I am trying this, but the env only has “Isaac-Velocity-Rough-G1-v0” task, is it correct?
./isaaclab.sh -p source/standalone/workflows/rsl_rl/train.py --task Isaac-Velocity-Rough-G1-v0 --headless
But the output is pt instead of pth…
I got error when I try to play it… I guess it is the task problem? Did IssacLab has the G1 or I still need to wait? Thx
./isaaclab.sh -p source/standalone/workflows/rsl_rl/play.py --task Isaac-Velocity-Rough-G1-v0 --num_envs 32 --checkpoint /media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough/2024-06-29_00-00-14/model_2999.pt
ValueError: No checkpoints in the directory: '/media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough/2024-06-29_00-00-14' match '/media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough/2024-06-29_00-00-14/model_2999.pt'.
I have the pt file though
/media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough/2024-06-29_00-00-14$ ls
events.out.tfevents.1719590448.ak-MS-7D99.9667.0 git model_2999.pt params
[INFO] Using python from: /home/ak/anaconda3/envs/isaaclab/bin/python
[INFO][AppLauncher]: Loading experience file: /media/ak/HD/Omniverse/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/../../../../../../apps/isaaclab.python.kit
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.kit_app'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Starting kit application with the following args: ['/home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/media/ak/HD/Omniverse/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/../../../../../../apps/isaaclab.python.kit', '--/app/tokens/exe-path=/home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/exts', '--ext-folder', '/home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/apps', '--/renderer/activeGpu=0', '--/physics/cudaDevice=0', '--portable', '--/app/window/hideUi=False']
Passing the following args to the base kit application: ['--task', 'Isaac-Velocity-Rough-G1-v0', '--num_envs', '32', '--checkpoint', '/media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough/2024-06-29_00-00-14/model_2999.pt']
Loading user config located at: '/home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/data/Kit/Isaac-Sim/4.0/user.config.json'
[Info] [carb] Logging to file: /home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/omni/logs/Kit/Isaac-Sim/4.0/kit_20240629_084456.log
2024-06-29 00:44:56 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.026s] [ext: omni.kit.async_engine-0.0.0] startup
[0.075s] [ext: omni.stats-0.0.0] startup
[0.076s] [ext: omni.client-1.1.0] startup
[0.091s] [ext: omni.datastore-0.0.0] startup
[0.091s] [ext: omni.blobkey-1.1.0] startup
[0.091s] [ext: omni.ujitso.default-1.0.0] startup
[0.091s] [ext: omni.hsscclient-0.0.0] startup
[0.092s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.092s] [ext: omni.assets.plugins-0.0.0] startup
[0.093s] [ext: omni.gpu_foundation-0.0.0] startup
[0.098s] [ext: carb.windowing.plugins-1.0.0] startup
[0.103s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.183.01 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4090 | Yes: 0 | | 24564 MB | 10de | 0 |
| | | | | | 2684 | f844c4a0.. |
| | | | | | 1 | |
| OS: 22.04.4 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.4, Kernel: 6.5.0-41-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 13th Gen Intel(R) Core(TM) i9-13900F | Cores: 24 | Logical: 48
| Total Memory (MB): 31925 | Free Memory: 27633
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.482s] [ext: omni.kit.pipapi-0.0.0] startup
[0.483s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.483s] [ext: omni.mtlx-0.1.0] startup
[0.483s] [ext: omni.usd.config-1.0.3] startup
[0.485s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.485s] [ext: omni.usd.libs-1.0.0] startup
[0.539s] [ext: omni.kit.telemetry-0.5.0] startup
[0.552s] [ext: omni.kit.loop-isaac-1.2.0] startup
[0.553s] [ext: omni.kit.test-0.0.0] startup
[0.575s] [ext: omni.appwindow-1.1.8] startup
[0.957s] [ext: omni.kit.renderer.core-1.0.1] startup
[1.567s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.568s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[1.605s] [ext: omni.ui-2.23.11] startup
[1.610s] [ext: omni.kit.mainwindow-1.0.3] startup
[1.611s] [ext: carb.audio-0.1.0] startup
[1.612s] [ext: omni.uiaudio-1.0.0] startup
[1.613s] [ext: omni.kit.uiapp-0.0.0] startup
[1.613s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.691s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.693s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.696s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.698s] [ext: omni.usd.schema.isaac-2.0.2] startup
[1.702s] [ext: omni.usd.schema.physx-106.0.16] startup
[1.727s] [ext: omni.usd.schema.forcefield-106.0.16] startup
[1.730s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.732s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[1.733s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[1.735s] [ext: omni.graph.exec-0.9.3] startup
[1.735s] [ext: omni.usd_resolver-1.0.0] startup
[1.738s] [ext: omni.resourcemonitor-105.0.1] startup
[1.739s] [ext: omni.activity.core-1.0.1] startup
[1.740s] [ext: omni.kit.usd_undo-0.1.8] startup
[1.740s] [ext: omni.usd.core-1.2.11] startup
[1.742s] [ext: omni.kit.widget.nucleus_connector-1.1.5] startup
[1.743s] [ext: omni.kit.exec.core-0.13.0] startup
[1.744s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[1.745s] [ext: omni.iray.libs-0.0.0] startup
[1.747s] [ext: usdrt.scenegraph-7.4.8] startup
[1.770s] [ext: omni.ujitso.client-0.0.0] startup
[1.771s] [ext: omni.mdl.neuraylib-0.2.4] startup
[1.771s] [ext: omni.kit.actions.core-1.0.0] startup
[1.772s] [ext: omni.hydra.usdrt_delegate-7.4.7] startup
[1.785s] [ext: omni.timeline-1.0.10] startup
[1.786s] [ext: omni.kit.commands-1.4.9] startup
[1.787s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[1.788s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[1.792s] [ext: omni.volume-0.5.0] startup
[1.794s] [ext: omni.usd-1.10.39] startup
[1.825s] [ext: omni.hydra.rtx-0.2.0] startup
[1.834s] [ext: omni.kit.hydra_texture-1.2.6] startup
[1.836s] [ext: omni.kit.widget.options_menu-1.1.4] startup
[1.838s] [ext: omni.kit.widget.viewport-106.0.2] startup
[1.839s] [ext: omni.kit.widget.options_button-1.0.2] startup
[1.840s] [ext: omni.kit.window.drop_support-1.0.1] startup
[1.840s] [ext: omni.ui.scene-1.9.3] startup
[1.842s] [ext: omni.kit.viewport.registry-104.0.6] startup
[1.843s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[1.843s] [ext: omni.kit.helper.file_utils-0.1.7] startup
[1.844s] [ext: omni.kit.widget.path_field-2.0.9] startup
[1.844s] [ext: omni.kit.search_core-1.0.5] startup
[1.844s] [ext: omni.kit.widget.filebrowser-2.3.47] startup
[1.846s] [ext: omni.kit.widget.browser_bar-2.0.9] startup
[1.847s] [ext: omni.kit.widget.context_menu-1.2.1] startup
[1.847s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[1.847s] [ext: omni.kit.notification_manager-1.0.8] startup
[1.848s] [ext: omni.kit.clipboard-1.0.3] startup
[1.849s] [ext: omni.kit.usd.layers-2.1.30] startup
[1.853s] [ext: omni.kit.menu.utils-1.5.23] startup
[1.859s] [ext: omni.kit.window.filepicker-2.10.32] startup
[1.864s] [ext: omni.kit.stage_template.core-1.1.20] startup
[1.864s] [ext: omni.kit.primitive.mesh-1.0.16] startup
[1.866s] [ext: omni.kit.window.file_importer-1.1.11] startup
[1.867s] [ext: omni.kit.window.file_exporter-1.0.29] startup
[1.867s] [ext: omni.kit.stage_templates-1.2.2] startup
[1.868s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[1.869s] [ext: omni.kit.window.file-1.3.52] startup
[1.870s] [ext: omni.kit.context_menu-1.8.0] startup
[1.871s] [ext: omni.mdl-52.0.1] startup
[1.879s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[1.879s] [ext: omni.hydra.engine.stats-1.0.1] startup
[1.882s] [ext: omni.kit.raycast.query-1.0.5] startup
[1.887s] [ext: omni.kit.material.library-1.4.0] startup
[1.888s] [ext: omni.kit.widget.settings-1.1.0] startup
[1.889s] [ext: omni.kit.widget.prompt-1.0.7] startup
[1.889s] [ext: omni.kit.viewport.window-106.0.8] startup
[1.897s] [ext: omni.kit.window.preferences-1.5.1] startup
[1.901s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[1.902s] [ext: omni.kit.viewport.utility-1.0.17] startup
[1.902s] [ext: omni.kit.widget.live_session_management-1.2.18] startup
[1.903s] [ext: omni.convexdecomposition-106.0.16] startup
[1.906s] [ext: omni.kit.hotkeys.core-1.3.3] startup
[1.906s] [ext: omni.kit.window.content_browser_registry-0.0.4] startup
[1.907s] [ext: omni.kit.widget.filter-1.1.3] startup
[1.907s] [ext: omni.kit.widget.searchfield-1.1.5] startup
[1.907s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[1.907s] [ext: omni.kit.window.content_browser-2.9.13] startup
[1.914s] [ext: omni.kit.window.property-1.11.1] startup
[1.915s] [ext: omni.kit.widget.stage-2.10.26] startup
[1.920s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.920s] [ext: omni.kit.property.usd-3.21.26] startup
[1.924s] [ext: omni.kvdb-106.0.16] startup
[1.925s] [ext: omni.physx.foundation-106.0.16] startup
[1.925s] [ext: omni.localcache-106.0.16] startup
[1.926s] [ext: omni.inspect-1.0.1] startup
[1.927s] [ext: omni.kit.widget.graph-1.12.6] startup
[1.929s] [ext: omni.graph.tools-1.77.0] startup
[1.938s] [ext: omni.graph.core-2.170.0] startup
[1.940s] [ext: omni.usdphysics-106.0.16] startup
[1.942s] [ext: omni.kit.window.extensions-1.4.7] startup
[1.944s] [ext: omni.graph-1.135.0] startup
[2.008s] [ext: omni.physx.cooking-106.0.16] startup
[2.046s] [ext: omni.graph.ui-1.67.1] startup
[2.061s] [ext: omni.graph.action_core-1.1.4] startup
[2.067s] [ext: omni.physx-106.0.16] startup
[2.077s] [ext: omni.graph.action_nodes-1.21.3] startup
[2.085s] [ext: omni.kit.numpy.common-0.1.2] startup
[2.089s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[2.093s] [ext: omni.physx.stageupdate-106.0.16] startup
[2.094s] [ext: omni.graph.action-1.101.1] startup
[2.095s] [ext: omni.isaac.kit-1.10.0] startup
[2.096s] [ext: omni.isaac.dynamic_control-1.3.7] startup
[2.101s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[2.102s] [ext: omni.physics.tensors-106.0.16] startup
[2.107s] [ext: omni.isaac.version-1.1.0] startup
[2.107s] [ext: omni.physx.tensors-106.0.16] startup
[2.110s] [ext: omni.warp.core-1.1.0] startup
Warp 1.1.0 initialized:
CUDA Toolkit 11.5, Driver 12.2
Devices:
"cpu" : "x86_64"
"cuda:0" : "NVIDIA GeForce RTX 4090" (24 GiB, sm_89, mempool enabled)
Kernel cache:
/home/ak/.cache/warp/1.1.0
[2.170s] [ext: omni.isaac.nucleus-0.1.2] startup
[2.171s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[2.172s] [ext: omni.isaac.core-3.12.0] startup
[2.786s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[2.789s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[2.790s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[2.791s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[2.792s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[2.795s] [ext: omni.graph.window.core-1.107.1] startup
[2.803s] [ext: omni.ui_query-1.1.2] startup
[2.805s] [ext: omni.graph.window.generic-1.23.1] startup
[2.809s] [ext: omni.kit.ui_test-1.2.18] startup
[2.811s] [ext: omni.kit.ui.actions-1.0.1] startup
[2.812s] [ext: omni.isaac.ui-0.15.1] startup
[2.814s] [ext: omni.kit.window.cursor-1.1.2] startup
[2.815s] [ext: omni.kit.menu.common-1.1.5] startup
[2.816s] [ext: omni.command.usd-1.0.3] startup
[2.817s] [ext: omni.isaac.menu-0.4.1] startup
[2.818s] [ext: omni.kit.viewport.menubar.core-107.0.0] startup
[2.827s] [ext: omni.kit.viewport.actions-105.2.8] startup
[2.829s] [ext: omni.graph.window.action-1.25.2] startup
[2.832s] [ext: omni.kit.viewport.menubar.display-106.0.0] startup
[2.834s] [ext: omni.debugdraw-0.1.3] startup
[2.837s] [ext: omni.kit.widget.toolbar-1.6.2] startup
[2.840s] [ext: omni.kit.manipulator.transform-104.7.5] startup
[2.842s] [ext: omni.usdphysics.ui-106.0.16] startup
[2.857s] [ext: omni.physx.commands-106.0.16] startup
[2.859s] [ext: omni.kit.manipulator.tool.snap-1.4.5] startup
[2.861s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[2.862s] [ext: omni.physx.ui-106.0.16] startup
[2.878s] [ext: omni.kit.property.material-1.9.3] startup
[2.880s] [ext: omni.kit.viewport.manipulator.transform-106.0.0] startup
ViewportTransformManipulatorExt on_startup
[2.881s] [ext: omni.physx.demos-106.0.16] startup
[2.889s] [ext: omni.kit.property.physx-106.0.16] startup
[2.929s] [ext: omni.kit.manipulator.prim.core-106.0.2] startup
[2.933s] [ext: omni.fabric.commands-1.1.4] startup
[2.937s] [ext: omni.graph.image.core-0.3.2] startup
[2.940s] [ext: omni.physx.vehicle-106.0.16] startup
[2.949s] [ext: omni.kit.manipulator.prim.usd-106.0.1] startup
[2.950s] [ext: omni.kit.manipulator.prim.fabric-106.0.1] startup
[2.951s] [ext: omni.graph.image.nodes-1.0.2] startup
[2.952s] [ext: omni.physx.camera-106.0.16] startup
[2.958s] [ext: omni.kit.manipulator.prim-106.0.0] startup
[2.958s] [ext: omni.graph.nodes-1.141.2] startup
[2.965s] [ext: omni.graph.ui_nodes-1.24.1] startup
[2.968s] [ext: omni.kit.manipulator.selection-104.0.9] startup
[2.970s] [ext: omni.kit.widget.layers-1.7.9] startup
[2.988s] [ext: omni.kit.window.toolbar-1.6.1] startup
[2.992s] [ext: omni.graph.scriptnode-1.18.2] startup
[2.995s] [ext: omni.graph.bundle.action-2.0.4] startup
[2.998s] [ext: omni.physx.cct-106.0.16] startup
[3.013s] [ext: omni.physx.graph-106.0.16] startup
[3.029s] [ext: omni.physx.supportui-106.0.16] startup
[3.044s] [ext: omni.physx.telemetry-106.0.16] startup
[3.054s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[3.061s] [ext: omni.sensors.tiled-0.0.3] startup
[3.065s] [ext: omni.syntheticdata-0.6.7] startup
[3.122s] [ext: omni.warp-1.1.0] startup
[3.127s] [ext: omni.physx.bundle-106.0.16] startup
[3.128s] [ext: omni.kit.window.material_graph-1.8.15] startup
[3.172s] [ext: omni.isaac.debug_draw-0.7.1] startup
[3.178s] [ext: omni.sensors.nv.common-1.0.1] startup
[3.184s] [ext: omni.replicator.core-1.11.8] startup
2024-06-29 00:44:59 [3,186ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[3.238s] [ext: omni.kit.menu.create-1.0.12] startup
[3.241s] [ext: omni.sensors.nv.materials-1.0.0] startup
[3.242s] [ext: omni.isaac.range_sensor-3.0.1] startup
[3.260s] [ext: omni.isaac.core_nodes-1.15.4] startup
[3.274s] [ext: omni.sensors.nv.wpm-1.0.0] startup
[3.276s] [ext: omni.kit.actions.window-1.1.1] startup
[3.286s] [ext: omni.kit.selection-0.1.4] startup
[3.289s] [ext: omni.sensors.nv.radar-1.0.1] startup
[3.292s] [ext: omni.sensors.nv.lidar-1.0.1] startup
[3.296s] [ext: omni.kit.menu.file-1.1.9] startup
[3.298s] [ext: omni.kit.menu.edit-1.1.19] startup
[3.303s] [ext: omni.isaac.sensor-11.3.0] startup
[3.356s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[3.363s] [ext: omni.kit.property.isaac-0.2.3] startup
[3.365s] [ext: omni.kit.property.layer-1.1.5] startup
[3.370s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[3.372s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[3.373s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[3.377s] [ext: omni.rtx.window.settings-0.6.15] startup
[3.380s] [ext: omni.kit.widget.live-2.1.6] startup
[3.381s] [ext: omni.kit.viewport.menubar.camera-105.1.8] startup
[3.383s] [ext: omni.kit.viewport.menubar.render-106.1.2] startup
[3.385s] [ext: omni.kit.viewport.menubar.settings-106.0.0] startup
[3.386s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[3.387s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[3.409s] [ext: omni.kit.property.audio-1.0.11] startup
[3.411s] [ext: omni.kit.widget.calendar-1.0.8] startup
[3.412s] [ext: omni.kit.widget.stage_icons-1.0.3] startup
[3.412s] [ext: omni.hydra.scene_api-0.1.2] startup
[3.417s] [ext: omni.kit.property.geometry-1.3.0] startup
[3.419s] [ext: omni.kit.property.camera-1.0.6] startup
[3.420s] [ext: omni.kit.widget.extended_searchfield-1.0.27] startup
[3.424s] [ext: omni.kit.window.stage-2.5.9] startup
[3.426s] [ext: omni.kit.property.transform-1.5.1] startup
[3.428s] [ext: omni.kit.property.render-1.1.1] startup
[3.429s] [ext: omni.kit.property.light-1.0.8] startup
[3.430s] [ext: omni.kit.window.commands-0.2.5] startup
[3.431s] [ext: omni.kit.widget.timeline-105.0.1] startup
[3.433s] [ext: omni.kit.menu.stage-1.2.5] startup
[3.433s] [ext: omni.kit.property.bundle-1.2.11] startup
[3.434s] [ext: omni.kit.window.status_bar-0.1.6] startup
[3.438s] [ext: omni.kit.window.title-1.1.3] startup
[3.438s] [ext: omni.replicator.isaac-1.15.0] startup
[3.447s] [ext: omni.replicator.replicator_yaml-2.0.5] startup
[3.457s] [ext: omni.rtx.settings.core-0.6.0] startup
[3.462s] [ext: omni.kit.window.console-0.2.12] startup
[3.470s] [ext: semantics.schema.editor-0.3.4] startup
[3.473s] [ext: semantics.schema.property-1.0.2] startup
[3.474s] [ext: omni.kit.window.script_editor-1.7.6] startup
[3.476s] [ext: omni.kit.profiler.window-2.2.1] startup
2024-06-29 00:44:59 [3,468ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
[3.481s] [ext: omni.isaac.utils-1.0.1] startup
[3.482s] [ext: omni.isaac.cloner-0.8.1] startup
[3.484s] [ext: omni.kit.window.stats-0.1.6] startup
[3.485s] [ext: isaaclab.python-1.0.0] startup
[3.486s] Simulation App Starting
[4.840s] app ready
[5.582s] Simulation App Startup Complete
[INFO]: Parsing configuration from: <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.rough_env_cfg.G1RoughEnvCfg'>
[INFO]: Parsing configuration from: <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.agents.rsl_rl_cfg.G1RoughPPORunnerCfg'>
[6.042s] [ext: omni.physx.fabric-106.0.16] startup
[INFO]: Base environment:
Environment device : cuda:0
Physics step-size : 0.005
Rendering step-size : 0.02
Environment step-size : 0.02
Physics GPU pipeline : True
Physics GPU simulation: True
[INFO] Generating terrains based on curriculum took : 0.794930 seconds
[INFO]: Time taken for scene creation : 2.731068 seconds
[INFO]: Scene manager: <class InteractiveScene>
Number of environments: 32
Environment spacing : 2.5
Source prim name : /World/envs/env_0
Global prim paths : ['/World/ground']
Replicate physics : True
[INFO]: Starting the simulation. This may take a few seconds. Please wait...
2024-06-29 00:45:07 [11,888ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /World/envs/env_0/Robot/head_link/visuals.proto_mesh_0_id0 that has not been populated
[INFO]: Time taken for simulation start : 3.415806 seconds
[INFO] Command Manager: <CommandManager> contains 1 active terms.
| Active Command Terms |
| Index | Name | Type |
| 0 | base_velocity | UniformVelocityCommand |
[INFO] Action Manager: <ActionManager> contains 1 active terms.
| Active Action Terms (shape: 37) |
| Index | Name | Dimension |
| 0 | joint_pos | 37 |
Module omni.isaac.lab.utils.warp.kernels load on device 'cuda:0' took 1.36 ms
[INFO] Observation Manager: <ObservationManager> contains 1 groups.
| Active Observation Terms in Group: 'policy' (shape: (310,)) |
| Index | Name | Shape |
| 0 | base_lin_vel | (3,) |
| 1 | base_ang_vel | (3,) |
| 2 | projected_gravity | (3,) |
| 3 | velocity_commands | (3,) |
| 4 | joint_pos | (37,) |
| 5 | joint_vel | (37,) |
| 6 | actions | (37,) |
| 7 | height_scan | (187,) |
[INFO] Event Manager: <EventManager> contains 2 active terms.
| Active Event Terms in Mode: 'startup' |
| Index | Name |
| 0 | physics_material |
| Active Event Terms in Mode: 'reset' |
| Index | Name |
| 0 | base_external_force_torque |
| 1 | reset_base |
| 2 | reset_robot_joints |
[INFO] Termination Manager: <TerminationManager> contains 2 active terms.
| Active Termination Terms |
| Index | Name | Time Out |
| 0 | time_out | True |
| 1 | base_contact | False |
[INFO] Reward Manager: <RewardManager> contains 16 active terms.
| Active Reward Terms |
| Index | Name | Weight |
| 0 | track_lin_vel_xy_exp | 1.0 |
| 1 | track_ang_vel_z_exp | 2.0 |
| 2 | lin_vel_z_l2 | 0.0 |
| 3 | ang_vel_xy_l2 | -0.05 |
| 4 | dof_torques_l2 | -1.5e-07 |
| 5 | dof_acc_l2 | -1.25e-07 |
| 6 | action_rate_l2 | -0.005 |
| 7 | feet_air_time | 0.25 |
| 8 | flat_orientation_l2 | -1.0 |
| 9 | dof_pos_limits | -1.0 |
| 10 | termination_penalty | -200.0 |
| 11 | feet_slide | -0.1 |
| 12 | joint_deviation_hip | -0.1 |
| 13 | joint_deviation_arms | -0.1 |
| 14 | joint_deviation_fingers | -0.05 |
| 15 | joint_deviation_torso | -0.1 |
[INFO] Curriculum Manager: <CurriculumManager> contains 1 active terms.
| Active Curriculum Terms |
| Index | Name |
| 0 | terrain_levels |
Creating window for environment.
[INFO]: Completed setting up the environment...
[INFO] Loading experiment from directory: /media/ak/HD/Omniverse/IsaacLab/logs/rsl_rl/g1_rough
File "/media/ak/HD/Omniverse/IsaacLab/source/standalone/workflows/rsl_rl/play.py", line 106, in <module>
main()
File "/media/ak/HD/Omniverse/IsaacLab/source/standalone/workflows/rsl_rl/play.py", line 71, in main
resume_path = get_checkpoint_path(log_root_path, agent_cfg.load_run, agent_cfg.load_checkpoint)
File "/media/ak/HD/Omniverse/IsaacLab/source/extensions/omni.isaac.lab_tasks/omni/isaac/lab_tasks/utils/parse_cfg.py", line 205, in get_checkpoint_path
raise ValueError(f"No checkpoints in the directory: '{run_path}' match '{checkpoint}'.")
2024-06-29 00:45:08 [12,682ms] [Warning] [carb] [Plugin: omni.sensors.tiled.plugin] Module /home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/extscache/omni.sensors.tiled-0.0.3+106.0.0.lx64.r/bin/libomni.sensors.tiled.plugin.so remained loaded after unload request
2024-06-29 00:45:08 [12,685ms] [Warning] [carb] [Plugin: omni.spectree.delegate.plugin] Module /home/ak/anaconda3/envs/isaaclab/lib/python3.10/site-packages/isaacsim/extscache/omni.usd_resolver/bin/libomni.spectree.delegate.plugin.so remained loaded after unload request
2024-06-29 00:45:08 [12,687ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2024-06-29 00:45:08 [12,688ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2024-06-29 00:45:08 [12,688ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2024-06-29 00:45:08 [12,893ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
The env
| Available Environments in Isaac Lab |
| S. No. | Task Name | Entry Point | Config |
| 1 | Isaac-Ant-Direct-v0 | omni.isaac.lab_tasks.direct.ant:AntEnv | <class 'omni.isaac.lab_tasks.direct.ant.ant_env.AntEnvCfg'> |
| 2 | Isaac-Velocity-Flat-Anymal-C-Direct-v0 | omni.isaac.lab_tasks.direct.anymal_c:AnymalCEnv | <class 'omni.isaac.lab_tasks.direct.anymal_c.anymal_c_env.AnymalCFlatEnvCfg'> |
| 3 | Isaac-Velocity-Rough-Anymal-C-Direct-v0 | omni.isaac.lab_tasks.direct.anymal_c:AnymalCEnv | <class 'omni.isaac.lab_tasks.direct.anymal_c.anymal_c_env.AnymalCRoughEnvCfg'> |
| 4 | Isaac-Cartpole-Direct-v0 | omni.isaac.lab_tasks.direct.cartpole:CartpoleEnv | <class 'omni.isaac.lab_tasks.direct.cartpole.cartpole_env.CartpoleEnvCfg'> |
| 5 | Isaac-Cartpole-RGB-Camera-Direct-v0 | omni.isaac.lab_tasks.direct.cartpole:CartpoleCameraEnv | <class 'omni.isaac.lab_tasks.direct.cartpole.cartpole_camera_env.CartpoleRGBCameraEnvCfg'> |
| 6 | Isaac-Cartpole-Depth-Camera-Direct-v0 | omni.isaac.lab_tasks.direct.cartpole:CartpoleCameraEnv | <class 'omni.isaac.lab_tasks.direct.cartpole.cartpole_camera_env.CartpoleDepthCameraEnvCfg'> |
| 7 | Isaac-Franka-Cabinet-Direct-v0 | omni.isaac.lab_tasks.direct.franka_cabinet:FrankaCabinetEnv | <class 'omni.isaac.lab_tasks.direct.franka_cabinet.franka_cabinet_env.FrankaCabinetEnvCfg'> |
| 8 | Isaac-Humanoid-Direct-v0 | omni.isaac.lab_tasks.direct.humanoid:HumanoidEnv | <class 'omni.isaac.lab_tasks.direct.humanoid.humanoid_env.HumanoidEnvCfg'> |
| 9 | Isaac-Quadcopter-Direct-v0 | omni.isaac.lab_tasks.direct.quadcopter:QuadcopterEnv | <class 'omni.isaac.lab_tasks.direct.quadcopter.quadcopter_env.QuadcopterEnvCfg'> |
| 10 | Isaac-Shadow-Hand-Direct-v0 | omni.isaac.lab_tasks.direct.shadow_hand:ShadowHandEnv | <class 'omni.isaac.lab_tasks.direct.shadow_hand.shadow_hand_env_cfg.ShadowHandEnvCfg'> |
| 11 | Isaac-Shadow-Hand-OpenAI-FF-Direct-v0 | omni.isaac.lab_tasks.direct.shadow_hand:ShadowHandEnv | <class 'omni.isaac.lab_tasks.direct.shadow_hand.shadow_hand_env_cfg.ShadowHandOpenAIEnvCfg'> |
| 12 | Isaac-Shadow-Hand-OpenAI-LSTM-Direct-v0 | omni.isaac.lab_tasks.direct.shadow_hand:ShadowHandEnv | <class 'omni.isaac.lab_tasks.direct.shadow_hand.shadow_hand_env_cfg.ShadowHandOpenAIEnvCfg'> |
| 13 | Isaac-Humanoid-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.classic.humanoid.humanoid_env_cfg.HumanoidEnvCfg'> |
| 14 | Isaac-Ant-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.classic.ant.ant_env_cfg.AntEnvCfg'> |
| 15 | Isaac-Cartpole-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.classic.cartpole.cartpole_env_cfg.CartpoleEnvCfg'> |
| 16 | Isaac-Velocity-Flat-Anymal-B-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_b.flat_env_cfg.AnymalBFlatEnvCfg'> |
| 17 | Isaac-Velocity-Flat-Anymal-B-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_b.flat_env_cfg.AnymalBFlatEnvCfg_PLAY'> |
| 18 | Isaac-Velocity-Rough-Anymal-B-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_b.rough_env_cfg.AnymalBRoughEnvCfg'> |
| 19 | Isaac-Velocity-Rough-Anymal-B-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_b.rough_env_cfg.AnymalBRoughEnvCfg_PLAY'> |
| 20 | Isaac-Velocity-Flat-Anymal-C-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_c.flat_env_cfg.AnymalCFlatEnvCfg'> |
| 21 | Isaac-Velocity-Flat-Anymal-C-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_c.flat_env_cfg.AnymalCFlatEnvCfg_PLAY'> |
| 22 | Isaac-Velocity-Rough-Anymal-C-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_c.rough_env_cfg.AnymalCRoughEnvCfg'> |
| 23 | Isaac-Velocity-Rough-Anymal-C-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_c.rough_env_cfg.AnymalCRoughEnvCfg_PLAY'> |
| 24 | Isaac-Velocity-Flat-Anymal-D-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_d.flat_env_cfg.AnymalDFlatEnvCfg'> |
| 25 | Isaac-Velocity-Flat-Anymal-D-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_d.flat_env_cfg.AnymalDFlatEnvCfg_PLAY'> |
| 26 | Isaac-Velocity-Rough-Anymal-D-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_d.rough_env_cfg.AnymalDRoughEnvCfg'> |
| 27 | Isaac-Velocity-Rough-Anymal-D-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.anymal_d.rough_env_cfg.AnymalDRoughEnvCfg_PLAY'> |
| 28 | Isaac-Velocity-Flat-Cassie-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.cassie.flat_env_cfg.CassieFlatEnvCfg'> |
| 29 | Isaac-Velocity-Flat-Cassie-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.cassie.flat_env_cfg.CassieFlatEnvCfg_PLAY'> |
| 30 | Isaac-Velocity-Rough-Cassie-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.cassie.rough_env_cfg.CassieRoughEnvCfg'> |
| 31 | Isaac-Velocity-Rough-Cassie-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.cassie.rough_env_cfg.CassieRoughEnvCfg_PLAY'> |
| 32 | Isaac-Velocity-Rough-G1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.rough_env_cfg.G1RoughEnvCfg'> |
| 33 | Isaac-Velocity-Rough-G1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.rough_env_cfg.G1RoughEnvCfg_PLAY'> |
| 34 | Isaac-Velocity-Flat-G1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.flat_env_cfg.G1FlatEnvCfg'> |
| 35 | Isaac-Velocity-Flat-G1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.g1.flat_env_cfg.G1FlatEnvCfg_PLAY'> |
| 36 | Isaac-Velocity-Rough-H1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.h1.rough_env_cfg.H1RoughEnvCfg'> |
| 37 | Isaac-Velocity-Rough-H1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.h1.rough_env_cfg.H1RoughEnvCfg_PLAY'> |
| 38 | Isaac-Velocity-Flat-H1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.h1.flat_env_cfg.H1FlatEnvCfg'> |
| 39 | Isaac-Velocity-Flat-H1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.h1.flat_env_cfg.H1FlatEnvCfg_PLAY'> |
| 40 | Isaac-Velocity-Flat-Spot-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.spot.flat_env_cfg.SpotFlatEnvCfg'> |
| 41 | Isaac-Velocity-Flat-Spot-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.spot.flat_env_cfg.SpotFlatEnvCfg_PLAY'> |
| 42 | Isaac-Velocity-Flat-Unitree-A1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_a1.flat_env_cfg.UnitreeA1FlatEnvCfg'> |
| 43 | Isaac-Velocity-Flat-Unitree-A1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_a1.flat_env_cfg.UnitreeA1FlatEnvCfg_PLAY'> |
| 44 | Isaac-Velocity-Rough-Unitree-A1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_a1.rough_env_cfg.UnitreeA1RoughEnvCfg'> |
| 45 | Isaac-Velocity-Rough-Unitree-A1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_a1.rough_env_cfg.UnitreeA1RoughEnvCfg_PLAY'> |
| 46 | Isaac-Velocity-Flat-Unitree-Go1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go1.flat_env_cfg.UnitreeGo1FlatEnvCfg'> |
| 47 | Isaac-Velocity-Flat-Unitree-Go1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go1.flat_env_cfg.UnitreeGo1FlatEnvCfg_PLAY'> |
| 48 | Isaac-Velocity-Rough-Unitree-Go1-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go1.rough_env_cfg.UnitreeGo1RoughEnvCfg'> |
| 49 | Isaac-Velocity-Rough-Unitree-Go1-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go1.rough_env_cfg.UnitreeGo1RoughEnvCfg_PLAY'> |
| 50 | Isaac-Velocity-Flat-Unitree-Go2-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go2.flat_env_cfg.UnitreeGo2FlatEnvCfg'> |
| 51 | Isaac-Velocity-Flat-Unitree-Go2-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go2.flat_env_cfg.UnitreeGo2FlatEnvCfg_PLAY'> |
| 52 | Isaac-Velocity-Rough-Unitree-Go2-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go2.rough_env_cfg.UnitreeGo2RoughEnvCfg'> |
| 53 | Isaac-Velocity-Rough-Unitree-Go2-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.locomotion.velocity.config.unitree_go2.rough_env_cfg.UnitreeGo2RoughEnvCfg_PLAY'> |
| 54 | Isaac-Open-Drawer-Franka-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.cabinet.config.franka.joint_pos_env_cfg.FrankaCabinetEnvCfg'> |
| 55 | Isaac-Open-Drawer-Franka-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.cabinet.config.franka.joint_pos_env_cfg.FrankaCabinetEnvCfg_PLAY'> |
| 56 | Isaac-Open-Drawer-Franka-IK-Abs-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.cabinet.config.franka.ik_abs_env_cfg.FrankaCabinetEnvCfg'> |
| 57 | Isaac-Open-Drawer-Franka-IK-Rel-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.cabinet.config.franka.ik_rel_env_cfg.FrankaCabinetEnvCfg'> |
| 58 | Isaac-Repose-Cube-Allegro-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.inhand.config.allegro_hand.allegro_env_cfg.AllegroCubeEnvCfg'> |
| 59 | Isaac-Repose-Cube-Allegro-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.inhand.config.allegro_hand.allegro_env_cfg.AllegroCubeEnvCfg_PLAY'> |
| 60 | Isaac-Repose-Cube-Allegro-NoVelObs-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.inhand.config.allegro_hand.allegro_env_cfg.AllegroCubeNoVelObsEnvCfg'> |
| 61 | Isaac-Repose-Cube-Allegro-NoVelObs-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.inhand.config.allegro_hand.allegro_env_cfg.AllegroCubeNoVelObsEnvCfg_PLAY'> |
| 62 | Isaac-Lift-Cube-Franka-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.lift.config.franka.joint_pos_env_cfg.FrankaCubeLiftEnvCfg'> |
| 63 | Isaac-Lift-Cube-Franka-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.lift.config.franka.joint_pos_env_cfg.FrankaCubeLiftEnvCfg_PLAY'> |
| 64 | Isaac-Lift-Cube-Franka-IK-Abs-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.lift.config.franka.ik_abs_env_cfg.FrankaCubeLiftEnvCfg'> |
| 65 | Isaac-Lift-Cube-Franka-IK-Rel-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.lift.config.franka.ik_rel_env_cfg.FrankaCubeLiftEnvCfg'> |
| 66 | Isaac-Reach-Franka-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.franka.joint_pos_env_cfg.FrankaReachEnvCfg'> |
| 67 | Isaac-Reach-Franka-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.franka.joint_pos_env_cfg.FrankaReachEnvCfg_PLAY'> |
| 68 | Isaac-Reach-Franka-IK-Abs-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.franka.ik_abs_env_cfg.FrankaReachEnvCfg'> |
| 69 | Isaac-Reach-Franka-IK-Rel-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.franka.ik_rel_env_cfg.FrankaReachEnvCfg'> |
| 70 | Isaac-Reach-UR10-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.ur_10.joint_pos_env_cfg.UR10ReachEnvCfg'> |
| 71 | Isaac-Reach-UR10-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.manipulation.reach.config.ur_10.joint_pos_env_cfg.UR10ReachEnvCfg_PLAY'> |
| 72 | Isaac-Navigation-Flat-Anymal-C-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.navigation.config.anymal_c.navigation_env_cfg.NavigationEnvCfg'> |
| 73 | Isaac-Navigation-Flat-Anymal-C-Play-v0 | omni.isaac.lab.envs:ManagerBasedRLEnv | <class 'omni.isaac.lab_tasks.manager_based.navigation.config.anymal_c.navigation_env_cfg.NavigationEnvCfg_PLAY'> |
