How to set the frequency of IMU publishing to ROS to 100hz? Why is the frequency of my IMU published to ROS only 20 + Hz? I set the IMU to publish to ROS topic using the action graph. I don’t know how to set the frequency.
Ene.li
2
Have you solved it?
Related topics
| Can I set IMU frequency in Isaac Sim | 2 | 2234 | August 27, 2022 | |
| IMU Sensor hz setting problem using ros2 in Isaac Simulator | 2 | 1223 | January 25, 2023 | |
| Isaac Sim increase rate of /imu topic ROS2 | 12 | 978 | August 15, 2025 | |
| IMU topic publish Code error | 3 | 677 | July 10, 2023 | |
| How to increase frequency of IMU and Joint State in simulation | 2 | 218 | September 29, 2025 | |
| ROS2 Isaac Sim camera fps & IMU hz setting | 1 | 957 | August 30, 2022 | |
| How do I set how often the camera publish images to ROS topic with GUI | 4 | 731 | August 23, 2023 | |
| ROS Publishing rate issue between 2022.2.1 and 2023.1.0-hotfix.1 | 6 | 648 | June 2, 2025 | |
| The problem of IMU noise | 1 | 625 | November 24, 2023 | |
| Noisy IMU sensor on Carter V1 | 4 | 1211 | January 2, 2023 |
