When I launch Omniverse Create everything looks as expected, except the viewport is gray, and no scene content is rendered.
Different versions behave slightly differently:
- With the standard launcher, the logs show
Driver Version: 0.0, but with the singlegpu launcher the driver is correctly identified. In both cases the viewport is blank gray. - The Hydra Storm version works as expected with scene elements appearing in the viewport.
- The iray version crashes with a segfault before it’s able to open the GUI at all.
Comparing the hdstorm (working) and singlegpu (blank viewport) versions,
Both logs contain a lot of the same this warnings, including:
[Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/x/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
The hdstorm version shows this error, although it still works fine:
[Error] [omni.kit.window.viewport.plugin] Failed to find suitable scene renderer
The singlegpu version does not show that error, but it does dump the following errors not present in the hdstorm logs:
2021-07-05 19:45:26 [1,412ms] [Warning] [omni.ext.plugin] [ext: omni.kit.editor-full-0.0.0] '/home/jmp/.local/share/ov/pkg/create-2021.1.1/_build/kit_release/_build/linux-x86_64/release/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
| Driver Version: 460.80 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | GeForce RTX 3060 | Yes | | 12534 MB | 10de | 0 |
| | | | | | 2503 | 835eb8a4.. |
| OS: Linux higgs, Version: 5.11.0-16-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12011000 (1.20.11.0)
| Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 32048 | Free Memory: 15724
| Total Page/Swap (MB): 5631 | Free Page/Swap: 5631
2021-07-05 19:45:27 [2,683ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/scenedb/SparseMemCopy.compute.hlsl'.
2021-07-05 19:45:27 [2,683ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/utils/PrefixScanBuffer.compute.hlsl'.
2021-07-05 19:45:27 [2,683ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/scenedb/SparseMemCopy.compute.hlsl
2021-07-05 19:45:27 [2,683ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.psodb.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/utils/PrefixScanTexture.compute.hlsl'.
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/utils/PrefixScanBuffer.compute.hlsl'.
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl'.
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2021-07-05 19:45:27 [2,693ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.psodb.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl'.
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl'.
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/scenedb/TranslateInstancePosition.compute.hlsl'.
2021-07-05 19:45:27 [2,694ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/scenedb/TranslateInstancePosition.compute.hlsl
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/scenedb/Skinning.comp.hlsl'.
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/scenedb/SkinNormal.comp.hlsl'.
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/scenedb/Skinning.comp.hlsl
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/scenedb/SkinNormal.comp.hlsl
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/scenedb/NormalGeneration.comp.hlsl'.
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.psodb.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-07-05 19:45:27 [2,715ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/raytracing/LightVoxels.cs.hlsl'.
2021-07-05 19:45:27 [2,716ms] [Error] [rtx.psodb.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-07-05 19:45:27 [2,716ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/scenedb/NormalGeneration.comp.hlsl
2021-07-05 19:45:27 [2,716ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/raytracing/LightVoxels.cs.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/raytracing/SimpleMiss.ms.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/raytracing/SimpleMiss.ms.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/rasterizing/Line.vertex.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/rasterizing/Line.geometry.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.vertex.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/rasterizing/Point.pixel.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/rasterizing/Line.pixel.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/rasterizing/Point.geometry.hlsl'.
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.pixel.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.geometry.hlsl
2021-07-05 19:45:27 [2,717ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.pixel.hlsl
2021-07-05 19:45:27 [2,897ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/system/GenerateMipMap.comp.hlsl'.
2021-07-05 19:45:27 [2,897ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,897ms] [Error] [rtx.resourcemanager.plugin] Failed to async compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,898ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,899ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,900ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,901ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,902ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,903ms] [Error] [rtx.resourcemanager.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/utils/DiffTextures.compute.hlsl'.
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/utils/DiffTextures.compute.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/raytracing/Gbuffer.rgs.hlsl'.
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/raytracing/Shadow.rgs.hlsl'.
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.psodb.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/filters/ShadowSpatial.compute.hlsl'.
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/raytracing/Gbuffer.rgs.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/raytracing/Shadow.rgs.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/filters/ShadowSpatial.compute.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] Cannot load shader file 'rtx/raytracing/RTAO.rgs.hlsl'.
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.shaderdb.plugin] buildShaderAsync() failed: rtx/raytracing/RTAO.rgs.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.raytracing.plugin] Failed to async compile raygen shader: rtx/raytracing/RTAO.rgs.hlsl
2021-07-05 19:45:27 [2,904ms] [Error] [rtx.raytracing.plugin] initialize failure: m_rtPass creation failed
2021-07-05 19:45:27 [2,904ms] [Error] [carb.scenerenderer-rtx.plugin] Creating rtx::raytracing::AmbientOcclusionContext failed.
2021-07-05 19:45:27 [3,081ms] [Warning] [carb.scenerenderer-mux.plugin] Failed to create context for scene renderer 'rtx'.
2021-07-05 19:45:27 [3,081ms] [Error] [carb.scenerenderer-mux.plugin] No carb::scenerenderer::SceneRenderer was found.
