Install DOCA on bluefield 2 failed
Hi, I want to install doca by sdkmanager on bluefiled 2.
But it seems that it hangs to write bfb onto /dev/rshim0/boot.
And the command “cat /dev/rshim0/misc” hangs forever.
The rshim service is active.
11:38:46 INFO: Flash BlueField OS Image - flash: sudo ./bfb-pre-install_v1.2.1.sh
11:38:47 INFO: Flash BlueField OS Image - flash: Setting Ubuntu Networking
11:38:47 INFO: Flash BlueField OS Image - flash: create new /etc/netplan/config.yaml file
11:38:47 INFO: Flash BlueField OS Image - flash: STATUS=50
11:38:47 INFO: Flash BlueField OS Image - flash: sudo bfb-install --bfb DOCA_v1.2.1_BlueField_OS_Ubuntu_20.04-5.4.0-1023-bluefield-5.5-2.1.7.0-3.8.5.12027-1.signed-aarch64.bfb --rshim rshim0 --config ./bf.cfg
11:38:47 INFO: Flash BlueField OS Image - flash: Pushing bfb + cfg
14:28:02 SUMMARY: DateTime Target Setup - target: Depends on failed component
I think it might be an issue about rshim.
Could anyone help me?
The root cause is the DPU would be dead if the temperature is high…
Solution is to add a box fan for it .
