Install nvidia-jetpack
An error will occur if you use the chroot environment
apt-get update
Get:1 https://repo.download.nvidia.com/jetson/common r32.4 InRelease [2552 B]
Get:2 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease [2565 B]
Get:3 Index of /ubuntu-ports bionic InRelease [242 kB]
Err:1 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
- The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004*
Err:2 https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease - The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004*
Unable to install
apt-get install -y nvidia-jetpack
et:61 Index of /ubuntu-ports bionic-security/multiverse DEP-11 48x48 Icons [29 B]
Get:62 Index of /ubuntu-ports bionic-security/multiverse DEP-11 64x64 Icons [2638 B]
Reading package lists… Done
W: GPG error: https://repo.download.nvidia.com/jetson/common r32.4 InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 0D296FFB880FB004
E: The repository’https://repo.download.nvidia.com/jetson/common r32.4 InRelease’ is not signed.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: GPG error: https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease: The following signatures couldn’t be verified because the p ublic key is not available: NO_PUBKEY 0D296FFB880FB004
E: The repository’https://repo.download.nvidia.com/jetson/t194 r32.4 InRelease’ is not signed.
I tried to add GITKEY ,still can’t install
#Get and install the nvidia-docker public key
curl -sL https://nvidia.github.io/nvidia-docker/gpgkey | sudo apt-key add-
#Set variable
distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
#Add repository
curl -sL https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | sudo tee /etc/apt/sources.list.d/nvidia-docker.list
#can’t install nvidia-jetpack
apt-get update
But the installation on the board is successful,
So copy the relevant deb to chroot environment
But there will still be errors in the installation
dpkg -i *.deb
Setting up mesa-common-dev:arm64 (20.0.8-0ubuntu1~18.04.1) …
Setting up nvidia-container-csv-cudnn (7.6.3.28-1+cuda10.0) …
Setting up nvidia-container-toolkit (1.0.1-1) …
dpkg: dependency problems prevent configuration of nvidia-l4t-jetson-multimedia-api:
nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-camera (= 32.3.1-20191209230245); however:
Package nvidia-l4t-camera is not installed.
nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-core (= 32.3.1-20191209230245); however:
Package nvidia-l4t-core is not installed.
nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-multimedia (= 32.3.1-20191209230245); however:
Package nvidia-l4t-multimedia is not installed.
nvidia-l4t-jetson-multimedia-api depends on nvidia-l4t-multimedia-utils (= 32.3.1-20191209230245); however:
Package nvidia-l4t-multimedia-utils is not installed.
dpkg: error processing package nvidia-l4t-jetson-multimedia-api (–install):
dependency problems-leaving unconfigured
Setting up po-debconf (1.0.20) …
Setting up uff-converter-tf (6.0.1-1+cuda10.0) …
Setting up vpi (0.1.0) …
update-alternatives: using /opt/nvidia/vpi/vpi-0.1/lib/libnvvpi.so.0.1.0 to provide /usr/lib/aarch64-linux-gnu//tegra/libnvvpi.so.0.1.0 (vpi ) in auto mode
update-alternatives: error: error creating symbolic link’/usr/lib/aarch64-linux-gnu//tegra/libnvvpi.so.0.1.0.dpkg-tmp’: No such file or directory
dpkg: error processing package vpi (–install):
installed vpi package post-installation script subprocess returned error exit status 2
dpkg: dependency problems prevent configuration of vpi-dev:
vpi-dev depends on vpi (= 0.1.0); however:
Package vpi is not configured yet.
dpkg: error processing package vpi-dev (–install):
dpkg: dependency problems prevent configuration of vpi-samples:
vpi-samples depends on vpi-dev (= 0.1.0); however:
Package vpi-dev is not configured yet.
Unable to install
