Hi:
I expect to superposition the data of the two images.
Achieve an effect of transparency.
A function similar to the OSD.
Can Nvmedia support this in order to reduce data processing time?
Is there a Demo program available for reference?
Thank you!
kayccc
August 18, 2022, 8:34am
#2
Are you askng for DRIVE Orin platform?
Dear @songqing.zhang ,
Unfortunately we donāt have APIs to perform superposition the data of the two images.
Ok, thanks for your reply!
This function interface should do what I want.
This is so great!
However, we are still using the old SDK version (5.2).
I will try using the new SDK.
Thank you very much!
VickNV
August 22, 2022, 5:28pm
#11
@songqing.zhang So this topic is for Xavier or Orin devkit? Which one are you using now?
VickNV
August 23, 2022, 3:28pm
#13
If thatās the case, you should use DRIVE OS 6.x. DRIVE OS 5.x doesnāt support Orin. Thanks.
Iām sorryļ¼my mistakeļ¼In fact, we are currently using DRIVE OS 6.0.2. Thanks
