I just installed Omniverse and wondered why Iray is greyed out. Any idea how to enable it?
Hi @chris75
We have separate launch scripts to run Create in different modes.
Can you you try running the Iray bat script from your Create installation folder?
It should be in your User/AppData/Local/ov/pkg/create2020.3.0.rc-1 folder. If you installed to a different directory, you can check the Launcher Settings for Create to see where the installation path is.
Hi Chris,
In Create there is an AppLauncher under the “Help” entry.
Check the attached video - should be easy to enable.
Have fun
Hi, the video helped me to solver the issue. Thanks for your help.
