Hi Team,
I am trying to run Omniverse Audio2Face on my system with NVIDIA GeForce RTX 5080 (CUDA Compute Capability 12.0), but the application doesn’t launch correctly due to IRAY rendering issues.
System Info:
- GPU: NVIDIA Ge Fourse RTX 5080 50 series (CUDA 12.0)
- OS: Windows 11 pro
- RAM: 64GB
- Storage: 2Tb
- Omniverse Audio2Face Version: 2023.2.0
- Installed via: Omniverse Launcher
Here is the exact log message from my system:
2025-06-12 12:51:02 [23,707ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.lt and use insort ‘key’ arg instead
[24.845s] [ext: omni.deform.ssd-105.2.1] startup
[24.896s] [ext: omni.anim.window.timeline-105.11.14] startup
[24.949s] [ext: omni.anim.skelJoint-105.1.17] startup
[25.004s] [ext: audio2face-2023.0.0] startup
2025-06-12 12:51:03 [24,881ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : GPU 1 (NVIDIA GeForce RTX 5080) with CUDA compute capability 12.0 is unsupported by this version of iray photoreal. Please look for an update with your software provider.
2025-06-12 12:51:03 [24,882ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
2025-06-12 12:51:05 [27,218ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2025-06-12 12:51:05 [27,218ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[28.501s] app ready
2025-06-12 12:51:06 [27,742ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2025-06-12 12:51:06 [27,756ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
2025-06-12 12:51:08 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
I would like to know:
- Will IRAY be updated soon to support CUDA 12.0 (RTX 5080)?
- Is there a cleaner way to bypass IRAY for newer GPUs?
- Any known timeline for RTX 50-series support in IRAY?
Please guide me or suggest a permanent fix.
