Azure IOT Edge, Deepstream SDK version
I’m trying to deploy Deepstream SDK from Azure IOT Edge to my Jetson Nano 2GB, but having issues with the version of the SDK/container.
This is my version on the Jetson:
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64 (JetPack 4.6.1)
When deploying this container-version: nvcr.io/nvidia/deepstream-l4t:6.0.1-samples, I get this error:
<3> 2022-05-20 13:27:28.289 +00:00 [ERR] - Edge agent plan execution failed.
System.AggregateException: One or more errors occurred. (Error calling start module NVIDIADeepStreamSDK: Could not start module NVIDIADeepStreamSDK
caused by: Could not start module NVIDIADeepStreamSDK
caused by: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown)
—> Microsoft.Azure.Devices.Edge.Agent.Edgelet.EdgeletCommunicationException- Message:Error calling start module NVIDIADeepStreamSDK: Could not start module NVIDIADeepStreamSDK
caused by: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: error adding seccomp filter rule for syscall clone3: permission denied: unknown, StatusCode:500, at: at Microsoft.Azure.Devices.Edge.Agent.Edgelet.Version_2021_12_07.ModuleManagementHttpClient.HandleException(Exception exception, String operation) in /mnt/vss/_work/1/s/edge-agent/src/Microsoft.Azure.Devices.Edge.Agent.Edgelet/version_2021_12_07/ModuleManagementHttpClient.cs:line 231
at Microsoft.Azure.Devices.Edge.Agent.Edgelet.Versioning.ModuleManagementHttpClientVersioned.Execute[T](Func`1 func, String operation) in /mnt/vss/_work/1/s/edge-agent/src/Microsoft.Azure.Devices.Edge.Agent.Edgelet/versioning/ModuleManagementHttpClientVersioned.cs:line 155
at Microsoft.Azure.Devices.Edge.Agent.Edgelet.Version_2021_12_07.ModuleManagementHttpClient.StartModuleAsync(String name) in /mnt/vss/_work/1/s/edge-agent/src/Microsoft.Azure.Devices.Edge.Agent.Edgelet/version_2021_12_07/ModuleManagementHttpClient.cs:line 179
at Microsoft.Azure.Devices.Edge.Agent.Edgelet.ModuleManagementHttpClient.<>c__DisplayClass26_0.<b__0>d.MoveNext() in /mnt/vss/_work/1/s/edge-agent/src/Microsoft.Azure.Devices.Edge.Agent.Edgelet/ModuleManagementHttpClient.cs:line 140
— End of stack trace from previous location where exception was thrown —
Please follow readme to setup IOT edge module.
sources/libs/azure_protocol_adaptor/module_client/README
