Is there a way to compute overlaping volume of two objects?
Isaac Sim Version
4.2.0
Isaac Lab Version (if applicable)
1.2
Operating System
Ubuntu 22.04
Hi.
Specifically I have two prims(one represents robot and the other one has a simple shape,eg, cube), and I have turned off the collision of the cube so that I can allow my robot to traverse in that cubic regime
I want to know if there is function that is able to compute the overlaping volume between the two, in other words, I want to compute the accurate volume of my robot in that region.
I am thinking of class omni.physx.bindings._physx.PhysXSceneQuery but I don’t think in phyX there is a function that can directly return the overlaping volume given two prim paths, for instance.
Of course, simple boundingbox methods doesn’t satisfy my precision requriment. So I am think is there any advanced function in PhyX or extensions?
THanks.
Haoyu
We currently have an internal feature request regarding this in PhysX, but it is not supported at this time.
I had the same issue, in Isaac there is a workaround in the UI atleast for 4.5.0, you can read the mass properties of a prim (Tools → Physics toolbar, and enable Mass Distribution Manipulator). If you set the density of the object to a fixed value and mass auto-generated, you then have the mass and density, so you can calculate the volume yourself with mass/density == volume. Just make sure you know what units the stage is using (I was using a stage in cm and kg and got some values I didn’t understand using densities at around ~1000 kg/cm3 :) )
I dunno if you can get the density and mass from the API though?
Seems like some more people have asked similar questions, and this was the only I could reply too Getting the volume of prims and How to get volume of object in scene?
PhysX does not expose an overlap volume API – the PhysXSceneQuery overlap methods (overlap_box, overlap_mesh, etc.) return hit count or boolean, not volume. There is an internal feature request for this, but it is not available yet.
One note on @rasmus.larsson’s suggestion: the mass/density trick gives you the total volume of a single prim – useful on its own, but not the intersection volume of two prims, which is what the original question asks for.
Workaround: trimesh boolean intersection
For the actual overlap volume, the cleanest approach is a mesh boolean intersection using trimesh. trimesh 4.5.2 is bundled with Isaac Sim 6.1.0 (via the IRI pip_prebundle), and you can install the manifold3d backend separately:
pip install manifold3d
Then extract the mesh geometry from your USD prims and compute the intersection:
from pxr import UsdGeom
import trimesh
import trimesh.boolean
import numpy as np
def usd_mesh_to_trimesh(stage, prim_path):
    prim = stage.GetPrimAtPath(prim_path)
    mesh = UsdGeom.Mesh(prim)
    pts = np.array(mesh.GetPointsAttr().Get())
    face_counts = np.array(mesh.GetFaceVertexCountsAttr().Get())
    face_indices = np.array(mesh.GetFaceVertexIndicesAttr().Get())
    # Triangulate: assumes all-triangle mesh; for quads, split each quad into two tris
    faces = face_indices.reshape(-1, 3)
    return trimesh.Trimesh(vertices=pts, faces=faces)
mesh_robot = usd_mesh_to_trimesh(stage, "/World/Robot")
mesh_zone  = usd_mesh_to_trimesh(stage, "/World/Zone")
intersection = trimesh.boolean.intersection([mesh_robot, mesh_zone], engine="manifold")
print("Overlap volume:", intersection.volume)
Requirement: both meshes must be watertight (closed surfaces). If the robot mesh has open
surfaces, trimesh.repair.fill_holes(mesh) can help.
Alternative: voxelization (no extra deps, approximate)
If you cannot install manifold3d, voxelization gives an approximate result with controllable
precision (via the pitch parameter):
pitch = 0.005  # voxel size in stage units; smaller = more accurate, slower
vox_robot = mesh_robot.voxelized(pitch=pitch)
vox_zone  = mesh_zone.voxelized(pitch=pitch)
overlap = vox_robot.intersection(vox_zone)
print("Overlap volume (approx):", overlap.volume)
Analytic shortcut (cube zone)
Since your zone is an axis-aligned cube, you can skip the full boolean and instead clip the
robot mesh triangles directly against the cube’s AABB. This avoids the manifold requirement
entirely, but is more code. The trimesh approach above is simpler for most cases.
Closing this topic since the PhysX status has been answered and workarounds are available.
If the native PhysX feature ships in a future release, we will update the docs.
