/tasks/amp/humanoid_amp_base.py:186: DeprecationWarning: an integer is required (got type isaacgym._bindings.linux-x86_64.gym_38.DofDriveMode).  Implicit conversion to integers using __int__ is deprecated, and may be removed in a future version of Python.
  asset_options.default_dof_drive_mode = gymapi.DOF_MODE_NONE
Loading 1/1 motion files: /home/jiao/isaacgym/IsaacGymEnvs/isaacgymenvs/tasks/../../assets/amp/motions/amp_humanoid_run.npy
Loaded 1 motions with a total length of 1.350s.
Box(-1.0, 1.0, (28,), float32) Box(-inf, inf, (105,), float32)
WARNING: seq_len is deprecated, use seq_length instead
seq_length: 4
current training device: cuda:0
Error executing job with overrides: ['task=HumanoidAMP', 'num_envs=1024']
  File "train.py", line 210, in launch_rlg_hydra
    runner.run({
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/rl_games/torch_runner.py", line 133, in run
    self.run_train(args)
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/rl_games/torch_runner.py", line 113, in run_train
    agent = self.algo_factory.create(self.algo_name, base_name='run', params=self.params)
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/rl_games/common/object_factory.py", line 15, in create
    return builder(**kwargs)
  File "train.py", line 188, in <lambda>
    runner.algo_factory.register_builder('amp_continuous', lambda **kwargs : amp_continuous.AMPAgent(**kwargs))
  File "/home/jiao/isaacgym/IsaacGymEnvs/isaacgymenvs/learning/amp_continuous.py", line 53, in __init__
    super().__init__(base_name, params)
  File "/home/jiao/isaacgym/IsaacGymEnvs/isaacgymenvs/learning/common_agent.py", line 58, in __init__
    a2c_common.A2CBase.__init__(self, base_name, params)
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/rl_games/common/a2c_common.py", line 249, in __init__
    assert(self.batch_size % self.minibatch_size == 0)
AssertionError
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Then I used the following command to resolve the issue.
export HYDRA_FULL_ERROR=1
Then I continued running the example program
AttributeError: ‘AMPAgent’ object has no attribute ‘seq_len’
  ret = run_job(
Device count 1
2024-03-28 20:49:28,190 - INFO - logger - logger initialized
task:
    env:
        numEnvs: 4096
        envSpacing: 5
        episodeLength: 300
        cameraFollow: True
        pdControl: True
        powerScale: 1.0
        stateInit: Random
        hybridInitProb: 0.5
        numAMPObsSteps: 2
        localRootObs: False
        asset:
        plane:
            staticFriction: 1.0
            restitution: 0.0
    sim:
        dt: 0.0166
        substeps: 2
        up_axis: z
        physx:
            num_threads: 4
            solver_type: 1
            use_gpu: True
            rest_offset: 0.0
            num_subscenes: 4
    task:
        randomize: False
            frequency: 600
            observations:
                range: [0, 0.002]
                operation: additive
            actions:
                range: [0.0, 0.02]
                operation: additive
            sim_params:
                gravity:
                    range: [0, 0.4]
                    operation: additive
                    schedule: linear
            actor_params:
                humanoid:
                    color: True
                        mass:
                            range: [0.5, 1.5]
                            operation: scaling
                            setup_only: True
                            schedule: linear
                        friction:
                            num_buckets: 500
                            range: [0.7, 1.3]
                            operation: scaling
                            schedule: linear
                        restitution:
                            range: [0.0, 0.7]
                            operation: scaling
                            schedule: linear
                    dof_properties:
                        damping:
                            range: [0.5, 1.5]
                            operation: scaling
                            schedule: linear
                        stiffness:
                            range: [0.5, 1.5]
                            operation: scaling
                            schedule: linear
                        lower:
                            range: [0, 0.01]
                            operation: additive
                            schedule: linear
                        upper:
                            range: [0, 0.01]
                            operation: additive
                            schedule: linear
train:
    params:
        seed: 42
        algo:
        model:
        network:
            separate: True
            space:
                continuous:
                    mu_activation: None
                    mu_init:
                    sigma_init:
                        val: -2.9
                    fixed_sigma: True
                    learn_sigma: False
            mlp:
                units: [1024, 512]
                activation: relu
                d2rl: False
                initializer:
                regularizer:
            disc:
                units: [1024, 512]
                activation: relu
                initializer:
        load_path:
        config:
            env_name: rlgpu
            ppo: True
            multi_gpu: False
            num_actors: 4096
            reward_shaper:
                scale_value: 1
            gamma: 0.99
            tau: 0.95
            kl_threshold: 0.008
            score_to_win: 20000
            max_epochs: 5000
            save_frequency: 50
            print_stats: True
            grad_norm: 1.0
            entropy_coef: 0.0
            e_clip: 0.2
            horizon_length: 16
            mini_epochs: 6
            critic_coef: 5
            clip_value: False
            seq_len: 4
            amp_batch_size: 512
            disc_coef: 5
            task_reward_w: 0.0
            disc_reward_w: 1.0
pbt:
    enabled: False
experiment:
num_envs:
seed: 42
max_iterations:
pipeline: gpu
sim_device: cuda:0
rl_device: cuda:0
num_threads: 4
solver_type: 1
num_subscenes: 4
test: False
checkpoint:
sigma:
multi_gpu: False
wandb_group:
wandb_entity:
wandb_tags: []
wandb_logcode_dir:
force_render: True
headless: False
Setting seed: 42
{'name': 'HumanoidAMP', 'full_experiment_name': None, 'env_name': 'rlgpu', 'ppo': True, 'multi_gpu': False, 'mixed_precision': False, 'normalize_input': True, 'normalize_value': True, 'value_bootstrap': True, 'num_actors': 4096, 'reward_shaper': {'scale_value': 1}, 'normalize_advantage': True, 'gamma': 0.99, 'tau': 0.95, 'learning_rate': 5e-05, 'lr_schedule': 'constant', 'kl_threshold': 0.008, 'score_to_win': 20000, 'max_epochs': 5000, 'save_best_after': 100, 'save_frequency': 50, 'print_stats': True, 'grad_norm': 1.0, 'entropy_coef': 0.0, 'truncate_grads': False, 'e_clip': 0.2, 'horizon_length': 16, 'minibatch_size': 32768, 'mini_epochs': 6, 'critic_coef': 5, 'clip_value': False, 'seq_len': 4, 'bounds_loss_coef': 10, 'amp_obs_demo_buffer_size': 200000, 'amp_replay_buffer_size': 1000000, 'amp_replay_keep_prob': 0.01, 'amp_batch_size': 512, 'amp_minibatch_size': 4096, 'disc_coef': 5, 'disc_logit_reg': 0.05, 'disc_grad_penalty': 5, 'disc_reward_scale': 2, 'disc_weight_decay': 0.0001, 'normalize_amp_input': True, 'task_reward_w': 0.0, 'disc_reward_w': 1.0, 'device': 'cuda:0', 'population_based_training': False, 'pbt_idx': None}
self.seed = 42
Started to train
+++ Using GPU PhysX
seq_length: 4
build mlp: 105
build mlp: 105
build mlp: 210
sigma
actor_mlp.0.weight
actor_mlp.0.bias
actor_mlp.2.weight
actor_mlp.2.bias
critic_mlp.0.weight
critic_mlp.0.bias
critic_mlp.2.weight
critic_mlp.2.bias
value.weight
value.bias
mu.weight
mu.bias
_disc_mlp.0.weight
_disc_mlp.0.bias
_disc_mlp.2.weight
_disc_mlp.2.bias
_disc_logits.weight
_disc_logits.bias
RunningMeanStd:  (1,)
RunningMeanStd:  (105,)
Error executing job with overrides: ['task=HumanoidAMP']
  File "train.py", line 219, in <module>
    launch_rlg_hydra()
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/main.py", line 94, in decorated_main
    _run_hydra(
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/utils.py", line 394, in _run_hydra
    _run_app(
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/utils.py", line 457, in _run_app
    run_and_report(
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/utils.py", line 223, in run_and_report
    raise ex
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/utils.py", line 220, in run_and_report
    return func()
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/utils.py", line 458, in <lambda>
    lambda: hydra.run(
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/_internal/hydra.py", line 132, in run
    _ = ret.return_value
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/core/utils.py", line 260, in return_value
    raise self._return_value
  File "/home/jiao/anaconda3/envs/isaacgym/lib/python3.8/site-packages/hydra/core/utils.py", line 186, in run_job
    ret.return_value = task_function(task_cfg)
    runner.run({
  File "/home/jiao/isaacgym/IsaacGymEnvs/isaacgymenvs/learning/common_agent.py", line 98, in __init__
    self.dataset = amp_datasets.AMPDataset(self.batch_size, self.minibatch_size, self.is_discrete, self.is_rnn, self.ppo_device, self.seq_len)
AttributeError: 'AMPAgent' object has no attribute 'seq_len'
But when I ran the Ant example program, it worked fine
python train.py task=Ant
Please help!!!!!
Did you figure it out? i had same problem here
i think seq_len variable is changed to seq_length. change all seq_len to seq_length in common_agent.py and amp_continuous.py and amp_datasets.py file
