If I reset the SX6036G to factory default settings, can the subnet manager and gateway functions continue to be used?
Or is it necessary to install the license again?
Hello Takahashi-Sama,
Hope you are doing well.
Based on the information provided, page 263 from the MLNX_OS UM (version 3.6.8012), will explain in which combination of the ‘reset-factory’ command will delete the licenses or retain the licenses.
You can download the UM through the following link → Salesforce
Many thanks,
~Mellanox Technical Support
