I need to use the Jetson nano EMMC module on the nano 2GB carrier board
The USB interface cannot recognize the new device. What do I need to do to make it recognize normally.
It’s strange that 2GB modules are OK for other carrier board, but 4GB modules are not good for 2GB carrier board.
Can USB be used on by modifying the device tree?
I checked the same problem in the forum and found that it was not solved in the end. If there is any possibility to solve it, please give me some guidance and I can try it
I think the logic here is wrong. You should file a topic and ask why the usb interface cannot recognize your device but not trying to use a board that is not compatible.
