I wrote the python code to publish the imu topic in Isaac Simulator like below code. And I set the sensor_period to 1/400, which is the 400 hz. But I got the UI FPS(like below image 89), not 400.
I run below code using script editor in Isaac Simulator.
What’s the matter in my code? And why am I getting from UI FPS, not sensor_period?
My Isaac version is “2022.2.0” and ros version is Noetic.
Thank you so much for reading this problem!
import rospy
import asyncio
from omni.isaac.sensor import _sensor
import omni
from sensor_msgs.msg import Imu
import omni.kit.commands
import time
from pxr import Gf, UsdGeom
class ImuPub:
def __init__(self):
self.imu_msg = Imu()
isaac_imu_topic = "/carter1/imu"
self.isaac_imu_pub = rospy.Publisher(isaac_imu_topic, Imu, queue_size=10)
self.carter_usd_path = '/World/Carter_ROS/chassis_link'
self._is = _sensor.acquire_imu_sensor_interface()
result, sensor = omni.kit.commands.execute(
"IsaacSensorCreateImuSensor",
path = '/Carter_imu',
parent = self.carter_usd_path,
sensor_period = 1/400,
translation = Gf.Vec3d(0,0,0),
orientation = Gf.Quatd(1, 0,0,0),
visualize = False, )
self.meters_per_unit = 1.0
print("Initialization Complete")
def run(self):
rospy.init_node("isaac_imu_pub")
asyncio.ensure_future(self.pub_imu())
async def pub_imu(self):
process_min = 0.5
t_end = time.time() + (60 * process_min)
while time.time() < t_end:
# while not rospy.is_shutdown():
await asyncio.sleep(0.0001)
imu_reading = self._is.get_sensor_readings(self.carter_usd_path + '/Carter_imu')
isaac_imu_msg = Imu()
isaac_imu_msg.header.frame_id = 'sim_imu'
if len(imu_reading) != 0:
last_reading = imu_reading[-1]
print(last_reading)
isaac_imu_msg.header.stamp = rospy.Time.from_seconds(last_reading['time'])
isaac_imu_msg.linear_acceleration.x = last_reading["lin_acc_x"]
isaac_imu_msg.linear_acceleration.y = last_reading["lin_acc_y"]
isaac_imu_msg.linear_acceleration.z = last_reading["lin_acc_z"]
isaac_imu_msg.angular_velocity.x = last_reading["ang_vel_x"] * self.meters_per_unit
isaac_imu_msg.angular_velocity.y = last_reading["ang_vel_y"] * self.meters_per_unit
isaac_imu_msg.angular_velocity.z = last_reading["ang_vel_z"] * self.meters_per_unit
self.isaac_imu_pub.publish(isaac_imu_msg)
if __name__ == "__main__":
imupub = ImuPub()
imupub.run()
