I want to change the camera fps and imu hz when i publish each topic(e.g /imu, /right_image) using ros2.
So,
How can i modify each parameters( 1) camera fps, 2) imu hz ) when i publish each topic?
For example, I want to change the camera fps from default fps to 30 frames. IMU either.
Thank you for reading!
