Publish RO2 Topics with better rate
I’m trying to publish TF to ROS2 for Move It, and I see my publish rate is between 30-40 Hz. Can anyone help me understand, how I can increase the publish rate?
I’m using isaac sim 4.2.0, ROS2 Humble.
Have you tried modifying the Qos profile in the Ros Publisher?
Hey @raihan619 ! Have you checked out this tutorial: ROS2 Setting Publish Rates — Omniverse IsaacSim?
Thanks @edsonbffilho for the reply. I did play around with it, but couldn’t see any increase in the publish rate. Let me do a proper read through this time
Thanks @zhengwang for the reply, Can you let me know how i can implement this when using python extension?
Hey @raihan619! Have you tried to follow this tutorial to set your simulation frame rate? You can do that with python extension. On a high performance machine, your TF publish rate should be close to your max frame rate.
I will close this topic since there is no new replies. But please feel free to open a new topic if the issue persists.
