I'm having trouble with install nvidia-jetpack
I’m having trouble with install nvidia-jetpack
manager@manager-desktop:~$ apt depends nvidia-jetpack | awk ‘{print $2}’ | xargs -I {} sudo apt install -y {}
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Reading package lists… Done
Building dependency tree
Reading state information… Done
nvidia-cuda is already the newest version (4.4.1-b50).
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common kde-window-manager kinit kio
kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5 libkdecorations2private5v5 libkf5activities5 libkf5attica5
libkf5completion-data libkf5completion5 libkf5declarative-data libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5
libkf5idletime5 libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data
libkf5newstuff5 libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5 libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5 libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5
libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5 libqt5multimedia5
libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5 libqt5quickwidgets5 libqt5sql5 libqt5test5 libxcb-composite0 libxcb-cursor0
libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit python3-sip
qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel tasksel-data
Use ‘sudo apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 307 not upgraded.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nvidia-opencv : Depends: libopencv (= 4.1.1-2-gd5a58aa75) but it is not going to be installed
Depends: libopencv-dev (= 4.1.1-2-gd5a58aa75) but it is not going to be installed
Depends: libopencv-python (= 4.1.1-2-gd5a58aa75) but it is not going to be installed
Depends: libopencv-samples (= 4.1.1-2-gd5a58aa75) but it is not going to be installed
Depends: opencv-licenses (= 4.1.1-2-gd5a58aa75) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
nvidia-cudnn8 is already the newest version (4.4.1-b50).
nvidia-tensorrt is already the newest version (4.4.1-b50).
nvidia-visionworks : Depends: libvisionworks-samples (= 1.6.0.501) but it is not going to be installed
Depends: libvisionworks-sfm-dev (= 0.90.4.501) but it is not going to be installed
Depends: libvisionworks-tracking-dev (= 0.88.2.501) but it is not going to be installed
nvidia-container is already the newest version (4.4.1-b50).
nvidia-vpi : Depends: vpi-samples (= 0.4.4) but it is not going to be installed
nvidia-l4t-jetson-multimedia-api is already the newest version (32.4.4-20201027211359).
What am I supposed to do?
I have tried to install nvidia-jetpack.
URL : How to Install JetPack :: NVIDIA JetPack Documentation
untill now, I have installed nvidia-jetpack successfully using above command.
Check please.
Thank you.
Hi Hodu,
Are you remove JetPack components before running new JetPack components commands?
No, but I have installed jetpack component for the first time with this nano.
Since I have installed a jetpack component, opencv and vpi is omitted
https://docs.nvidia.com/jetson/jetpack/install-jetpack/index.html#how-to-install-jetpack
Thank you.
Hi Hodu,
You already install jetpack components success.
Sorry, I don’t understand what is your problem now.
@forumuser I guess this is language problem. Please try to describe what you’ve done clearly.
Hello, WayneWWW
I installed the jatpack component referring to how to install the jetpack component in the emmc module, but opencv and vpi wer not installed.
The log is as attached above.
I have installed the jetpack component in the emmc module several times, but this is the first time I asked a question.
Thank you.
Please reflash the board and re-install jetpack again.
