I2C device not detected in u-boot
i2c device is not detecting in u-boot. while the same device is detected in linux when changed bus clock-frequency to 100 Mhz from 400 Mhz in dtb.
u-boot level bus clock-frequency is also 100 Mhz still not detecting !!
–Thanks
@shrinathchoudhary
Why do you need to access the device in u-boot?
Could you probe to check if host send the access command from the bus.
ShaneCCC
I need to configure the device from i2c.
from jetson u-boot it is failing to list device after scan ( i2c probe ).
when used power-pc u-boot it is listing
OK please have probe the bus to check if any signal from the host bus to clarify the problem.
Hi shrinathchoudhary,
Is this still an issue? Any result can be shared?
We haven’t heard back from you in a couple weeks, so marking this topic is not an issue now.
Please open a new forum issue when you are ready and we’ll pick it up there.
