Jetson
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0.1
Documentation issue
The links in /opt/nvidia/deepstream/deepstream-6.0/sources/libs/azure_protocol_adaptor/module_client/README are invalid.
The second link …
#Register a new Azure IoT Edge device from the Azure portal:
https://docs.microsoft.com/en-us/azure/iot-edge/how-to-register-device-portal
Leads you to 404 - Page not found
The last link
#For Jetson:
Install the Azure Iot Edge from the instructions provided here: https://aka.ms/install-iot-edge-arm64
Incorrectly routs you to Create and provision an IoT Edge device on Linux using symmetric keys which I believe, leads you to install the incorrect version of IoT Edge.
Is there correct documentation available for setup on arm64?? I was about to try the following… https://www.henkboelman.com/blog/iot-edge-custom-vision-on-the-jetson-nano/ but wanted to check here first…
Thanks,
Robert.
