I am trying to flash an image created using meta-tegra yocto pkg by setting “MACHINE ?= “jetson-agx-orin-devkit-industrial”” in local.conf. Flashing is completed successfully but nothing got displayed on attached monitor ( even nvidia boot screen doest come up and lsusb shows the productid as 7023). The build created the same way for AGX Orin (MACHINE ?= “jetson-agx-orin-devkit”) works fine. Creating the image using “bitbake core-image-sato-dev”.
Below are the flash logs of IGX Orin:
tc@tc106:~/jetson-agx-orin-devkit-industrial.tegraflash$ sudo ./doflash.sh
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0174 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0179 ] File rcm_state open failed
[ 0.0184 ] ERROR: failed to read rcm_state
[ 0.0184 ]
[ 0.0225 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0226 ] Assuming zero filled SBK key
[ 0.0187 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0328 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008-flash.dts
[ 0.0495 ] Parsing partition layout
[ 0.0501 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0517 ] Kernel DTB used: None
[ 0.0517 ] WARNING: dce base dtb is not provided
[ 0.0518 ] Parsing partition layout
[ 0.0524 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0535 ] Creating list of images to be signed
[ 0.0539 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0542 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0557 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0563 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0623 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0628 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0672 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0677 ] adding BCH for mb2_t234_aligned.bin
[ 0.0703 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0835 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0844 ] adding BCH for mb2_t234_aligned.bin
[ 0.0987 ] Filling MB1 storage info
[ 0.0987 ] Parsing dev params for multi chains
[ 0.1093 ] Generating br-bct
[ 0.1099 ] Updating dev and MSS params in BR BCT
[ 0.1099 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1108 ] Updating bl info
[ 0.1112 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1114 ] WARNING: boot chain is not completed. set to 0
[ 0.1129 ] Generating signatures
[ 0.1170 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1171 ] Assuming zero filled SBK key
[ 0.1296 ] Warning: pub_key.key is not found
[ 0.1259 ] Parsing dev params for multi chains
[ 0.1259 ] Generating br-bct
[ 0.1264 ] Updating dev and MSS params in BR BCT
[ 0.1265 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1277 ] Updating bl info
[ 0.1280 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1284 ] WARNING: boot chain is not completed. set to 0
[ 0.1310 ] Get Signed section of bct
[ 0.1316 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1327 ] Signing BCT
[ 0.1368 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1369 ] Assuming zero filled SBK key
[ 0.1391 ] Sha saved in br_bct_BR.sha
[ 0.1394 ] Warning: pub_key.key is not found
[ 0.1354 ] Updating BCT with signature
[ 0.1357 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1360 ] Offset :4608 Len :3584
[ 0.1367 ] Generating SHA2 Hash
[ 0.1407 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1408 ] Assuming zero filled SBK key
[ 0.1432 ] Sha saved in br_bct_BR.sha
[ 0.1395 ] Updating BCT with SHA2 Hash
[ 0.1398 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1402 ] Offset :4608 Len :3584
[ 0.1408 ] Offset :68 Len :8124
[ 0.1410 ] Generating coldboot mb1-bct
[ 0.1415 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1418 ] MB1-BCT version: 0.13
[ 0.1422 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 0.1453 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 0.1465 ]
[ 0.1465 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1465 ] Added Platform Config 9 data with size :- 100
[ 0.1465 ]
[ 0.1466 ] Updating mb1-bct with firmware information
[ 0.1471 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1487 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1490 ] Generating SHA2 Hash for mb1bct
[ 0.1541 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.1550 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.1514 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1517 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1574 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1575 ] Assuming zero filled SBK key
[ 0.1587 ] Warning: pub_key.key is not found
[ 0.1551 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1564 ] Generating recovery mb1-bct
[ 0.1571 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1576 ] MB1-BCT version: 0.13
[ 0.1580 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 0.1607 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 0.1623 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1626 ] Added Platform Config 9 data with size :- 100
[ 0.1626 ]
[ 0.1626 ] Updating mb1-bct with firmware information
[ 0.1630 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1642 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1649 ] Generating SHA2 Hash for mb1bct
[ 0.1699 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.1707 ] Sha saved in mb1_bct_MB1.sha
[ 0.1671 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1674 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1725 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1726 ] Assuming zero filled SBK key
[ 0.1738 ] Warning: pub_key.key is not found
[ 0.1703 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1716 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1716 ] Copying signatures
[ 0.1720 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1800 ] Boot Rom communication
[ 0.1810 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1817 ] BR_CID: 0x80012344705DE2C02C0000000B000280
[ 0.1828 ] Sending bct_br
[ 0.1831 ] Sending mb1
[ 0.1840 ] Sending psc_bl1
[ 0.1954 ] Sending bct_mb1
[ 0.2018 ] Boot Rom communication completed
[ 0.2034 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.2043 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.2046 ] adding BCH for applet_t234_aligned.bin
[ 0.2207 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2209 ] Assuming zero filled SBK key
[ 0.2236 ] Warning: pub_key.key is not found
[ 0.2201 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.2230 ] Sending mb2_applet...
[ 0.2233 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.2237 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.4089 ] Sending applet
[ 0.5181 ] completed
[ 0.5191 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.5198 ] MB2 Applet version 01.00.0000
[ 0.7261 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7269 ] MB2 Applet version 01.00.0000
[ 0.7312 ] Retrieving board information
[ 0.7320 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 0.7328 ] MB2 Applet version 01.00.0000
[ 0.7364 ] Saved platform info in chip_info.bin
[ 0.7428 ] Chip minor revision: 1
[ 0.7430 ] Bootrom revision: 0x7
[ 0.7432 ] Ram code: 0x4
[ 0.7434 ] Chip sku: 0x90
[ 0.7436 ] Chip Sample: prod
[ 0.7440 ] Retrieving EEPROM data
[ 0.7440 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/tc/jetson-agx-orin-devkit-industrial.tegraflash/cvm.bin.wSVzM --chip 0x23 0
[ 0.7445 ] MB2 Applet version 01.00.0000
[ 0.7483 ] Saved platform info in /home/tc/jetson-agx-orin-devkit-industrial.tegraflash/cvm.bin.wSVzM
[ 0.7839 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7845 ] MB2 Applet version 01.00.0000
[ 0.7888 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.7893 ] MB2 Applet version 01.00.0000
[ 0.7931 ] Dumping customer Info
[ 0.7935 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 0.7941 ] MB2 Applet version 01.00.0000
[ 0.7980 ] Saved bct in tmp.bct
[ 0.8078 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/tc/jetson-agx-orin-devkit-industrial.tegraflash/custinfo_out.bin
[ 0.8085 ] Customer data saved in /home/tc[ 0.8093 ] /jetson-agx-orin-devkit-industrial.tegraflash/custinfo_out.bin successfully
[ 0.8093 ] Rebooting to recovery mode
[ 0.8097 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 0.8149 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.8155 ] MB2 Applet version 01.00.0000
[ 0.8189 ] Booting to recovery mode
[ 0.8195 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 0.8201 ] MB2 Applet version 01.00.0000
Board ID(3701) version(500) sku(0008) revision(P.0)
Creating sparseimage core-image-sato-dev.ext4.img...
version 1.0.0
[ 0.0253 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0254 ] Assuming zero filled SBK key
[ 0.0211 ] Parsing partition layout
[ 0.0220 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0298 ] Change tegra234-bpmp-3701-0008-3737-0000.dtb to tegra234-bpmp-3701-0008-3737-0000_with_odm.dtb
[ 0.0620 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0008-3737-0000_with_odm.dtb tegra234-bpmp-3701-0008-3737-0000_with_odm_tmp.dtb
[ 0.0626 ] /home/tc/jetson-agx-orin-devkit-industrial.tegraflash/1255615/dtbcheck.py:192: SyntaxWarning: invalid escape sequence '\+'
[ 0.0813 ] node_chars = '[0-9A-Za-z\+,\-\._]'
[ 0.0820 ] /home/tc/jetson-agx-orin-devkit-industrial.tegraflash/1255615/dtbcheck.py:195: SyntaxWarning: invalid escape sequence '\+'
[ 0.0836 ] prop_chars = '[0-9A-Za-z#\+,\-\.\?_]'
[ 0.4575 ] Concatenating L4TConfiguration.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-overlay.dtbo to tegra234-p3701-0008-p3737-0000_with_odm_overlay.dtb
[ 0.4592 ] Concatenating bl dtb to cpubl binary
[ 0.4641 ] MB2 binary: mb2_t234.bin
[ 0.4642 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0008.dts
[ 0.4835 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[ 0.9448 ] Generating coldboot mb2-bct
[ 0.9449 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0008_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[ 0.9457 ] ERROR: value 0x31 is out of range
[ 0.9502 ] ERROR: value 0x31 is out of range
[ 0.9506 ] ERROR: value 0x31 is out of range
[ 0.9509 ] ERROR: value 0x31 is out of range
[ 0.9512 ] WARNING: unknown property 'tfc_version'
[ 0.9518 ] WARNING: unknown property 'addr_header_version'
[ 0.9620 ] Updating mb2-bct with storage information
[ 0.9626 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.9649 ] Concatenating mb2-bct to mb2 binary
[ 0.9649 ] mb2_bin_file = mb2_t234.bin
[ 0.9650 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.9707 ] DCE binary: display-t234-dce.bin
[ 0.9708 ] Kernel DTB used: kernel_tegra234-p3701-0008-p3737-0000.dtb
[ 0.9708 ] Concatenating kernel-dtb to dce-fw binary
[ 0.9708 ] dce_bin = display-t234-dce.bin
[ 0.9708 ] kernel_dtb = kernel_tegra234-p3701-0008-p3737-0000.dtb
[ 0.9709 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000.bin
[ 0.9810 ] Update display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000.bin to dce_fw partitions
[ 0.9834 ] Parsing partition layout
[ 0.9840 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.9866 ] Creating list of images to be signed
[ 0.9877 ] Generating ratchet blob
[ 0.9878 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[ 0.9998 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 1.0114 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[ 1.0228 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[ 1.0364 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0008-flash.dts
[ 1.0576 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[ 1.0801 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[ 1.0934 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0000.dts
[ 1.1093 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[ 1.1231 ] Pre-processing config: tegra234-p3701-0008-sdram-l4t.dts
[ 1.8618 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[ 1.8740 ] Pre-processing config: tegra234-p3701-0008-wb0sdram-l4t.dts
[ 2.6099 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[ 2.6254 ] Generating coldboot mb1-bct
[ 2.6262 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --wb0sdram tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 2.6267 ] MB1-BCT version: 0.13
[ 2.6271 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 2.6304 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 2.6312 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 2.6320 ] Added Platform Config 0 data with size :- 2936
[ 2.6341 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 2.6345 ] WARNING: unknown node 'g2'
[ 2.6346 ] WARNING: unknown node 'g2'
[ 2.6349 ] WARNING: unknown node 'g9'
[ 2.6349 ] Added Platform Config 2 data with size :- 24
[ 2.6349 ]
[ 2.6349 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 2.6349 ] Added Platform Config 4 data with size :- 532
[ 2.6349 ]
[ 2.6349 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 2.6349 ] Added Platform Config 3 data with size :- 52
[ 2.6349 ]
[ 2.6349 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 2.6349 ] WARNING: unknown property 'major'
[ 2.6349 ] WARNING: unknown property 'minor'
[ 2.6349 ] Added Platform Config 5 data with size :- 524
[ 2.6349 ]
[ 2.6350 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 2.6350 ] WARNING: unknown property 'major'
[ 2.6350 ] WARNING: unknown property 'minor'
[ 2.6350 ] Added Platform Config 7 data with size :- 380
[ 2.6350 ]
[ 2.6350 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 2.6350 ] Added Platform Config 8 data with size :- 24
[ 2.6350 ]
[ 2.6350 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 2.6350 ] Added Platform Config 9 data with size :- 100
[ 2.6350 ]
[ 2.6350 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 2.6350 ] ModuleCount 0 NumProdNames 0
[ 2.6350 ] Added Platform Config 6 data with size :- 16
[ 2.6350 ]
[ 2.6350 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 2.6351 ]
[ 2.6351 ] Updating mb1-bct with firmware information
[ 2.6356 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.6370 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 2.6374 ] Generating SHA2 Hash for mb1bct
[ 2.6466 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 2.6487 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 2.6452 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 2.6457 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 2.6526 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.6527 ] Assuming zero filled SBK key
[ 2.6538 ] Warning: pub_key.key is not found
[ 2.6499 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 2.6516 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 2.6519 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 2.6544 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 2.6549 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 2.6607 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 2.6613 ] Header already present for nvdec_t234_prod_aligned.fw
[ 2.6642 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 2.6702 ] adding BCH for xusb_t234_prod_aligned.bin
[ 2.6843 ] Header already present for bpmp_t234-TE992M-A1_prod_aligned.bin
[ 2.6938 ] adding BCH for tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 2.7104 ] Header already present for pscfw_t234_prod_aligned.bin
[ 2.7160 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 2.7229 ] Header already present for sc7_t234_prod.bin
[ 2.7266 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 2.7302 ] adding BCH for mb2rf_t234_aligned.bin
[ 2.7326 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 2.7969 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 87%
[ 2.8031 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 2.8572 ] adding BCH for tos-optee_t234_aligned.img
[ 2.9092 ] adding BCH for eks_aligned.img
[ 2.9521 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin
[ 3.1219 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin, ratio = 7%
[ 3.1400 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 3.1588 ] adding BCH for fsi-fw-ecc_aligned.bin
[ 3.1887 ] adding BCH for spe_t234_aligned.bin
[ 3.3712 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 3.3814 ] adding BCH for adsp-fw_aligned.bin
[ 3.3992 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 3.4126 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 3.4136 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 3.4177 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 3.4184 ] Header already present for nvdec_t234_prod_aligned.fw
[ 3.4202 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 3.4265 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.4403 ] Header already present for bpmp_t234-TE992M-A1_prod_aligned.bin
[ 3.4486 ] adding BCH for tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 3.4657 ] Header already present for pscfw_t234_prod_aligned.bin
[ 3.4709 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 3.4775 ] Header already present for sc7_t234_prod.bin
[ 3.4805 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 3.4842 ] adding BCH for mb2rf_t234_aligned.bin
[ 3.4864 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 3.5516 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 87%
[ 3.5580 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 3.6138 ] adding BCH for tos-optee_t234_aligned.img
[ 3.6665 ] adding BCH for eks_aligned.img
[ 3.7063 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin
[ 3.8785 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin, ratio = 7%
[ 3.8966 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_blob_w_bin_aligned.bin
[ 3.9152 ] adding BCH for fsi-fw-ecc_aligned.bin
[ 3.9438 ] adding BCH for spe_t234_aligned.bin
[ 4.1275 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 4.1368 ] adding BCH for adsp-fw_aligned.bin
[ 4.1670 ] Filling MB1 storage info
[ 4.1670 ] Parsing dev params for multi chains
[ 4.1830 ] Generating br-bct
[ 4.1839 ] Updating dev and MSS params in BR BCT
[ 4.1839 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 4.2731 ] Updating bl info
[ 4.2741 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 4.2894 ] Generating br-bct
[ 4.2900 ] Updating dev and MSS params in BR BCT
[ 4.2901 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 4.3751 ] Updating bl info
[ 4.3760 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 4.3786 ] Generating BCT backup image
[ 4.3786 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 4.3791 ] 32768+0 records in
[ 4.4017 ] 32768+0 records out
[ 4.4018 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0211795 s, 1,5 MB/s
[ 4.4018 ]
[ 4.4018 ] Concatenating BCT for chain A to bct_backup.img
[ 4.4018 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 4.4023 ] 8192+0 records in
[ 4.4134 ] 8192+0 records out
[ 4.4135 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00959139 s, 854 kB/s
[ 4.4135 ]
[ 4.4135 ] Concatenating BCT for chain B to bct_backup.img
[ 4.4135 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 4.4145 ] 8192+0 records in
[ 4.4284 ] 8192+0 records out
[ 4.4284 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,0125352 s, 654 kB/s
[ 4.4284 ]
[ 4.4284 ] Generating signatures
[ 4.4328 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.4330 ] Assuming zero filled SBK key
[ 4.5494 ] Warning: pub_key.key is not found
[ 4.5480 ] Parsing dev params for multi chains
[ 4.5480 ] Generating br-bct
[ 4.5484 ] Updating dev and MSS params in BR BCT
[ 4.5485 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 4.6393 ] Updating customer data section
[ 4.6403 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 4.6412 ] Updating bl info
[ 4.6419 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.6452 ] Get Signed section of bct
[ 4.6457 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 4.6463 ] Signing BCT
[ 4.6507 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.6509 ] Assuming zero filled SBK key
[ 4.6535 ] Sha saved in br_bct_BR.sha
[ 4.6537 ] Warning: pub_key.key is not found
[ 4.6493 ] Updating BCT with signature
[ 4.6497 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 4.6499 ] Offset :4608 Len :3584
[ 4.6505 ] Generating SHA2 Hash
[ 4.6549 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 4.6550 ] Assuming zero filled SBK key
[ 4.6572 ] Sha saved in br_bct_BR.sha
[ 4.6530 ] Updating BCT with SHA2 Hash
[ 4.6533 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 4.6536 ] Offset :4608 Len :3584
[ 4.6540 ] Offset :68 Len :8124
[ 4.6542 ] Generating br-bct
[ 4.6545 ] Updating dev and MSS params in BR BCT
[ 4.6545 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 4.7578 ] Updating customer data section
[ 4.7588 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 4.7604 ] Updating bl info
[ 4.7607 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.7648 ] Get Signed section of bct
[ 4.7652 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 4.7658 ] Signing BCT
[ 4.7702 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.7703 ] Assuming zero filled SBK key
[ 4.7728 ] Sha saved in br_bct_BR.sha
[ 4.7731 ] Warning: pub_key.key is not found
[ 4.7687 ] Updating BCT with signature
[ 4.7691 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 4.7694 ] Offset :4608 Len :3584
[ 4.7705 ] Generating SHA2 Hash
[ 4.7749 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 4.7750 ] Assuming zero filled SBK key
[ 4.7771 ] Sha saved in br_bct_BR.sha
[ 4.7730 ] Updating BCT with SHA2 Hash
[ 4.7733 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 4.7735 ] Offset :4608 Len :3584
[ 4.7738 ] Offset :68 Len :8124
[ 4.7741 ] Generating BCT backup image
[ 4.7741 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 4.7745 ] 32768+0 records in
[ 4.7970 ] 32768+0 records out
[ 4.7970 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0213433 s, 1,5 MB/s
[ 4.7970 ]
[ 4.7970 ] Concatenating BCT for chain A to bct_backup.img
[ 4.7971 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 4.7980 ] 8192+0 records in
[ 4.8076 ] 8192+0 records out
[ 4.8076 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00817181 s, 1,0 MB/s
[ 4.8076 ]
[ 4.8077 ] Concatenating BCT for chain B to bct_backup.img
[ 4.8077 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 4.8086 ] 8192+0 records in
[ 4.8202 ] 8192+0 records out
[ 4.8202 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,0102159 s, 802 kB/s
[ 4.8202 ]
[ 4.8203 ] Generating coldboot mb1-bct
[ 4.8211 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --wb0sdram tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 4.8218 ] MB1-BCT version: 0.13
[ 4.8223 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 4.8260 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 4.8267 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 4.8271 ] Added Platform Config 0 data with size :- 2936
[ 4.8298 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 4.8300 ] WARNING: unknown node 'g2'
[ 4.8300 ] WARNING: unknown node 'g9'
[ 4.8300 ] Added Platform Config 2 data with size :- 24
[ 4.8300 ]
[ 4.8300 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 4.8300 ] Added Platform Config 4 data with size :- 532
[ 4.8301 ]
[ 4.8301 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 4.8301 ] Added Platform Config 3 data with size :- 52
[ 4.8301 ]
[ 4.8301 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 4.8301 ] WARNING: unknown property 'major'
[ 4.8301 ] WARNING: unknown property 'minor'
[ 4.8302 ] Added Platform Config 5 data with size :- 524
[ 4.8302 ]
[ 4.8302 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 4.8302 ] WARNING: unknown property 'major'
[ 4.8302 ] WARNING: unknown property 'minor'
[ 4.8302 ] Added Platform Config 7 data with size :- 380
[ 4.8302 ]
[ 4.8303 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 4.8303 ] Added Platform Config 8 data with size :- 24
[ 4.8303 ]
[ 4.8303 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 4.8303 ] Added Platform Config 9 data with size :- 100
[ 4.8303 ]
[ 4.8303 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 4.8303 ] ModuleCount 0 NumProdNames 0
[ 4.8304 ] Added Platform Config 6 data with size :- 16
[ 4.8304 ]
[ 4.8304 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 4.8304 ]
[ 4.8305 ] Updating mb1-bct with firmware information
[ 4.8311 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.8322 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 4.8327 ] Generating SHA2 Hash for mb1bct
[ 4.8380 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 4.8391 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 4.8352 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 4.8355 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 4.8412 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8413 ] Assuming zero filled SBK key
[ 4.8430 ] Warning: pub_key.key is not found
[ 4.8391 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.8408 ] Generating recovery mb1-bct
[ 4.8412 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0008-flash_cpp.dtb --wb0sdram tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 4.8416 ] MB1-BCT version: 0.13
[ 4.8419 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_DATA/ is not supported
[ 4.8432 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_TEMP_QB_IO_BUFFER/ is not supported
[ 4.8441 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[ 4.8446 ] Added Platform Config 0 data with size :- 2936
[ 4.8472 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[ 4.8476 ] WARNING: unknown node 'g2'
[ 4.8476 ] WARNING: unknown node 'g9'
[ 4.8476 ] Added Platform Config 2 data with size :- 24
[ 4.8476 ]
[ 4.8476 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 4.8476 ] Added Platform Config 4 data with size :- 532
[ 4.8476 ]
[ 4.8476 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 4.8477 ] Added Platform Config 3 data with size :- 52
[ 4.8477 ]
[ 4.8477 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 4.8477 ] WARNING: unknown property 'major'
[ 4.8477 ] WARNING: unknown property 'minor'
[ 4.8477 ] Added Platform Config 5 data with size :- 524
[ 4.8477 ]
[ 4.8477 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 4.8477 ] Added Platform Config 7 data with size :- 380
[ 4.8477 ]
[ 4.8477 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 4.8477 ] Added Platform Config 8 data with size :- 24
[ 4.8477 ]
[ 4.8477 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 4.8477 ] Added Platform Config 9 data with size :- 100
[ 4.8478 ]
[ 4.8478 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 4.8478 ] ModuleCount 0 NumProdNames 0
[ 4.8478 ] Added Platform Config 6 data with size :- 16
[ 4.8478 ]
[ 4.8478 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[ 4.8478 ]
[ 4.8478 ] Updating mb1-bct with firmware information
[ 4.8482 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 4.8492 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 4.8497 ] Generating SHA2 Hash for mb1bct
[ 4.8550 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 4.8559 ] Sha saved in mb1_bct_MB1.sha
[ 4.8519 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 4.8522 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 4.8578 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.8579 ] Assuming zero filled SBK key
[ 4.8595 ] Warning: pub_key.key is not found
[ 4.8556 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.8574 ] Generating coldboot mem-bct
[ 4.8579 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0008-sdram-l4t_cpp_1.bct tegra234-p3701-0008-sdram-l4t_cpp_2.bct tegra234-p3701-0008-sdram-l4t_cpp_3.bct tegra234-p3701-0008-sdram-l4t_cpp_4.bct
[ 4.8582 ] packing sdram params with Wb0 file tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb
[ 4.9514 ] Packing sdram param for instance[0]
[ 4.9519 ] Packing sdram param for instance[1]
[ 4.9524 ] Packing sdram param for instance[2]
[ 4.9529 ] Packing sdram param for instance[3]
[ 4.9534 ] Packing sdram param for instance[4]
[ 4.9539 ] Packing sdram param for instance[5]
[ 4.9544 ] Packing sdram param for instance[6]
[ 4.9549 ] Packing sdram param for instance[7]
[ 4.9552 ] Packing sdram param for instance[8]
[ 4.9556 ] Packing sdram param for instance[9]
[ 4.9560 ] Packing sdram param for instance[10]
[ 4.9564 ] Packing sdram param for instance[11]
[ 4.9567 ] Packing sdram param for instance[12]
[ 4.9571 ] Packing sdram param for instance[13]
[ 4.9575 ] Packing sdram param for instance[14]
[ 4.9579 ] Packing sdram param for instance[15]
[ 5.0406 ] Getting sector size from pt
[ 5.0415 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 5.0424 ] BlockSize read from layout is 0x200
[ 5.0432 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0008-sdram-l4t_cpp_1.bct tegra234-p3701-0008-sdram-l4t_cpp_2.bct tegra234-p3701-0008-sdram-l4t_cpp_3.bct tegra234-p3701-0008-sdram-l4t_cpp_4.bct --ratchet_blob ratchet_blob.bin
[ 5.0437 ] Binary 0 length is 58752
[ 5.0440 ] Binary 0 align length is 58880
[ 5.0454 ] Binary 1 length is 58752
[ 5.0455 ] Binary 1 align length is 58880
[ 5.0470 ] Binary 2 length is 58752
[ 5.0473 ] Binary 2 align length is 58880
[ 5.0481 ] Binary 3 length is 58752
[ 5.0484 ] Binary 3 align length is 58880
[ 5.0490 ] Buffer length is 235520
[ 5.0491 ] adding BCH for tegra234-p3701-0008-sdram-l4t_cpp_1.bct
[ 5.0493 ] new length is 243712
[ 5.0493 ]
[ 5.0501 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 5.0508 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 5.0512 ] Header already present for mem_coldboot_aligned.bct
[ 5.0577 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.0578 ] Assuming zero filled SBK key
[ 5.0597 ] Warning: pub_key.key is not found
[ 5.0559 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 5.0584 ] Generating recovery mem-bct
[ 5.0588 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0008-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0008-sdram-l4t_cpp_1.bct tegra234-p3701-0008-sdram-l4t_cpp_2.bct tegra234-p3701-0008-sdram-l4t_cpp_3.bct tegra234-p3701-0008-sdram-l4t_cpp_4.bct
[ 5.0591 ] packing sdram params with Wb0 file tegra234-p3701-0008-wb0sdram-l4t_cpp.dtb
[ 5.1502 ] Packing sdram param for instance[0]
[ 5.1507 ] Packing sdram param for instance[1]
[ 5.1511 ] Packing sdram param for instance[2]
[ 5.1515 ] Packing sdram param for instance[3]
[ 5.1519 ] Packing sdram param for instance[4]
[ 5.1523 ] Packing sdram param for instance[5]
[ 5.1528 ] Packing sdram param for instance[6]
[ 5.1532 ] Packing sdram param for instance[7]
[ 5.1535 ] Packing sdram param for instance[8]
[ 5.1536 ] Packing sdram param for instance[9]
[ 5.1538 ] Packing sdram param for instance[10]
[ 5.1539 ] Packing sdram param for instance[11]
[ 5.1540 ] Packing sdram param for instance[12]
[ 5.1542 ] Packing sdram param for instance[13]
[ 5.1543 ] Packing sdram param for instance[14]
[ 5.1544 ] Packing sdram param for instance[15]
[ 5.2385 ] Got ramcode 4 from the command line
[ 5.2386 ] Using ramcode 1
[ 5.2386 ] Disabled BPMP dtb trim, using default dtb
[ 5.2386 ]
[ 5.2401 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 5.2416 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 5.2420 ] adding BCH for mem_rcm_aligned.bct
[ 5.2514 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.2515 ] Assuming zero filled SBK key
[ 5.2534 ] Warning: pub_key.key is not found
[ 5.2496 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 5.2518 ] Copying signatures
[ 5.2523 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 5.3330 ] Boot Rom communication
[ 5.3345 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 5.3354 ] BR_CID: 0x80012344705DE2C02C0000000B000280
[ 5.3376 ] Sending bct_br
[ 5.3378 ] Sending mb1
[ 5.3383 ] Sending psc_bl1
[ 5.3482 ] Sending bct_mb1
[ 5.3543 ] Boot Rom communication completed
[ 5.3544 ] Generating blob for T23x
[ 5.3591 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_with_dtb_aligned.bin
[ 5.3602 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[ 5.3606 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[ 5.4786 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.4788 ] Assuming zero filled SBK key
[ 5.4908 ] Warning: pub_key.key is not found
[ 5.4872 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 5.5041 ] Get magic id
[ 5.5053 ] tegraparser_v2 --get_magic psc_fw
[ 5.5058 ] PFWP
[ 5.5062 ] partition type psc_fw, magic id = PFWP
[ 5.5069 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[ 5.5081 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[ 5.5085 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[ 5.5216 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.5219 ] Assuming zero filled SBK key
[ 5.5243 ] Warning: pub_key.key is not found
[ 5.5205 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 5.5233 ] Get magic id
[ 5.5237 ] tegraparser_v2 --get_magic mts_mce
[ 5.5240 ] MTSM
[ 5.5242 ] partition type mts_mce, magic id = MTSM
[ 5.5251 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[ 5.5262 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 5.5266 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[ 5.5371 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.5372 ] Assuming zero filled SBK key
[ 5.5401 ] Warning: pub_key.key is not found
[ 5.5366 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 5.5397 ] Get magic id
[ 5.5403 ] tegraparser_v2 --get_magic mb2_applet
[ 5.5409 ] MB2A
[ 5.5413 ] partition type mb2_applet, magic id = MB2A
[ 5.5428 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[ 5.5439 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[ 5.5443 ] adding BCH for blob_applet_t234_aligned.bin
[ 5.5608 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.5610 ] Assuming zero filled SBK key
[ 5.5637 ] Warning: pub_key.key is not found
[ 5.5599 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[ 5.5640 ] Generating recovery mb2-bct
[ 5.5640 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0008_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[ 5.5646 ] ERROR: value 0x31 is out of range
[ 5.5656 ] ERROR: value 0x31 is out of range
[ 5.5657 ] ERROR: value 0x31 is out of range
[ 5.5658 ] ERROR: value 0x31 is out of range
[ 5.5659 ] WARNING: unknown property 'tfc_version'
[ 5.5665 ] WARNING: unknown property 'addr_header_version'
[ 5.5795 ] Updating mb2-bct with storage information
[ 5.5805 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 5.5816 ] Concatenating mb2-bct to mb2 binary
[ 5.5816 ] mb2_bin_file = mb2_t234.bin
[ 5.5816 ] mb2_bct_file = mb2_bct_MB2.bct
[ 5.5823 ] Get magic id
[ 5.5828 ] tegraparser_v2 --get_magic mb2_bootloader
[ 5.5833 ] MB2B
[ 5.5836 ] partition type mb2_bootloader, magic id = MB2B
[ 5.5844 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 5.5854 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 5.5857 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 5.6070 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.6072 ] Assuming zero filled SBK key
[ 5.6099 ] Warning: pub_key.key is not found
[ 5.6060 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 5.6102 ] Get magic id
[ 5.6108 ] tegraparser_v2 --get_magic xusb_fw
[ 5.6114 ] XUSB
[ 5.6117 ] partition type xusb_fw, magic id = XUSB
[ 5.6125 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[ 5.6136 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[ 5.6140 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[ 5.6267 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.6269 ] Assuming zero filled SBK key
[ 5.6294 ] Warning: pub_key.key is not found
[ 5.6256 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 5.6273 ] Kernel DTB used: kernel_tegra234-p3701-0008-p3737-0000.dtb
[ 5.6273 ] Concatenating kernel-dtb to dce-fw binary
[ 5.6273 ] dce_bin = display-t234-dce.bin
[ 5.6273 ] kernel_dtb = kernel_tegra234-p3701-0008-p3737-0000.dtb
[ 5.6273 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000.bin
[ 5.6372 ] Get magic id
[ 5.6378 ] tegraparser_v2 --get_magic dce_fw
[ 5.6383 ] DCEF
[ 5.6386 ] partition type dce_fw, magic id = DCEF
[ 5.6456 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin
[ 5.6466 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin zerosbk
[ 5.6469 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned.bin
[ 5.9626 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.9628 ] Assuming zero filled SBK key
[ 5.9936 ] Warning: pub_key.key is not found
[ 5.9900 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_sigheader.bin.hash zerosbk
[ 6.0176 ] Get magic id
[ 6.0185 ] tegraparser_v2 --get_magic nvdec
[ 6.0191 ] NDEC
[ 6.0195 ] partition type nvdec, magic id = NDEC
[ 6.0205 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[ 6.0218 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[ 6.0222 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[ 6.0347 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.0349 ] Assuming zero filled SBK key
[ 6.0376 ] Warning: pub_key.key is not found
[ 6.0338 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 6.0354 ] Get magic id
[ 6.0359 ] tegraparser_v2 --get_magic bpmp_fw
[ 6.0364 ] BPMF
[ 6.0368 ] partition type bpmp_fw, magic id = BPMF
[ 6.0383 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE992M-A1_prod_aligned.bin
[ 6.0394 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE992M-A1_prod_aligned.bin zerosbk
[ 6.0397 ] Header already present for blob_bpmp_t234-TE992M-A1_prod_aligned.bin
[ 6.0636 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.0638 ] Assuming zero filled SBK key
[ 6.0675 ] Warning: pub_key.key is not found
[ 6.0637 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE992M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 6.0703 ] Using bpmp-dtb concatenated with odmdata in blob
[ 6.0704 ] Get magic id
[ 6.0709 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 6.0714 ] BPMD
[ 6.0718 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 6.0725 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 6.0737 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb zerosbk
[ 6.0742 ] adding BCH for blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned.dtb
[ 6.0868 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.0870 ] Assuming zero filled SBK key
[ 6.0900 ] Warning: pub_key.key is not found
[ 6.0861 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 6.0889 ] Get magic id
[ 6.0896 ] tegraparser_v2 --get_magic sce_fw
[ 6.0902 ] SCEF
[ 6.0904 ] partition type sce_fw, magic id = SCEF
[ 6.0917 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-sce_aligned.img
[ 6.0928 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[ 6.0932 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[ 6.1060 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.1062 ] Assuming zero filled SBK key
[ 6.1089 ] Warning: pub_key.key is not found
[ 6.1053 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[ 6.1074 ] Get magic id
[ 6.1078 ] tegraparser_v2 --get_magic rce_fw
[ 6.1083 ] RCEF
[ 6.1086 ] partition type rce_fw, magic id = RCEF
[ 6.1096 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[ 6.1109 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[ 6.1112 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[ 6.1352 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.1354 ] Assuming zero filled SBK key
[ 6.1386 ] Warning: pub_key.key is not found
[ 6.1347 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 6.1367 ] Get magic id
[ 6.1373 ] tegraparser_v2 --get_magic ape_fw
[ 6.1378 ] APEF
[ 6.1383 ] partition type ape_fw, magic id = APEF
[ 6.1393 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[ 6.1404 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[ 6.1407 ] adding BCH for blob_adsp-fw_aligned.bin
[ 6.1635 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.1637 ] Assuming zero filled SBK key
[ 6.1666 ] Warning: pub_key.key is not found
[ 6.1628 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 6.1644 ] Get magic id
[ 6.1650 ] tegraparser_v2 --get_magic spe_fw
[ 6.1654 ] SPEF
[ 6.1656 ] partition type spe_fw, magic id = SPEF
[ 6.1664 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[ 6.1676 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[ 6.1680 ] adding BCH for blob_spe_t234_aligned.bin
[ 6.1840 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.1842 ] Assuming zero filled SBK key
[ 6.1868 ] Warning: pub_key.key is not found
[ 6.1830 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[ 6.1853 ] Get magic id
[ 6.1858 ] tegraparser_v2 --get_magic fsi_fw
[ 6.1863 ] FSIF
[ 6.1866 ] partition type fsi_fw, magic id = FSIF
[ 6.1913 ] tegrahost_v2 --chip 0x23 0 --align blob_fsi-fw-ecc_aligned.bin
[ 6.1924 ] tegrahost_v2 --chip 0x23 0 --magicid FSIF --ratchet_blob ratchet_blob.bin --appendsigheader blob_fsi-fw-ecc_aligned.bin zerosbk
[ 6.1928 ] adding BCH for blob_fsi-fw-ecc_aligned.bin
[ 6.3859 ] tegrasign_v3.py --key None --list blob_fsi-fw-ecc_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.3862 ] Assuming zero filled SBK key
[ 6.3995 ] Warning: pub_key.key is not found
[ 6.3959 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_fsi-fw-ecc_aligned_sigheader.bin.encrypt blob_fsi-fw-ecc_aligned_sigheader.bin.hash zerosbk
[ 6.4143 ] Get magic id
[ 6.4150 ] tegraparser_v2 --get_magic tos
[ 6.4154 ] TOSB
[ 6.4155 ] partition type tos, magic id = TOSB
[ 6.4171 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[ 6.4184 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[ 6.4189 ] adding BCH for blob_tos-optee_t234_aligned.img
[ 6.4665 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.4667 ] Assuming zero filled SBK key
[ 6.4709 ] Warning: pub_key.key is not found
[ 6.4673 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 6.4765 ] Get magic id
[ 6.4776 ] tegraparser_v2 --get_magic eks
[ 6.4782 ] EKSB
[ 6.4786 ] partition type eks, magic id = EKSB
[ 6.4792 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_aligned.img
[ 6.4804 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_aligned.img zerosbk
[ 6.4808 ] adding BCH for blob_eks_aligned.img
[ 6.4862 ] tegrasign_v3.py --key None --list blob_eks_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.4863 ] Assuming zero filled SBK key
[ 6.4878 ] Warning: pub_key.key is not found
[ 6.4839 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_aligned_sigheader.img.encrypt blob_eks_aligned_sigheader.img.hash zerosbk
[ 6.4864 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 6.4868 ] The number of images in blob is 17
[ 6.4876 ] blobsize is 24283616
[ 6.4877 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3416128
[ 6.5054 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 6.5064 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 6.5070 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 6.5075 ] Not supported type: mb2_applet
[ 6.5076 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 437264
[ 6.5080 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 6.5084 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_sigheader.bin.encrypt of size 9536080
[ 6.5171 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 6.5199 ] Added binary blob_bpmp_t234-TE992M-A1_prod_sigheader.bin.encrypt of size 1046080
[ 6.5203 ] Added binary blob_tegra234-bpmp-3701-0008-3737-0000_with_odm_sigheader.dtb.encrypt of size 151168
[ 6.5209 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 6.5212 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 540000
[ 6.5217 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 6.5221 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 6.5224 ] Added binary blob_fsi-fw-ecc_sigheader.bin.encrypt of size 5746688
[ 6.5262 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1259424
[ 6.5291 ] Added binary blob_eks_sigheader.img.encrypt of size 9232
[ 6.5449 ] Sending membct and RCM blob
[ 6.5458 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 6.5465 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 6.5473 ] Sending bct_mem
[ 6.5477 ] Sending blob
[ 9.6538 ] completed
[ 9.6538 ] Retrieving storage infomation
[ 9.6549 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails storage storage_info.bin
[ 9.6559 ] MB2 version 01.00.0000
[ 10.3355 ] Saved platform info in storage_info.bin
[ 11.3427 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 11.3474 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 11.3481 ] MB2 version 01.00.0000
[ 11.3503 ] Flashing the device
[ 11.3509 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 11.3514 ] gpt_secondary_3_0.bin:
[ 11.3525 ] partition_id partition_name StartingLba EndingLba
[ 11.3528 ] 1 BCT 0 2047
[ 11.3534 ] 2 A_mb1 2048 3071
[ 11.3539 ] 3 A_psc_bl1 3072 3583
[ 11.3545 ] 4 A_MB1_BCT 3584 3839
[ 11.3550 ] 5 A_MEM_BCT 3840 4351
[ 11.3554 ] 6 A_tsec-fw 4352 6399
[ 11.3557 ] 7 A_nvdec 6400 8447
[ 11.3561 ] 8 A_mb2 8448 9471
[ 11.3566 ] 9 A_xusb-fw 9472 9983
[ 11.3568 ] 10 A_bpmp-fw 9984 13055
[ 11.3571 ] 11 A_bpmp-fw-dtb 13056 19199
[ 11.3574 ] 12 A_psc-fw 19200 20735
[ 11.3577 ] 13 A_mts-mce 20736 21759
[ 11.3579 ] 14 A_sc7 21760 22143
[ 11.3582 ] 15 A_pscrf 22144 22527
[ 11.3585 ] 16 A_mb2rf 22528 22783
[ 11.3587 ] 17 A_cpu-bootloader 22784 29951
[ 11.3590 ] 18 A_secure-os 29952 38143
[ 11.3593 ] 19 A_eks 38144 38655
[ 11.3596 ] 20 A_dce-fw 38656 42751
[ 11.3597 ] 21 A_fsi-fw 42752 55039
[ 11.3597 ] 22 A_spe-fw 55040 56191
[ 11.3597 ] 23 A_rce-fw 56192 58239
[ 11.3597 ] 24 A_adsp-fw 58240 62335
[ 11.3597 ] 25 A_reserved_on_boot 62336 63999
[ 11.3597 ] 26 B_mb1 64000 65023
[ 11.3597 ] 27 B_psc_bl1 65024 65535
[ 11.3597 ] 28 B_MB1_BCT 65536 65791
[ 11.3597 ] 29 B_MEM_BCT 65792 66303
[ 11.3597 ] 30 B_tsec-fw 66304 68351
[ 11.3597 ] 31 B_nvdec 68352 70399
[ 11.3597 ] 32 B_mb2 70400 71423
[ 11.3597 ] 33 B_xusb-fw 71424 71935
[ 11.3597 ] 34 B_bpmp-fw 71936 75007
[ 11.3597 ] 35 B_bpmp-fw-dtb 75008 81151
[ 11.3598 ] 36 B_psc-fw 81152 82687
[ 11.3598 ] 37 B_mts-mce 82688 83711
[ 11.3598 ] 38 B_sc7 83712 84095
[ 11.3598 ] 39 B_pscrf 84096 84479
[ 11.3598 ] 40 B_mb2rf 84480 84735
[ 11.3598 ] 41 B_cpu-bootloader 84736 91903
[ 11.3598 ] 42 B_secure-os 91904 100095
[ 11.3598 ] 43 B_eks 100096 100607
[ 11.3598 ] 44 B_dce-fw 100608 104703
[ 11.3598 ] 45 B_fsi-fw 104704 116991
[ 11.3598 ] 46 B_spe-fw 116992 118143
[ 11.3598 ] 47 B_rce-fw 118144 120191
[ 11.3598 ] 48 B_adsp-fw 120192 124287
[ 11.3598 ] 49 B_reserved_on_boot 124288 125951
[ 11.3598 ] 50 bad-page 125952 126975
[ 11.3599 ] 51 uefi_variables 126976 127487
[ 11.3599 ] 52 uefi_ftw 127488 128511
[ 11.3599 ] 53 worm 129920 130303
[ 11.3599 ] 54 BCT-boot-chain_backup 130304 130431
[ 11.3599 ] 55 reserved_partition 130432 130559
[ 11.3599 ] 56 secondary_gpt_backup 130560 130687
[ 11.3599 ] 57 B_VER 130688 130815
[ 11.3599 ] 58 A_VER 130816 130943
[ 11.3599 ] gpt_primary_1_3.bin:
[ 11.3599 ] partition_id partition_name StartingLba EndingLba
[ 11.3599 ] 1 APP 3050048 124321751
[ 11.3599 ] 2 A_kernel 40 262183
[ 11.3599 ] 3 A_kernel-dtb 262184 263719
[ 11.3599 ] 4 A_reserved_on_user 263720 328487
[ 11.3599 ] 5 B_kernel 328488 590631
[ 11.3599 ] 6 B_kernel-dtb 590632 592167
[ 11.3599 ] 7 B_reserved_on_user 592168 656935
[ 11.3599 ] 8 recovery 656936 820775
[ 11.3600 ] 9 recovery-dtb 820776 821799
[ 11.3600 ] 10 esp 821800 952871
[ 11.3600 ] 11 recovery_alt 952872 1116711
[ 11.3600 ] 12 recovery-dtb_alt 1116712 1117735
[ 11.3600 ] 13 esp_alt 1117736 1248807
[ 11.3600 ] 14 UDA 1248832 2068031
[ 11.3600 ] 15 reserved 2068032 3050047
[ 11.3600 ] gpt_secondary_1_3.bin:
[ 11.3600 ] partition_id partition_name StartingLba EndingLba
[ 11.3600 ] 1 APP 3050048 124321751
[ 11.3600 ] 2 A_kernel 40 262183
[ 11.3600 ] 3 A_kernel-dtb 262184 263719
[ 11.3600 ] 4 A_reserved_on_user 263720 328487
[ 11.3600 ] 5 B_kernel 328488 590631
[ 11.3600 ] 6 B_kernel-dtb 590632 592167
[ 11.3601 ] 7 B_reserved_on_user 592168 656935
[ 11.3601 ] 8 recovery 656936 820775
[ 11.3601 ] 9 recovery-dtb 820776 821799
[ 11.3601 ] 10 esp 821800 952871
[ 11.3601 ] 11 recovery_alt 952872 1116711
[ 11.3601 ] 12 recovery-dtb_alt 1116712 1117735
[ 11.3601 ] 13 esp_alt 1117736 1248807
[ 11.3601 ] 14 UDA 1248832 2068031
[ 11.3601 ] 15 reserved 2068032 3050047
[ 11.3601 ]
[ 11.3601 ] Start flashing
[ 11.3607 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 11.3609 ] Bootloader version 01.00.0000
[ 11.3642 ] Erasing spi: 0 ......... [Done]
[ 163.3785 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 163.3793 ] [................................................] 100%
[ 163.6011 ] Erasing sdmmc_user: 3 ......... [Done]
[ 163.9252 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 163.9259 ] [................................................] 100%
[ 163.9299 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 163.9324 ] [................................................] 100%
[ 163.9360 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 163.9466 ] [................................................] 100%
[ 163.9594 ] Writing partition A_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 282768 bytes ]
[ 163.9610 ] [................................................] 100%
[ 163.9719 ] Writing partition A_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 139264 bytes ]
[ 167.4510 ] [................................................] 100%
[ 167.4587 ] Writing partition A_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 169.1715 ] [................................................] 100%
[ 169.1867 ] Writing partition A_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 437264 bytes ]
[ 172.8082 ] [................................................] 100%
[ 172.8261 ] Writing partition A_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164864 bytes ]
[ 178.2007 ] [................................................] 100%
[ 178.2108 ] Writing partition A_bpmp-fw with bpmp_t234-TE992M-A1_prod_sigheader.bin.encrypt [ 1046080 bytes ]
[ 180.2371 ] [................................................] 100%
[ 180.2776 ] Writing partition A_bpmp-fw-dtb with tegra234-bpmp-3701-0008-3737-0000_with_odm_sigheader.dtb.encrypt [ 151168 bytes ]
[ 193.1182 ] [................................................] 100%
[ 193.1268 ] Writing partition A_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 375168 bytes ]
[ 194.9919 ] [................................................] 100%
[ 195.0092 ] Writing partition A_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 190592 bytes ]
[ 199.6185 ] [................................................] 100%
[ 199.6271 ] Writing partition A_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 186880 bytes ]
[ 201.9763 ] [................................................] 100%
[ 201.9855 ] Writing partition A_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 139264 bytes ]
[ 204.2821 ] [................................................] 100%
[ 204.2917 ] Writing partition A_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122048 bytes ]
[ 206.0049 ] [................................................] 100%
[ 206.0132 ] Writing partition A_cpu-bootloader with uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 2997600 bytes ]
[ 207.5200 ] [................................................] 100%
[ 233.3434 ] Writing partition A_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1259424 bytes ]
[ 244.3948 ] [................................................] 100%
[ 257.3050 ] Writing partition A_eks with eks_sigheader.img.encrypt [ 9232 bytes ]
[ 259.8987 ] [................................................] 100%
[ 259.9028 ] Writing partition A_dce-fw with display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_blob_w_bin_sigheader.bin.encrypt [ 757424 bytes ]
[ 260.0293 ] [................................................] 100%
[ 260.0569 ] Writing partition A_fsi-fw with fsi-fw-ecc_sigheader.bin.encrypt [ 5746688 bytes ]
[ 269.3561 ] [................................................] 100%
[ 333.8571 ] Writing partition A_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 340.0396 ] [................................................] 100%
[ 340.0527 ] Writing partition A_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 540000 bytes ]
[ 343.3713 ] [................................................] 100%
[ 343.3912 ] Writing partition A_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 400960 bytes ]
[ 350.0205 ] [................................................] 100%
[ 350.0407 ] Writing partition B_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 282768 bytes ]
[ 354.9699 ] [................................................] 100%
[ 354.9834 ] Writing partition B_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 139264 bytes ]
[ 358.4630 ] [................................................] 100%
[ 358.4719 ] Writing partition B_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 294912 bytes ]
[ 360.1849 ] [................................................] 100%
[ 360.1981 ] Writing partition B_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 437264 bytes ]
[ 363.8207 ] [................................................] 100%
[ 363.8381 ] Writing partition B_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164864 bytes ]
[ 369.2137 ] [................................................] 100%
[ 369.2227 ] Writing partition B_bpmp-fw with bpmp_t234-TE992M-A1_prod_sigheader.bin.encrypt [ 1046080 bytes ]
[ 371.2495 ] [................................................] 100%
[ 371.2902 ] Writing partition B_bpmp-fw-dtb with tegra234-bpmp-3701-0008-3737-0000_with_odm_sigheader.dtb.encrypt [ 151168 bytes ]
[ 384.1307 ] [................................................] 100%
[ 384.1399 ] Writing partition B_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 375168 bytes ]
[ 386.0055 ] [................................................] 100%
[ 386.0206 ] Writing partition B_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 190592 bytes ]
[ 390.6294 ] [................................................] 100%
[ 390.6411 ] Writing partition B_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 186880 bytes ]
[ 392.9901 ] [................................................] 100%
[ 392.9985 ] Writing partition B_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 139264 bytes ]
[ 395.2931 ] [................................................] 100%
[ 395.3035 ] Writing partition B_mb2rf with mb2rf_t234_sigheader.bin.encrypt [ 122048 bytes ]
[ 397.0151 ] [................................................] 100%
[ 397.0227 ] Writing partition B_cpu-bootloader with uefi_jetson_with_dtb_aligned_blob_w_bin_sigheader.bin.encrypt [ 2997600 bytes ]
[ 398.5295 ] [................................................] 100%
[ 424.3562 ] Writing partition B_secure-os with tos-optee_t234_sigheader.img.encrypt [ 1259424 bytes ]
[ 435.4069 ] [................................................] 100%
[ 448.3125 ] Writing partition B_eks with eks_sigheader.img.encrypt [ 9232 bytes ]
[ 450.9058 ] [................................................] 100%
[ 450.9108 ] Writing partition B_dce-fw with display-t234-dce_with_kernel_tegra234-p3701-0008-p3737-0000_aligned_blob_w_bin_sigheader.bin.encrypt [ 757424 bytes ]
[ 451.0374 ] [................................................] 100%
[ 451.0643 ] Writing partition B_fsi-fw with fsi-fw-ecc_sigheader.bin.encrypt [ 5746688 bytes ]
[ 460.3628 ] [................................................] 100%
[ 524.8556 ] Writing partition B_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 531.0381 ] [................................................] 100%
[ 531.0522 ] Writing partition B_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 540000 bytes ]
[ 534.3725 ] [................................................] 100%
[ 534.3959 ] Writing partition B_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 400960 bytes ]
[ 541.0267 ] [................................................] 100%
[ 541.0467 ] Writing partition bad-page with badpage.bin [ 5124 bytes ]
[ 545.9746 ] [................................................] 100%
[ 545.9808 ] Writing partition secondary_gpt_backup with gpt_backup_secondary_3_0.bin [ 16896 bytes ]
[ 546.0571 ] [................................................] 100%
[ 546.0628 ] Writing partition B_VER with jetson-agx-orin-devkit-industrial_bootblob_ver.txt [ 109 bytes ]
[ 546.2752 ] [................................................] 100%
[ 546.2794 ] Writing partition A_VER with jetson-agx-orin-devkit-industrial_bootblob_ver.txt [ 109 bytes ]
[ 546.2896 ] [................................................] 100%
[ 546.2945 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 546.3050 ] [................................................] 100%
[ 546.3102 ] Writing partition A_kernel with boot.img [ 35733504 bytes ]
[ 546.3173 ] [................................................] 100%
[ 547.7250 ] Writing partition A_kernel-dtb with kernel_tegra234-p3701-0008-p3737-0000.dtb [ 438851 bytes ]
[ 547.7276 ] [................................................] 100%
[ 547.7476 ] Writing partition B_kernel with boot.img [ 35733504 bytes ]
[ 547.7526 ] [................................................] 100%
[ 549.1703 ] Writing partition B_kernel-dtb with kernel_tegra234-p3701-0008-p3737-0000.dtb [ 438851 bytes ]
[ 549.1728 ] [................................................] 100%
[ 549.1918 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 549.1980 ] [................................................] 100%
[ 551.7747 ] Writing partition APP with core-image-sato-dev.ext4.img [ 1362318396 bytes ]
[ 551.7915 ] [................................................] 100%
[ 605.9942 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 605.9948 ] Bootloader version 01.00.0000
[ 605.9981 ] Writing partition BCT with br_bct_BR.bct [ 8192 bytes ]
[ 605.9985 ] [................................................] 100%
[ 612.5678 ] tegradevflash_v2 --write BCT-boot-chain_backup bct_backup.img
[ 612.5687 ] Bootloader version 01.00.0000
[ 612.5712 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 612.5715 ] [................................................] 100%
[ 612.9870 ] tegradevflash_v2 --write A_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 612.9875 ] Bootloader version 01.00.0000
[ 612.9899 ] Writing partition A_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18384 bytes ]
[ 612.9902 ] [................................................] 100%
[ 613.2289 ] tegradevflash_v2 --write B_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 613.2297 ] Bootloader version 01.00.0000
[ 613.2336 ] Writing partition B_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18384 bytes ]
[ 613.2345 ] [................................................] 100%
[ 613.4745 ] tegradevflash_v2 --write A_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 613.4750 ] Bootloader version 01.00.0000
[ 613.4787 ] Writing partition A_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 613.4793 ] [................................................] 100%
[ 616.4852 ] tegradevflash_v2 --write B_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 616.4862 ] Bootloader version 01.00.0000
[ 616.4887 ] Writing partition B_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 616.4894 ] [................................................] 100%
[ 619.4911 ] Flashing completed
[ 619.4912 ] Coldbooting the device
[ 619.4926 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 619.4934 ] MB2 version 01.00.0000
[ 619.4960 ] Coldbooting the device
[ 619.4967 ] tegrarcm_v2 --chip 0x23 0 --reboot coldboot
[ 619.4973 ] MB2 version 01.00.0000
tc@tc106:~/jetson-agx-orin-devkit-industrial.tegraflash$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 1d6b:0107 Linux Foundation USB Virtual Hub
Bus 001 Device 003: ID 0557:9241 ATEN International Co., Ltd SMCI HID KM
Bus 001 Device 004: ID 0b1f:03ee Insyde Software Corp. RNDIS/Ethernet Gadget
Bus 001 Device 009: ID 0955:7023 NVIDIA Corp. APX
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
