Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify): Ubuntu 24.04 LTS
GPU Information
- Model: RTX 4500 Ada
- Driver Version: 550.144.03
Topic Description
Import from onshape does not work, regardless of the assembly to be imported.
Steps to Reproduce
- Try to import any assembly from onshape. After selecting the assembly, the following error message appears in the logs:
Error Messages
2025-02-13 22:35:34 [1,467,683ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-26216' coro=<AssemblyDetailsWidget.build_ui.<locals>.create() done, defined at /home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/widgets/assembly_widget.py:772> exception=ErrorException(Error in 'pxrInternal_v0_22__pxrReserved__::ArFilesystemWritableAsset::Create' at line 46 in file /builds/omniverse/usd-ci/USD/pxr/usd/ar/filesystemWritableAsset.cpp : 'Could not create directory '/chicken/assets/Custom_USD_Stages/grasp_with_frankie.usd/EasyPuzzle_200/Materials/' for asset '/chicken/assets/Custom_USD_Stages/grasp_with_frankie.usd/EasyPuzzle_200/Materials/Materials.usd'', Error in 'pxrInternal_v0_22__pxrReserved__::Usd_CrateFile::CrateFile::StartPacking' at line 2506 in file /builds/omniverse/usd-ci/USD/pxr/usd/usd/crateFile.cpp : 'Unable to open /chicken/assets/Custom_USD_Stages/grasp_with_frankie.usd/EasyPuzzle_200/Materials/Materials.usd for write')>
File "/home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/widgets/assembly_widget.py", line 773, in create
self.usd_gen.create_all_stages(self._parts_widget.model._children)
File "/home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py", line 542, in create_all_stages
self._stages_dir, part, self.stage_unit, self.material_stage
File "/home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py", line 529, in material_stage
self._material_stage = createInMemoryStage(self._materials_path, self.stage_unit)
File "/home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py", line 150, in createInMemoryStage
stage = pxr.Usd.Stage.CreateNew(path)
pxr.Tf.ErrorException:
2025-02-13 22:35:34 [1,467,908ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-26217' coro=<UsdGenerator.set_part_mesh() done, defined at /home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py:546> exception=KeyError(53112490217517594)>
File "/home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py", line 549, in set_part_mesh
if not sync and not self._parts_stage_dict[part.get_key()].payload:
KeyError: 53112490217517594
2025-02-13 22:35:34 [1,467,938ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-26218' coro=<UsdGenerator.set_part_mesh() done, defined at /home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py:546> exception=KeyError(-7560833944980736558)>
KeyError: -7560833944980736558
2025-02-13 22:35:35 [1,468,135ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name='Task-26219' coro=<UsdGenerator.set_part_mesh() done, defined at /home/chicken/isaacsim/extscache/omni.importer.onshape-0.8.1+106.5.0/omni/importer/onshape/scripts/usd_generator.py:546> exception=KeyError(8884821858475168404)>
KeyError: 8884821858475168404
Screenshots or Videos
This is the screen after it gets stuck.
