Isaac ROS 4.4 Dev Container Build Fails: Unable to locate package nvv4l2 on Ubuntu 22.04 x86_64 RTX 5050
System:
  • Ubuntu 22.04.5 LTS
  • ROS 2 Humble
  • NVIDIA Driver 595.71.05
  • CUDA Toolkit 12.8
  • GPU: NVIDIA GeForce RTX 5050 Laptop GPU
  • Docker 29.5.3
  • NVIDIA Container Runtime working
Verification:
  • nvidia-smi works
  • nvcc works
  • Docker GPU passthrough works:
    docker run --rm --gpus all nvidia/cuda:12.8.0-base-ubuntu22.04 nvidia-smi
Repositories:
  • isaac_ros_common release-4.4
  • isaac_ros_visual_slam release-4.4
Issue:
I attempted to use the Isaac ROS development container workflow. The Docker image build starts successfully and downloads the base image, but fails during Dockerfile.x86_64 execution with:
E: Unable to locate package nvv4l2
Relevant section:
RUN apt-get update && apt-get install -y
nvv4l2
The build stops at this point before Visual SLAM is compiled.
Questions:
  1. Is nvv4l2 still expected to be available for Isaac ROS 4.4 on Ubuntu 22.04 x86_64?
  2. Has this package been renamed, moved, or removed from the current repositories?
  3. Is there an updated Isaac ROS 4.4 setup workflow for x86_64 systems with newer GPUs such as RTX 5050?
Any guidance would be appreciated.
Hello @sanjana.lankadi,
Welcome to the Isaac ROS forum!
This appears to be a platform mismatch. Isaac ROS 4.4 on X86_64 is supported on Ubuntu 24.04 Noble with ROS 2 Jazzy, please check the supported system requirements. If you would like to stay on Ubuntu 22.04 / ROS 2 Humble, please install Isaac ROS 3.2 instead.
