I just received my Jetson TX1 and started the flashing process. I am having trouble flashing because I keep getting an error stating Invalid target board -jetson-tx1. when I use the command,
You need to put it in recovery mode first.
To do so press the power button, then press and hold down the rec button which is next to the power button. While holding the rec button press the reset button and continue holding the rec button for 2 more seconds. If that was too confusing look up recovery mode TX1.
someone has changed the default password, so I am flashing jetson-tk1 from raspberry pi 2 with ubuntu mate 16.04 but at the last step it shows Invalid Target Board. Please help.
Flash requires an x86_64 Linux host. RPi and RPi2 will not work.
One thing I see which might or might not be a problem is that I see the flash commands are run with full path. Some file content is using a relative path to the current working directory, so if you are not actually in the flash.sh directory at the time it is run you might get mysterious failures due to that.
