Isaac ROS 4.4 / JetPack 7.2 Container missing nvcc — colcon build fails on isaac_ros_common
Hi everyone,
I am setting up an Isaac ROS 4.4 workspace on a Jetson platform running JetPack 7.2 (L4T R39.2.0).
While my host Jetson environment has the CUDA Toolkit fully configured and functional, the container launched by the new isaac-ros CLI v4.0 fails to find or see the nvcc compiler.
When attempting to execute a standard workspace compilation, colcon build aborts at the isaac_ros_common layer with the following CMake error:
--- stderr: isaac_ros_common
CMake Error at /usr/share/cmake-3.28/Modules/Internal/CMakeCUDAFindToolkit.cmake:104 (message):
  Failed to find nvcc.
  Compiler requires the CUDA toolkit.  Please set the CUDAToolkit_ROOT
  variable.
Call Stack (most recent call first):
  /usr/share/cmake-3.28/Modules/CMakeDetermineCUDACompiler.cmake:89 (cmake_cuda_find_toolkit)
  CMakeLists.txt:24 (enable_language)
Environment Details:
  • Host OS: JetPack 7.2 / L4T R39.2.0 (aarch64)
  • Isaac ROS Release: v4.4
  • Host CUDA/NVCC: Release 13.2, V13.2.78
  • Host /etc/docker/daemon.json configuration
        "default-runtime": "nvidia",
        "runtimes": {
            "nvidia": {
                "args": [],
                "path": "nvidia-container-runtime"
Observed Behaviors & Constraints:
  1. Running /usr/local/cuda/bin/nvcc --version directly inside the container yields bash: /usr/local/cuda/bin/nvcc: No such file or directory, confirming that the host’s CUDA binaries are completely blocked or filtered out from mounting.
  2. Attempting to run echo "export PATH..." >> ~/.bashrc directly inside the container fails completely, yielding: bash: /home/admin/.bashrc: Read-only file system. This is due to the immutable user directory enforcement in the 4.x container stack.
  3. Injecting traditional volume mounts (-v /usr/local/cuda:/usr/local/cuda:ro) via the workspace configurations (.isaac-ros-cli/config.yaml or user-scope variants) seems to be systematically stripped out or ignored by the isaac-ros CLI layer wrapper during container generation.
Questions:
  1. Is anyone else encountering host toolkit mounting filters on JetPack 7.2, and what is the officially supported mechanism to restore nvcc mapping into the ROS 2 Jazzy deployment shell?
Any insights or recommended config patches would be highly appreciated. Thanks!
Hello @terminalindigenous,
Welcome to the Isaac ROS forum and thanks for the post!
Isaac ROS 4.4 does not support JetPack 7.2 yet, you could reference this supported platforms matrix. Please downgrade/reflash to the Isaac ROS 4.4 supported JetPack 7.1 / R38.4.0 stack and retry the workspace build.
Thanks for your patience. Isaac ROS 4.6.0 is now available!
This release adds support for JetPack 7.2 on Jetson Orin and Jetson Thor. Please refer to the Isaac ROS 4.6 Release Notes — Isaac ROS and Isaac ROS 4.6 setup instructions for more details.
